 Forum index » Instruments and Equipment » Cwejman Sound
D-LFO locking
Jari Jokinen
PostPosted: Tue Jan 30, 2007 3:14 pm    Post subject: D-LFO locking Reply with quote  Mark this post and the followings unread
I am a novice in analogue modulars and a proud owner of five Cwejman modules including a D-LFO.
I noticed, that at audio range the two oscillators lock, if tuned too close to each other. This is a somewhat undesireable feature... I wonder, if it is normal.
A bit surprisingly (for me) the D-LFO can make some sequencer like patterns. Here is a quick example: The only CV source is the D-LFO, which controls a Cwejman MMF-1 filter.
Best regards
Jari Jokinen
D-LFO_sequence.mp3
 Filename:  D-LFO_sequence.mp3
 Filesize:  109.76 KB
 Downloaded:  393 Time(s)
doctorvague
PostPosted: Thu May 10, 2007 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like it!
yusynth
PostPosted: Wed May 16, 2007 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
They should not lock, I think it's a design problem certainly because the two oscillators share the same power rails. To avoid this one must add separate voltage regulators on the power rails of each LFO...
Yves
Niio1
