Schulte Compact A Phasing
Page 24 of 27 [660 Posts]
Goto page: Previous 1, 2, 3, ..., 22, 23, 24, 25, 26, 27 Next
JoeMorris
PostPosted: Tue Jul 07, 2009 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Would that not blow the fuse?
jhaible
PostPosted: Tue Jul 07, 2009 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not necessarily.
Fuses are mainly in there to minimize the risk of a circuit literally going up in flames - there is no guarantee that they are fast enough to protect a semiconductor.
But we're talking in general here - I don't say you have blown up anything - how could I know from a distance?
You will only find out bydoing the usual test routine: check supply voltages at every IC, then trace signal from input of the circuit to outputs thru every stage.
JH.
JoeMorris
PostPosted: Wed Jul 08, 2009 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah I'm really sorry I must come across like a total pain with all these questions!
I'd like to reiterate I'm certainly not expecting you to fix it for me I guess I'm just hoping for some ideas when I throw this out there.
I've got my multimeter back but there seems to be no power to any of the chips.....
jhaible
PostPosted: Wed Jul 08, 2009 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, then you should check the path of the AC (transformer secondary winding(s) ) into the circuit: fuses, rectifiers, voltage regulators.
JH.
JoeMorris
PostPosted: Thu Jul 09, 2009 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Strangely enough, though the fuse didnt look blown, replacing it seemed to do the trick. Bizarre. This phaser also sounds great JH, thanks for four amazing projects so far.
Only one little niggle, though it's not a catastrophe: no sound comes through in bypass mode...
Better than the otehr way round, though, eh! I'll have a look again at some point, but for now I'm gonna have a breather from DIYT for a couple of months and actually make some music...
jhaible
PostPosted: Fri Jul 10, 2009 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad to hear it works!
Can't bee hard to trace that fault - there's aonly a couple of components in the signal path, when the relay is in the bypass position.
JH.
Luka
PostPosted: Sun Aug 02, 2009 1:27 am    Post subject: Reply with quote  Mark this post and the followings unread
hi
im finishing up populating this pcb but having troubles getting 9k1 resistors
would combining 2 4k7s in series be ok (9k4) ?
problemchild
melbourne australia
jhaible
PostPosted: Sun Aug 02, 2009 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Luka wrote:
hi
No.
Better use a parallel connection:
10k || 100k = 9k09
(As a rule of thumb, if you don't have an E24 value, use the next bigger E12 value and connect 10 * that value in parallel.)
JH.
Luka
PostPosted: Sun Aug 02, 2009 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
problemchild
melbourne australia
Luka
PostPosted: Sun Aug 16, 2009 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
ok well im about to finally wire this baby up
is there need to isolate the lamps from each other if they are within an enclosure. i only really ask this as my panel mount lamp is not enclosed and the bulb is close to the other lamps / ldrs
problemchild
melbourne australia
jhaible
PostPosted: Sun Aug 16, 2009 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful!
What's the 5th knob?
FP lamp goes on when LDR lamps go off, so you must put some shade between them.
JH.
Luka
PostPosted: Sun Aug 16, 2009 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks will do
extra knob is just signal input
problemchild
melbourne australia
The Bad Producer
PostPosted: Mon Aug 17, 2009 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
Whilst building one of these phaser into a rack recently, I was stumped by what to cover the lamps with as the case was not totally light-proof, then at work I found some neon sign caps in black silicon. I didn't want to use tape, as it might make a mess, and though I do have heatproof tape at work too, it has aluminium in it, and I was worried about creating shorts... So if you can find these (maybe from a local neon sign supplier?) they are ideal, as they are also heatproof, and just slip on and off as needed (though they wouldn't 'fall' off when moving...)
I said it before, and I'll say it again - nice Phaser Luka!
Charlie
 Filesize:  2.59 MB
 Viewed:  301 Time(s)
jhaible
PostPosted: Tue Sep 01, 2009 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Boards are sold out !
JH.
The Bad Producer
PostPosted: Wed Sep 16, 2009 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello everyone, JH,
I finished a Krautrock Phaser some time ago, but I've just realised that I may have installed the wrong relay...
Instead of the 12V relay (Finder Relay 30.229 12V-360R )
I've installed a 5V relay (Finder Relay 30.22S 5V )
The circuit works with no problems that I have seen. Will this cause problems in the future?
Also the 12V one I should have used, is that the correct type (30.229 12V-60R), or would Finder Relay 30.22 12V work - I'm looking at this page at Banzai:
http://www.banzaieffects.com/Relays-c-276.html
Sorry for so many questions - this mistake has made me lose confidence slightly!
Charlie
jhaible
PostPosted: Wed Sep 16, 2009 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
The Bad Producer wrote:
Hello everyone, JH,
Charlie
It may become hot, or the resistor that's connected in series with the relay will.
Just re-calculate the resistor value.
Get the nominal current of your 5V relay: Inom
The resistor must take 15V - 5V = 10V
i.e. series resistor value Rser = 10V / Inom
Power in the resistor: P = 10V * Inom
Choose Resistor Wattage at least 3 times that calculated power.
JH.
The Bad Producer
PostPosted: Wed Sep 16, 2009 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Jurgen,
So, I've looked at the Datasheet for the relay, I've found the rated coil consumption (I guess that is Inom?) it is 40mA,
So that means a 1.2W resistor, I think (10*0.004 = 0.04, *3=1.2W
Or, more than likely, I've got the wrong end of the stick!
Charlie
jhaible
PostPosted: Wed Sep 16, 2009 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Jurgen,
Charlie
Well yes, the closer the relay voltage is to the PSU voltage, the better is the efficency of the whole thing ... that's the reason why I chose a 12V relay (15V is not so common, and 12V is close to 15V).
Lower Relay voltage means higher current (for the same type of relay), *and* higher voltage across the series resistor, so the power consumption of that resistor is increased dramatically.
JH.
The Bad Producer
PostPosted: Thu Sep 17, 2009 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks JH,
I knew it was wrong, and I shall have to replace the part, but now I know why it is wrong, so, again...
Thank you Very Happy
Charlie
henrikgo
PostPosted: Sat Sep 26, 2009 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Will there be another run of PCBs?
jhaible
PostPosted: Sat Sep 26, 2009 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hard to tell. If there is enough demand - yes.
Orders for this came trickling in, until suddenly I noticed the last board was gone - I don't even have a single spare for myself.
If anybody is interested in a re-run, send me an email (no PM, please). When I have enough, in a few months or so, I'll do a re-run.
JH.
b-funk
PostPosted: Tue Nov 17, 2009 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Just in case someone is curious how the original Schulte was designed... Wink
PS: I´m back. More soon...
 Filesize:  95.08 KB
 Viewed:  571 Time(s)
Luka
PostPosted: Fri Dec 11, 2009 9:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
can the mc1458 in the lfo be subbed for tl072?
problemchild
melbourne australia
jhaible
PostPosted: Sat Dec 12, 2009 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
No. Never use a 072 in a circuit where the input can swing near the supply rails, or where its output can see a heavy capacitve load.
JH.
Luka
PostPosted: Sat Dec 12, 2009 1:11 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks J
probably why it isnt working right now
any other decent substitutions?
i ordered 1458s and i got some 16pin IC, no other 1458s from local vendors.
i noticed mention of 4558s earlier in the thread, i have some here and might try, but if you can think of anything else im all ears
problemchild
melbourne australia
