Funky40
G2 patch files: 5
Posted: Sat Sep 15, 2007 11:36 am Post subject:
| Foniks Website wrote: | | The 2nd CV in (FM) provides an attenuverter (thank you Funky40 for this idea. it's allways good to listen to a hardcore patchers advice) |
uhhh, i'm not a Hardcore Patcher, i'm just into groove generating.
and to make good grooves with 8 repeating steps from a Seqeunzer,
one need something to vary and to twiddle
I'm really allways beginner......
btw.@ fonik:
thanks fonik for adding the Inverter.
Please make the Inverter that way available that one can choose how to wire it up.
I prefer for example to wire it to a switch which i then also can use as a mute switch.
serenadi has made his Polivoks Filter like this. ----> just perfect
Mosc mentioned the Idea that i can use a switch for the Inverter also for muting the CV inputs in a thread here at EM many moons ago.
Hey, and i build now all my Filters like this.
and i won't have any Filters any more without that Feature.
Muting CV Inputs is a veeeeeery useful Feature.
Thanks @ Mosc for that tip !  |
Peake
Joined: Jun 29, 2007 Posts: 1095 Location: Loss Angeles
Posted: Sat Sep 15, 2007 1:14 pm Post subject:
I've never heard the Wasp filter. Does anyone have a link to audio please?
I really like the added distortion. Everyone is going to throw their individual ideas at you, so pick and choose (and choose the above idea of switching one channel of CV in and out- great idea!). Would it be possible to have another distortion mode, to be able to switch it in prior to the filter, to distort just the input, as well as the given option of distorting the output?
No problem if not, just throwing ideas on the wall to see if any are worthy of sticking. Good work! |
Etaoin
Joined: Jun 30, 2005 Posts: 760 Location: Utrecht, NL
Posted: Wed Dec 12, 2007 4:18 am Post subject:
Fonik, does it work out alright with the 4069? I remember reading somewhere that Seb Francis said that when running in linear mode, you should not use more than three gates from the same chip or they would run too hot. That's the reason he split the two distortions in his Box-O-Trix over two 4069's and left three gates unused in each IC. _________________ http://www.casia.org/modular/ |
Joined: May 16, 2005 Posts: 8902 Location: Birmingham, England, UK
Posted: Wed Dec 12, 2007 4:29 am Post subject:
| Peake wrote: | I've never heard the Wasp filter. Does anyone have a link to audio please?
Try listening to The Stranglers some time. Dave Greenfield had 3 Wasps in his keyboard rig, and the synth parts on the LP "meninblack" was all Wasp  _________________ ACHTUNG!
Posted: Wed Dec 12, 2007 4:45 am Post subject:
| Etaoin wrote: | | Fonik, does it work out alright with the 4069? I remember reading somewhere that Seb Francis said that when running in linear mode, you should not use more than three gates from the same chip or they would run too hot. That's the reason he split the two distortions in his Box-O-Trix over two 4069's and left three gates unused in each IC. |
i know, etaoin. i let this module work for more than an hour these days. the IC gets really hot: i measured the 4069 at approx 65°C, the same result jürgen got with his clone using 5 of 6 gates.
according to the datasheet the 4069 is working up to 120°C IIRC. anyways you should not touch it with your finger! _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
6079smith
Joined: Jan 18, 2007 Posts: 95 Location: Mark of the Dane
Posted: Wed Dec 12, 2007 7:14 am Post subject:
Hi fonik, I built a Wasp VCF from your original design and I was well pleased with it. The only drawback was a slightly lower output than, well, other modules I have. I never thought that the 4069 got particularly hot, but I don't think I tried touching it... (that reminds me to start another thread). I noticed that also about the CV control not being wonderful. But it works, and sounds pretty unique. Nice work, and thanks for it.
| v-un-v wrote: | | Try listening to The Stranglers some time. Dave Greenfield had 3 Wasps in his keyboard rig, and the synth parts on the LP "meninblack" was all Wasp |
There's a coincidence, I was listening to "Black and White" this morning... |
Posted: Wed Dec 12, 2007 8:38 am Post subject:
| 6079smith wrote: | Hi fonik, I built a Wasp VCF from your original design and I was well pleased with it. The only drawback was a slightly lower output than, well, other modules I have. I never thought that the 4069 got particularly hot, but I don't think I tried touching it... (that reminds me to start another thread). I noticed that also about the CV control not being wonderful. But it works, and sounds pretty unique. Nice work, and thanks for it.
the layout from my site is a PCB layout for Jürgen Haibles Wasp clone! i just made a layout for press'n'peel blue, the circuit design is Jürgens! so all honor goes to him! _________________
fonitronik at
6079smith
Posted: Wed Dec 12, 2007 1:01 pm Post subject:
| fonik wrote: | | the layout from my site is a PCB layout for Jürgen Haibles Wasp clone! i just made a layout for press'n'peel blue, the circuit design is Jürgens! so all honor goes to him! |
Well, I tip my hat in Jürgen's direction as well! |
crashlander42
Joined: Oct 21, 2006 Posts: 276 Location: Orlando, FL (US)
Posted: Wed Dec 12, 2007 9:29 pm Post subject:
Sounds great and looks great!
The Wasp filter that I built from the layout on your site is one of my favorite filters in my setup right now.
Are you going to be doing a run of boards, or releasing a press n peel layout?
I am eagerly anticipating either.  _________________ When they plug me in the lights go down in Hong Kong.
http://www.myspace.com/isaciongun
http://www.youtube.com/user/Crashlander42
My DIY stuff Flickr |
The Alison Project
Peake
Posted: Wed Dec 12, 2007 11:16 pm Post subject:
| v-un-v wrote: | | Peake wrote: | I've never heard the Wasp filter. Does anyone have a link to audio please?
Oh, then I -have- heard the Wasp before!
Thanks. |
bugbrand
Joined: Nov 27, 2005 Posts: 842 Location: Bristol, UK
Posted: Thu Jan 31, 2008 3:50 pm Post subject:
Hey, I've been thinking on Wasps too recently... So have been interested to read through this thread and dredge it back up again.
I've got a couple of questions / ideas..
- Firstly - the original ran with a 5v single supply for the filter and Jurgen's schem had been marked like that. Matthias, did you try with 5v and 12v? I was wondering whether this'd make much difference other than headroom / where overdrive sets in.. I really want to test these circuits out and see how they respond to different input levels.
- also, I see you've got a switch to select different diodes - did you notice much difference? Hmm, different coloured LEDs have different sounds too, right? (or is it so subtle you really won't notice?)
* my main fresh idea has been to have a post filter mixer stage. I've seen something a bit similar by Craig Anderton before (in the EPFM book) - you get a three channel mixer for HP, BP, LP -- nice sound shaping, no?! This could also help bring the level back up again after the filter (especially if running at 5v). Now, I also wondered about the phase of each output - are all three in phase (I *think* they are?!)? I'd thought to use the left-over three 4069 gates as inverters for each output instead of employing them for overdrive - you'd then get a phase switch for each mix input and I'd think you'd be able to get some great tone shaping possibilities out.. Hmm, gotta try this out!
[Adding an inverter stage would, I think, just be a case of tapping the original response output with a 100k resistor, followed by a DC blocking cap (seeing that from Jurgen's Wasp schem) and then the inverter gate with another 100k resistor strung across as feedback.. ]
Any thoughts or comments?
Matthias - you said the CV response wasn't working so good on your prototype? I'm sure a number of typical lm13700 driving circuits could fit the bill perhaps?
Oh yeah, apparently the dirty noise band Whitehouse are characterised by the sound of the Wasp.... _________________ http://www.bugbrand.co.uk
http://www.bugbrand.blogspot.com |
numbernone
Joined: Aug 16, 2006 Posts: 476 Location: new york city
Posted: Thu Jan 31, 2008 7:50 pm Post subject:
| Early Whitehouse is entirely Wasp driven. Great stuff. |
Posted: Sun Feb 03, 2008 4:17 am Post subject:
| bugbrand wrote: | Hey, I've been thinking on Wasps too recently... So have been interested to read through this thread and dredge it back up again.
- Firstly - the original ran with a 5v single supply for the filter and Jurgen's schem had been marked like that. Matthias, did you try with 5v and 12v? I was wondering whether this'd make much difference other than headroom / where overdrive sets in.. I really want to test these circuits out and see how they respond to different input levels. |
my version needs a bipolar supply for the blend circuit anyway. i could try 12V though (i have always an adaptor on hand here).
| Quote: | | - also, I see you've got a switch to select different diodes - did you notice much difference? Hmm, different coloured LEDs have different sounds too, right? (or is it so subtle you really won't notice?) |
different colored LEDs have different voltage drop values so the clipping of the filter will be different. the difference between red and yellow is only subtle, green makes a big difference. this all applies to resonance only.
| Quote: | | * my main fresh idea has been to have a post filter mixer stage. I've seen something a bit similar by Craig Anderton before (in the EPFM book) - you get a three channel mixer for HP, BP, LP -- nice sound shaping, no?! This could also help bring the level back up again after the filter (especially if running at 5v). Now, I also wondered about the phase of each output - are all three in phase (I *think* they are?!)? I'd thought to use the left-over three 4069 gates as inverters for each output instead of employing them for overdrive - you'd then get a phase switch for each mix input and I'd think you'd be able to get some great tone shaping possibilities out.. Hmm, gotta try this out! |
do try this. i would be interested in the results, too.
| Quote: | | Matthias - you said the CV response wasn't working so good on your prototype? I'm sure a number of typical lm13700 driving circuits could fit the bill perhaps? |
i already changed some values in the CV circuit and i am almost satisfied. as soon as i find the time i will optimize them.
the PCB layout is actually tested and ready for production. i just wanted to upload some samples before asking for advance orders/interest. however i don't have much time these days, my wife and me bought/built a house and will move in march (you know how much work this is, i guess ). _________________
fonitronik at
Etaoin
Posted: Sun Feb 03, 2008 4:28 am Post subject:
| fonik wrote: | | the PCB layout is actually tested and ready for production. i just wanted to upload some samples before asking for advance orders/interest. |
No rush, we already have wogglebugs, Schulte compact phasers, Ray Wilson AR's and Buchla boards this month. There's only so much DIY one can do (and pay for ) _________________ http://www.casia.org/modular/ |
Posted: Sun Feb 03, 2008 4:48 am Post subject:
| Etaoin wrote: | No rush, we already have wogglebugs, Schulte compact phasers, Ray Wilson AR's and Buchla boards this month. There's only so much DIY one can do (and pay for ) |
that's the way i feel, too. and i still have to do half of the wiring of my klee! _________________
fonitronik at
bugbrand
Posted: Sun Feb 03, 2008 6:55 am Post subject:
One more thing I was wondering on was the driving of the Ca3080 (or LM13700 as I'm going to try) -- hmm, I don't really understand the internal workings so maybe I'm already falling down..
But, if we're powering the OTA with a single supply (0-5v or 0-12v or 0-15v) then can we still drive it with a standard exponential converter run off a bipolar supply? Or would be have to add in some sort of offset control? Uhh, I'm showing my lack of actual understanding here probably!
Oh well, this is on my more imminent ToDo list! I've sketched out plans for the main filter part with inverters for the outputs.....
I don't know what you'd think, Matthias, but I may be up for doing some PCBs at some point too... Dunno, I've also got a lot to juggle at the moment (don't we all!) _________________ http://www.bugbrand.co.uk
Fernando
Joined: Dec 30, 2006 Posts: 207 Location: Barcelona, Spain
Posted: Tue Mar 11, 2008 1:05 pm Post subject:
Hi all. Been offline for a while.
I like the Wasp very much. I never built the JH version but I played a real Wasp around '80. I like it.
I just wanted to add that the 3080 might be a better option since it can reach to a nice soft distortion when pushed a bit. I know that 13700 is easier to buy but I'd use the 3080 better... just my opinion
fernando |
widdly
Posted: Tue Mar 11, 2008 3:26 pm Post subject:
Hey fonik,
I noticed in another thread you posted some samples of your wasp filter self oscilllating. I built a version straight of JH's schematic into an old expression pedal but mine never self-oscillated. What's the trick?
http://electro-music.com/forum/topic-22235.html&postorder=asc&start=50 Last edited by widdly on Thu Aug 05, 2010 10:19 pm; edited 1 time in total |
jhaible
Posted: Tue Mar 11, 2008 3:30 pm Post subject:
| widdly wrote: | Hey fonik,
http://electro-music.com/forum/topic-22235-50.html |
The capacitance of a long cable at the output!
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
widdly
Posted: Tue Mar 11, 2008 3:45 pm Post subject:
I need an output buffer? Last edited by widdly on Thu Aug 05, 2010 10:19 pm; edited 1 time in total |
jhaible
Posted: Tue Mar 11, 2008 11:55 pm Post subject:
| widdly wrote: | | I need an output buffer? |
I enjoy the capability of self oscillation on my Wasp filter clone.
It's not like opamps, which often oscillate in the MHz range when loaded with a cable, after all - in the Wasp, I get oscillation near the corner frequency of the filter, and only when the resonance is all turned up. Quite nice - as if it were designed that way.
widdly
Posted: Wed Mar 12, 2008 1:24 am Post subject:
I have re-read your Wasp Clone page and I understand what you meant by "capacitance of a long cable at the output". I will have to try this out. From building guitar effects, I'm used to long cables causing problems not fixing.  Last edited by widdly on Thu Aug 05, 2010 10:19 pm; edited 1 time in total |
