frequency shifter
Page 23 of 23 [572 Posts]
Goto page: Previous 1, 2, 3, ..., 21, 22, 23
jhaible
PostPosted: Sun Feb 13, 2011 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
zarko wrote:
Hello Jürgen.
in my modular i have some attenuators pots, so i decided to omit the 10K log input pot, but the problem is that i can't leave the input aux without a jack plug in, if i don't do that i dsitoy my ears and speakers Sad
I try to solder a 10k resitor between ground and aux in but it's the same problem. For the moment i disconnect the comon of the feedback mode switch.
Would you tell me if there is an other solution to resolve this problem
without add a pot on the front panel because there is no place left.
Thank you.
Have a nice day.
Regards Fred.
Make sure that the ccw end of the pot is grounded! - Then it should fully attenuate when in ccw position.
JH.
sduck
PostPosted: Sun Feb 13, 2011 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
The wiring diagram as provided has a feedback circuit in it. If you delete the pot you've deleted an essential part of the feedback circuit. So yes, you'll need to disconnect the wire from the center of the feedback switch, and just do your feedback outside of the module if you choose to. The feedback circuit isn't essential to the operation of the frequency shifter, but it is a nice added touch.
jhaible
PostPosted: Mon Feb 14, 2011 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, sduck. I completely missed the part about the missing pot, and concluded there must be a mis-wired pot.
So, yes, it's all clear: You *need* that pot for proper feedback operation. But you can have a nice FS entirely without feedback also. Just what sduck says.
JH.
zarko
PostPosted: Mon Feb 14, 2011 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks i gone try to add this pot on the front panel Wink
zarko
PostPosted: Tue Feb 15, 2011 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
I find a solution for not drilling an other hole pot.
i replace the two 100K lin mix pot ,by a dual 100K, and in the free place, the aux level pot.
Now the feedback mode is fully functional Wink
Great and fat sound, Thanks Jürgen Very Happy
slaughterhousesam
PostPosted: Sat May 07, 2011 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey guys, finished mine a few months back, took the extra time measuring components as well as i could and working with the xls, and seem to have come up trumps. carrier bleedthrough is for all intents and purposes, nil.
think this has new favourite module written all over it.
guess i just wanted to put a big hearty "thanks Jurgen" out there Smile
nice one mate, thanks for your trouble, and your time, in doing this and making it available Very Happy
subkontrabob
PostPosted: Tue Aug 09, 2011 6:41 am    Post subject: a few questions..... Reply with quote  Mark this post and the followings unread
I'm currently finishing my FS-1A build. I'm going to put it in a 19" enclosure, and add a few extra connectors and goodies.
I have a few questions:
1. What is the function of the dual LED/two LEDs marked "F_LED"? Is it the same dual LED Jürgen referred to as "Rate"? Hard to place them without knowing their purpose.
2. I want to make the quadrature triangle signals available at the front panel like lexvortex mentioned in a previous post. Can I do that by simply connecting jacks to the SigSin and SigCos outputs on board 1?
3. Same question for the SumOut and Diff Out: Can i just connect a jack in parallel to the rest of the stuff?
4. I want to add external input jacks for the buffer inputs. I've been thinking about adding a pot to be able to mix between the external input jack and the dry/wet pot. Would that make sense? I guess I would have to use shielded wire for the connection?
That's all I can think of at the moment. The front panel is going to be stuffed!! Twisted Evil
best regards,
Bob
mph
PostPosted: Mon Aug 22, 2011 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi
I'm finishing to populate the boards, and I'm not sure about the 2SA733's position. Should I use the "real" pcb silkscreen, or this document:
http://www.jhaible.de/fs1a/fs1a_overlay_main_board.pdf
Question
On my pcb the trannies should be in the opposite side as on the pdf.
Thanks a lot for your help.
jhaible
PostPosted: Mon Aug 22, 2011 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
mph wrote:
Hi
Question
The PCB silkscreen is right. (The emitters, pins 1, are connected together.)
JH.
zthee
PostPosted: Mon Oct 10, 2011 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Would it be possible to power 2 FS1A from just one on board PSU?
jhaible
PostPosted: Mon Oct 10, 2011 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. But only if you have big enough heat sinks.
The location of the power regulators is - admittedly - a bit unfortunate to attach good heat sinks to them, though. But if you find a goot thermal + mechanical solution for getting the heatt off the voltage regulators, it will work.
JH.
zthee
PostPosted: Wed Oct 12, 2011 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
LED-man
PostPosted: Tue Sep 03, 2013 12:57 pm    Post subject: issue Reply with quote  Mark this post and the followings unread
Hello,
i hope to find some help here.
i´m building the fs1a.
today i tried to calibrate the device but i got in calibration process 1 and 2
2 waveforms with same amplitude but they DONT are 90degrees different in phase.
any idea ?
i tested:
U8, pin 7: triangle. yes was a triangle
U9, pin 7: triangle - yes yes is a triangle
U9, pin 1: square wave - yes
 Filesize:  2.33 MB
 Viewed:  470 Time(s)
LED-man
PostPosted: Wed Sep 04, 2013 2:23 pm    Post subject: Re: issue Reply with quote  Mark this post and the followings unread
LED-man wrote:
Hello,
any idea ?
i tested:
Failure gone.
I never tried before both channels together in my Oscilloscope,
Trigger Setting wrong.
Further i Must change R51 to 330ohm.
51k like described here is to much.
Original Layout Shows 430ohm.
The Jumper Setting near u10 must close to the right side.
Must say its a very
The Bad Producer
PostPosted: Fri Sep 06, 2013 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey LED-man, just saw this, glad you got it sorted, but now I'm wondering what you were going to say?! Very Happy
Must say its a very...
LED-man
PostPosted: Fri Sep 06, 2013 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Very good attention here.
Would say, its a fantastic device.
I post here a video later.
Have to solder few jacks and finish the separate psu connection.
roglok
PostPosted: Fri Sep 06, 2013 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
aww. i'm so jealous. would love to build one myself, but alas - no PCB for sale anywhere...
LED-man
PostPosted: Fri Sep 06, 2013 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I have tried to contact miss haible, but i'm unable to find a telephone number or valid email adress.
User harryw has contacted me last year, never heard again.
Im frustrated because he told me juergen leave 2000 pcbs !
WE must produce our own pcbs.
We need planning here.
PostPosted: Fri Sep 06, 2013 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
The PCB situation as I understand it is that the estate is a mess, because there was paperwork unfinished when Juergen died, and it is unclear whether his estate goes in any part to his wife (they were in process of divorcing) or all to his children. The German authorities have not put any evident effort into resolving this and so it is still far up in the air.
Many people do not wish to make PCBs even though they are capable, because they want Juergen's stock, which are hard assets of his estate, to retain its value, and if everyone can get someone else's PCB of the same design then what reason is it for the originals to have much value (aside from collectors)? The point being that value should benefit his heirs, and everyone wants that to be the case.
Knobhell proposed a middle way -- go ahead and produce some new PCBs with the understanding that a donation from each would go to a fund for Juergen's children or heirs++ -- and was roundly shot down.
I don't think most would object to people producing PCBs for their own personal use, but I expect any attempt to sell them, even just to help cover base costs, would raise a lot of negative attention.
++ Note this is my paraphrase of what he proposed, so if it is not accurate in any way, that is on me. But the discussion of these things is in the public forums here and on Muffwiggler, so you can verify my account.
LED-man
PostPosted: Fri Sep 06, 2013 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Has anybody here contacted Birgit haible in Last 12months ?
I think no !
I cant find informations here and in German Forums.
WE are the DIY Community and potentiell customers.
So lets start here, either we get contact and a clear Situation from Birgit or we start a own Production.(with % to Birgits Kids)
I think its in Jürgens interest to deploy/produce the Part of his genial livework.
its Same like Bob Moog, Paul S and other Great Technican.
His work need recognition here and yet.. Not only in history
Http://www.DSL-man.de. - Share your DIY Projects
KnobHell
PostPosted: Sun Sep 29, 2013 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Not the freqeency shifter, but positive movement none the less. I predicted this would happen and got pissed on pretty heavily.
Living vco project.
http://www.muffwiggler.com/forum/topic-93892.html
The market always takes care of itself. I'd expect to see more designs come out well before the German government settles his estate.
LED-man
PostPosted: Mon Mar 03, 2014 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
finished mine in 2013
works as designed
if someone need infos :
http://www.dsl-man.de/pages/viewpage.action?pageId=1867791
