<on air> Various Artists June Solstice live streaming concert
Morph Group 8
Page 1 of 1 [4 Posts]
clydebarrow
PostPosted: Fri May 18, 2007 11:39 pm    Post subject:  Morph Group 8 Reply with quote  Mark this post and the followings unread
sorry if this a stupid question.
I just got my G2 37 with exp.
I have made a good trunaround but I didn't catch how to use and control morph group8 as I don't have extra wheels.
thanx for your answer
iPassenger
G2 patch files: 78
PostPosted: Fri May 18, 2007 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where it says G.Wh 2 underneath the dia in the editor, click this area once, it will chaneg to read "Knob". You can now assign this morph dial to any midi controller.
iP (Ross)
clydebarrow
PostPosted: Sat May 19, 2007 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for this zebra quick answer!
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sun May 20, 2007 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
In addition to asigning it to any midi controller, you can also directly assign the morph group to a front panel encoder:
1. click on the text below the Morph knob to change it to "knob", as mentioned above.
2. click on Tools, then Parameter Overview to open a large display showing all 120 front panel encoder assignments (Pages A through E, multiplied by #1 through #3, multiplied by the eight actual encoders).
3. Now click and HOLD on any dark gray box in this window and drag the mouse to any Morph knob (or any parameter on any module in the patch. Knob, switch, whatever, there are only a very few that can't be assigned) and release the mouse. You will see that the parameter or Morph group is now shown in the gray box and it will also display on the synth's front panel above the encoder. Turning this encoder will now control the Morph group or module parameter.
Dave Peck
