dws
Joined: Feb 05, 2007 Posts: 6 Location: Toronto, Canada
Posted: Mon Feb 05, 2007 9:07 am Post subject:
new class creation question |
I am trying to create a new Event class and need to refer to an instance of that class internally (i.e. within the class definition). me only refers to a shred. Any idea how to do this?
thanks,
don |
spencer
Joined: Aug 16, 2006 Posts: 53 Location: northern california
Posted: Mon Feb 05, 2007 3:19 pm Post subject:
Hi Don,
You can do this with the this keyword. Here is a useless, contrived example: Code: | class A
0 => int value;
fun int getValue()
return this.value;
fun void printValue()
<<< this.getValue() >>>;
hope this helps,
spencer |
dws
Posted: Tue Feb 06, 2007 6:18 pm Post subject:
Perfect. Thanks, I'll report back when I have it working...
don
spencer wrote: | Hi Don,
0 => int value;
fun int getValue()
return this.value;
<<<this>>>;
hope this helps,
spencer |
Kassen
Posted: Thu Feb 08, 2007 8:01 am Post subject:
Erm, DWG did you notice there's a rather big difference between Spencer's post and your quote? I think Spencer edited a mistake he made after it got quoted?
Anyway, I thought I'd point that out before there is confusion. Wecome on board, BTW! _________________ Kassen |
spencer
Posted: Thu Feb 08, 2007 10:22 am Post subject:
Kassen wrote: | Erm, DWG did you notice there's a rather big difference between Spencer's post and your quote? I think Spencer edited a mistake he made after it got quoted?
Anyway, I thought I'd point that out before there is confusion. Wecome on board, BTW! |
Hmm, no, no edits from me. Looks like a case of the forum's misguided HTML parsing... my guess is he copied+pasted it correctly but when it was "converted" to proper HTML after posting, the .getValue() was chopped off.
spencer |
dws
Posted: Wed Feb 14, 2007 10:03 am Post subject:
new class creation continued |
ok here is what i am trying to do... i want to create a public class with a method called playnote(pitch, velocity, duration, channel) that will handle playing midi notes. then i want to call it from another chuck file. the problem is that when i call the method, more than once (two play two notes at once), the second (and subsequent) notes don't play until the previous one is finished. i assume that i am a bit confused about chuck time. here is what i have. i have attached the two files as well. any pointers would be greatly appreciated.
don
class creation file:
Code: | public class Makemidinote
MidiOut mout;
MidiMsg msg;
int pitch;
int velocity;
int duration;
int channel;
0 => int device;
// try to open MIDI port (see chuck --probe for available devices)
if( !mout.open( device ) ) me.exit();
// print out device that was opened
<<<MIDI> ", mout.name() >>>;
public void playnote(int p, int v, int d, int c)
p => pitch;
v => velocity;
d => duration;
c => channel;
// do midi out (on/off)
144 + (channel - 1) => msg.data1;
pitch => msg.data2;
velocity => msg.data3;
mout.send(msg);
128 + (channel - 1) => msg.data1;
pitch => msg.data2;
<<<"on: ", this, pitch, velocity, duration, channel>>>;
me.yield();
duration::ms => now;
me.yield();
mout.send(msg);
<<<"off: ",pitch, velocity, duration, channel>>>;
other file that calls function:
Code: | Makemidinote n;
n.playnote(59, 80, 4000, 1);
n.playnote(69, 80, 2000, 1);
n.playnote(49, 80, 1000, 1);
1::second => now;
n.playnote(61, 80, 4000, 1); |
Description: |
 Download (listen) |
Filename: |
test.ck |
Filesize: |
151 Bytes |
Downloaded: |
452 Time(s) |
Description: |
 Download (listen) |
Filename: |
Makemidinote.ck |
Filesize: |
848 Bytes |
Downloaded: |
456 Time(s) |
spencer
Posted: Wed Feb 14, 2007 11:06 am Post subject:
Don,
Quick note-you might want to use the "Disable HTML in this post" option when posting ChucK code. It looks like part of your ChucK program was erroneously deleted by the forum software as it tried to parse it as HTML when you posted it. See this thread for more info:
http://electro-music.com/forum/topic-14150.html
(Its also possible to disable HTML in posts by default through your profile.)
The reason why notes aren't playing simutaneously is because the playnote function does duration::ms => now; This means that the function will take a total of duration milliseconds to return. So the first n.playnote() in your test program will take 4000 ms, and then after that the next next n.playnote() will take 2000 ms, etc., in sequence. One really easy solution would be to spork each function call in a new shred. E.g.
spork ~ n.playnote(59, 80, 4000, 1);
spork ~ n.playnote(69, 80, 2000, 1);
spork ~ n.playnote(49, 80, 1000, 1);
1::second => now;
spork ~ n.playnote(61, 80, 4000, 1); |
This will spork a new shred for each note, so that groups of notes will play in parallel, rather than in sequence. However this creates a problem. Each of these shreds is going to be making modifications to the
Code: | MidiMsg msg;
int pitch;
int velocity;
int duration;
int channel;
part of n in parallel. This means that the values of these variables could be constantly changing as each new shred goes through the playnote function, and the variables could contain incorrect values when you create your MIDI msg. So the solution to this would be to move all of these variables into the body of the playnote() function, assuming you don't need them in any other functions in the Makemidinote class. In fact you could probably even remove the pitch, velocity, duration, and channel variables as they seem to be redundant in the code you posted, and just use the p, v, d, and c variables.
hope this helps!
spencer |
Kassen
Posted: Wed Feb 14, 2007 11:39 am Post subject:
spencer wrote: | Don,
Quick note-you might want to use the "Disable HTML in this post" option when posting ChucK code. |
Yet better; I found that you can disable HTML for all posts you make by setting a single checkbox in your profile.
I did this myself as well; it's just too easy to forget about the silly little checkbox every time. Site-admin Mosc is looking into improving the behaviour of the "code" tag to stop the board from trying to parse HTML. _________________ Kassen |
dws
Posted: Wed Feb 14, 2007 11:47 am Post subject:
almost there - notes don't stop |
thanks for your help on this.
things are working simultaneously now but notes don't end. my little test file plays the first three notes (on only) then seems to stop.
MidiOut mout;
0 => int device;
<<< "MIDI device:", mout.num(), " -> ", mout.name() >>>;
MidiMsg msg;
144 + (c - 1) => msg.data1;
p => msg.data2;
v => msg.data3;
mout.send(msg);
128 + (c - 1) => msg.data1;
p => msg.data2;
v => msg.data3;
<<<"on: ", this, p, v, d, c>>>;
me.yield();
d::ms => now;
me.yield();
mout.send(msg);
<<<"off: ", p, v, d, c>>>;
1::second => now;
spencer
Posted: Wed Feb 14, 2007 12:32 pm Post subject:
don,
Code: | public void playnote(int p, int v, int d, int c)
MidiMsg msg;
p => msg.data2;
v => msg.data3;
mout.send(msg);
p => msg.data2;
v => msg.data3;
me.yield();
d::ms => now;
me.yield(); | Should msg.data1 be set to a note off message here? Code: | mout.send(msg);
spencer |
dws
Posted: Wed Feb 14, 2007 12:48 pm Post subject:
i had the text output line in the wrong spot. here is a new version, functionally equivalent. same issue.
don
MidiMsg msg;
p => msg.data2;
v => msg.data3;
mout.send(msg);
me.yield();
d::ms => now;
me.yield();
0 => msg.data3;
mout.send(msg);
Kassen
Posted: Wed Feb 14, 2007 1:09 pm Post subject:
That's weird. That looks quite right to me, asuming it's sporked as a new shred and not just called as a function.
Chances are I missed something but the one thing I see to comment on is that you don't need to yield if you advance time right below it. Advancing time already yields *and* advances time in itself.
Advancing time time basically says "I don't need it anymore right now but I'd like to have the CPU back in this amount of time to do something again". Yielding expresses that it's now ok or (more likely) nesiscary for other shreds to execute but that you'd like to use the cpu after those shreds do their thing yet before any time (from a outside persective) passes again.
As a side note; I don't think I can find the "this" keyword in the manual and I'm not aware of it being documented anywhere? I think I'll add it to the "manual erata" WIKI page. _________________ Kassen |
spencer
Posted: Wed Feb 14, 2007 1:28 pm Post subject:
Uh I thought I just posted something but somehow it disappeared. whoops.
Anyways it looks to me like the playnote() function is sending two noteOn messages instead of a noteOn followed by a noteOff. Shouldnt there be a 0x80 + ( c - 1 ) => msg.data1; before the second mout.send(); to make the message a noteOff before sending it?
yeah i cant recall learning about "this" except via the mailing list, so that might be a good thing to have documented.
spencer |
dws
Posted: Wed Feb 14, 2007 1:44 pm Post subject:
you can send a note off using note on with velocity 0. they are equivalent.
there are a couple of references to this in the chuck manual. pages 31, 81. but no documentation of it's (or should i say this's) use.
don |
spencer
Posted: Wed Feb 14, 2007 1:49 pm Post subject:
oh yeah... whoops...
spencer |
Kassen
Posted: Wed Feb 14, 2007 2:28 pm Post subject:
dws wrote: | you can send a note off using note on with velocity 0. they are equivalent.
Indeed and this is very convenient if within the curent scope there's only one note at a time like here. I'm not sure what's wrong but as a overall structure for a implemention it looks quite sound to me right now.
I looked those up and you are right, but those references are a bit... erm.... thin (to say the least). It does make one wonder what "pure" does. The "pure" keyword gets mentioned on page 31 as well and that's the only reference to it. "const" is another mysterious word in that list.
More whoopses, but exciting ones, at least. _________________ Kassen |
