  Antimon Antimon Waves
 Forum index » Instruments and Equipment » Reaktor
Can't use Reaktor 5.1.2
Page 1 of 1 [7 Posts]
ocp
Audio files: 9
PostPosted: Sun Dec 17, 2006 8:12 pm    Post subject: Can't use Reaktor 5.1.2
Subject description: activation loop
I did the 5.1.2 UB update and now Reaktor won't work.
Whenever I open it, I'm asked to activate it.
The problem is I already did that and there's no solution in sight from NI.
I contacted NI support several times and they couldn't give me a satisfactory answer.
Wondering if anyone is going through the same Sad
http://joaoricardo.org | http://myspace.com/boiar | http://editoradoporto.blogspot.com
Mohoyoho
PostPosted: Mon Dec 18, 2006 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't do the update. I'm on a PC, and the update didn't seem to offer me anything I needed. I'd recommend going back to your older version and waiting for NI to sort this out. Awhile ago I noticed some problems mentioned on their forum. I haven't checked recently to see if anything has been resolved. Good luck.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
Axiom
G2 patch files: 28
PostPosted: Tue Jan 02, 2007 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
i've done the update and, then, redo the activation using NI Service Center application. It works perfectly. Did you used this last?
Luca
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
ocp
Audio files: 9
PostPosted: Fri Jan 12, 2007 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried everything, believe me!
Still not working and support can't solve the problem.
In the Reaktor forum, I'm not the only one going through this.
Note: I have the download version.
Axiom
G2 patch files: 28
PostPosted: Sat Jan 13, 2007 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
did you tried to remove activation keys from your PC/Mac and retrying the activation?
Luca
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sat Jan 13, 2007 9:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are you on mac? Apparently alot of people have been having issues with the update on mac... Check the NI forums
ocp
Audio files: 9
PostPosted: Wed Jul 04, 2007 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I was one of them.
After some time NI figured I had to buy the UB update - which I did - and all went fine.
I just regret the time it took...
