 Forum index » Clavia Nord Modular » Wish List
Enable the G2X features in the G2
Page 1 of 1 [15 Posts]
ersatzplanet
PostPosted: Sat May 19, 2007 2:15 pm    Post subject: Enable the G2X features in the G2
Subject description: Enable the G2X features in the G2
Since now the G2X is no longer in production, and I believe the PCBs to be the same, I would love to see the internal extra G2X mod wheel connectors enabled on the G2. Then I can add a joystick!
James Husted, Designer
Synthwerks, LLC
www.synthwerks.com
G2 patch files: 625
PostPosted: Sat May 19, 2007 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I've been thinking about this as well. The microcontroller used doesn't have a built in AtoD so it must be external. I count 6 sources on a standard G2,
Mod Wheel
Pitch Stick
Aftertouch
Pedal 1
Pedal 2
Volume knob (notice you cant change volume during patch load?)
Since multi channel AtoD would probably be 8 channel, the other two G2X wheels are probably connected to the last two channels.
Maybe the G2X has a small extra board with buffers for the extra modwheels.
Along with the pedal input, that would give three CV inputs.
Burp
G2 patch files: 7
PostPosted: Sun May 20, 2007 12:02 am    Post subject: Reply with quote  Mark this post and the followings unread
This would be very nice!
Maybe someone can look inside a G2X to see how the extra wheels are connected?
-Jan
if you don't know where you're going, you will allways arrive
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun May 20, 2007 12:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe someone can look inside a G2X to see how the extra wheels are connected? - Jan
Maybe this?
Wout
 Filesize:  142.05 KB
 Viewed:  14957 Time(s)
 Filesize:  242.27 KB
 Viewed:  11881 Time(s)
Burp
G2 patch files: 7
PostPosted: Sun May 20, 2007 12:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice Wout!
Seems like a littel extra pcb board with no extra electronics? (just a board to mount connectors?) Or am i missing something.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun May 20, 2007 1:45 am    Post subject: Reply with quote  Mark this post and the followings unread
There is no electronics on the board, only connections.
Connections are made on the PanelControlBoard, if open, at the top the PitchStick, (backside of the RotaryDial) and the large red 10 pins connector of the three Wheels.
Two important remarks! In my machine the ControlPanelBoard is hand labeled as G2X! It's also a preproduction model, so there can be differences!
All pots are, you can guess, 10K.
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun May 20, 2007 2:22 am    Post subject: Re: Enable the G2X features in the G2
Maybe I'm wrong...
There's a 10 pin connector to the three wheels.
Each pot has three connections, from which one is ground (?)
The three LED's will surely use the same cables.
I assume the blue strip in the connecting cable is ground.
Two strips for three wheels each makes seven.
One to power up the Led's makes eight...
Which pin is hot and which isn't?
Rob, Jan and I did it once to our Classic...
The buttons are to switch between normal knobs and joystick.
The left stick is spring powered, so it can be used as a sort of pitchstick, the right one has no spring and stays in it's position.
Hook function is essential!
Wout
 Filesize:  144.46 KB
 Viewed:  14935 Time(s)
Burp
G2 patch files: 7
PostPosted: Sun May 20, 2007 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
he Wout, if you're right then it shouldn't be that difficult!
Maybe some project in the future for me Wink
Your modded NM's are great idea, i always wanted to do that myself, but never actually did it... but made my own MIDI joystick controllers (doepfer pe..).
OT but maybe interesting:
On the picture my joystick controller, here controlling the micro, in a setup with two Kaosspads which i use a lot for live-sampling-sound-mangling.
It's an ongoing project, i want more buttons on it and at the end another front Wink
 Filesize:  144.55 KB
 Viewed:  11860 Time(s)
ersatzplanet
PostPosted: Sun May 20, 2007 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Up to recently I had a NM! also and popped it open and wired it up to have a joystick but never got the time or nerve to put the sheet metal on the drill press. I sold it to a gent who will be doing that and a bunch more to it. It is a lot simpler to add mods to the NM1 since all the main pots are just providing voltages. I once asked on this board about the connectors on the G2 and someone said the programming was different on it from the G2X so one could't just connect to the header. Different ROMs i would assume - hence the G2X sticker on the pcb. Hopefully it is something that can be changed with a flash/software update on the unit. If so I doubt it would be much of a hassle for Clavia to do it. I can't think of any other differences between the units other than the keyboard whose velocity curves etc may be much different from the G2's but that seems trivial. They could even sell the little PCB if they wanted to.
-James
Synthwerks, LLC
www.synthwerks.com
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun May 20, 2007 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know, the info is well hidden, but here is the article (three times due to a transport failure) about the modification. The pictures are manipulated, because they were unsharp...
http://nm-archives.electro-music.com/010_NordModular/014_Interesting_Threads/Folder/JoySticks/JoyStick.htm
Wout
jafre
PostPosted: Fri Nov 23, 2012 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
»»» Wout Blommers & James Husted
Hi guys,
Any devellopment on this subject?
"How to add in G2 one Doepfer JoyStick (Alps 2x10k), using those connectors where the G2X's extra wheels are connected"
It seems to me if firmware tests the hardware for detection at boot time,
it should be no problem to have 3 octave or 5 octave keyboard.
Firmware should deal with it identifying the correct one, right?
Unless they made a specific version of firmware for each model.
Wout: could you be so kind and send some detailed pictures of the insides of your G2X for comparation?
best regards,
Jaime
jafre
PostPosted: Fri Nov 23, 2012 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
The last post includes as well ian-s and Burp, of couse!
Copy/Paste seemed not to include you guys!
Sorry,
Jaime
jafre
PostPosted: Fri Feb 13, 2015 7:16 am    Post subject: Re: Enable the G2X features in the G2
Hi ersatzplanet
Did you manage to achieve this?
Do you have already enabled those 2 internal G2X connectors on the G2?
How far did you go on this? Is it doable?
best regards,
JaFre
ersatzplanet
PostPosted: Mon Jul 10, 2017 11:46 am    Post subject: Re: Enable the G2X features in the G2
jafre wrote:
Hi ersatzplanet
best regards,
JaFre
I have never heard a way to do this yet. I believe that it is all in the operating system and firmware and would have to be changed there. I just don't have the chops to go hacking that sort of stuff so I doubt that I will ever find a way. Really too bad since the connectors are there doing nothing.
Synthwerks, LLC
www.synthwerks.com
mtvic
PostPosted: Sat Jul 15, 2017 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Missing my G2X
