Yamaha A3000 and SCSI adapters
Gothboy
PostPosted: Tue Aug 21, 2007 8:26 am    Post subject: Yamaha A3000 and SCSI adapters Reply with quote  Mark this post and the followings unread
I have a Yamaha A3000 sampler which uses a 50-pin connector. I'd like to use a 25-pin zip drive with it for backup so I would need to buy a 50-pin male to 25-pin female SCSI adapter for it. Anyone know if adapters work with samplers like this?
Apple Mac Pro 2.66 GHz. Intel Xeon Quad core
13 GB
10.7.5 Digi 002R
Novation SL49/Remote Zero
Automap 4
Mopho Desktop, Nord Lead 2, Roland System 1, Novation Nova, Nord Micromoular, Korg Radias, Roland D-50, M-audio Venom, Alesis QS6, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Roland D2, Emu Proteus 1, Arturia Beatstep and SparkLE
"We are the music makers and we are the dreamers of dreams"
Dymaxion Vehicle Music at www.dymaxionvehicle.com/
EdisonRex
Audio files: 171
PostPosted: Tue Aug 21, 2007 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Typically, yes. Make sure you terminate the SCSI bus correctly.
Garret: It's so retro.
Gothboy
PostPosted: Thu Aug 23, 2007 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, well that's good to hear. I have some Roland VS recorders and I'd heard those didn't accept adapters so I wasn't sure if it was the same with a SCSI sampler. Cool
13 GB
10.7.5 Digi 002R
Automap 4
EdisonRex
Audio files: 171
PostPosted: Thu Aug 23, 2007 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think with the Rolands it's the usual Roland screwed up implementation of SCSI and lack of support for most SCSI devices except those they could charge an arm and a leg for. Some of the Rolands worked pretty well with 3rd party stuff, some didn't. The S-50 was a good one, but some of the others were not so helpful.
My old Ensoniq ASR-10 sampler had no problems with most of the SCSI-1 disks I had lying around at the time. And my Akai S-6000 has absolutely no problem talking to pretty much any SCSI device.
The Yamahas should work, but keep it simple. If it doesn't work, report back with that it's doing, a lot of problems usually boil down to improper termination. Newer SCSI kit will probably talk, slowly, on SCSI-1, but some kit, like tape drives and other single ended stuff, gets very cranky indeed.
Gothboy
PostPosted: Sun Aug 26, 2007 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info. I'll report back later when I get the adapter. Wink
13 GB
10.7.5 Digi 002R
Automap 4
