sallyjackmei
Posted: Tue Oct 16, 2007 6:10 am Post subject:
Searchin POWER SUPPLY in FRANCE for Wretch Metasonix!!!! |
Hello
i've bought Metasonx Wretch but without Pwer Supply.
Can you help me to find THE good Power Supply in 220V ?
i'm living in France !!!
THank you... |
Audio files: 278
Posted: Tue Oct 16, 2007 12:26 pm Post subject:
sallyjackmei
Does it not say on the device how many volts & Amps it wants? _________________ Jan
sallyjackmei
Posted: Tue Oct 16, 2007 12:36 pm Post subject:
Here is the reference of the original AC 110v:
Pri: 120 VAC 60 Hz 0.48 A
Sec: 12 VAC 40 VA
Here is what's written back of the Wretch s1000:
12 volts AC ONLY
Power consumption 3.0 amps at 12 Vac...
It doesn't make sens to me, so i ask some help!!!! |
Audio files: 278
Posted: Tue Oct 16, 2007 1:15 pm Post subject:
Ah OK, just find an AC supply (wall wart) rated at 220 or 230 V with the same output specs (12 V / 40 VA, or 12 V / 3 A). If you have a local electronics store they'll be able to help you if you show 'm the metasonix and the numbers you posted here. When you want to find one on the internet it can be a bit hard to see if the 12 V plug will fit the Wretch. _________________ Jan
sallyjackmei
Posted: Tue Oct 16, 2007 1:21 pm Post subject:
OK !
Thank you so much !
i will see tomorrow !
Good Night and thank you for your help |
Audio files: 278
Posted: Tue Oct 16, 2007 1:22 pm Post subject:
Good luck tomorrow ! _________________ Jan
EdisonRex
Joined: Mar 07, 2007 Posts: 4579 Location: London, UK
Audio files: 172
Posted: Tue Oct 16, 2007 2:07 pm Post subject:
Actually, to clear this up, I had a topic here on Metasonix which is what SallyJack found via Google. After some PMs, we've settled on the power supply I used, which is a Block HIT-60, primary 220-240VAC, secondary 11.5-12VAC, 60VA. A bit overrated but that's good in this case.
Coincidentally, Sally's Wretch SN is 00025. Mine is 00024. It's a small world here.
SallyJack's power supply that blew is exactly the same one I had, which is still on my desk, melted as a memento to Americans not understanding power in Europe. This from an American in Europe, so I feel qualified to comment.
For the record, my post in this forum about my power supply problems with my then-new Wretch was my first post on electro-music.com. _________________ Garret: It's so retro.
Home,My Studio,and another view |
Audio files: 278
Posted: Tue Oct 16, 2007 2:14 pm Post subject:
l'histoire se répète - sort of _________________ Jan
sallyjackmei
Posted: Tue Oct 16, 2007 2:32 pm Post subject:
GOOD FRENCH my dear |
Audio files: 278
Posted: Tue Oct 16, 2007 2:36 pm Post subject:
But please don't ask me to produce more french _________________ Jan
sallyjackmei
Posted: Tue Oct 16, 2007 2:42 pm Post subject:
OK comme tu veux !
Dommage pour une fois qu"'on peut parler un peu français dans ces forums |
EdisonRex
Audio files: 172
Posted: Tue Oct 16, 2007 2:50 pm Post subject:
sallyjackmei wrote: | OK comme tu veux !
en peu. Seulement en peu, s'il vous plait.
A very many of us are very bad at French, and bad English is still better than bad French. _________________ Garret: It's so retro.
Audio files: 278
Posted: Tue Oct 16, 2007 2:54 pm Post subject:
Which reminds me .. when I was a kid on holiday in a french speaking part of europe ... my mother had explained with hands and feet that she couldn't speak french, and then the man said : c'est dommage, pour moi et pour vous - we got that _________________ Jan
sallyjackmei
Posted: Tue Oct 16, 2007 2:55 pm Post subject:
ahahah lol |
sallyjackmei
Posted: Wed Oct 17, 2007 10:06 am Post subject:
i don't find other Power Supply...
Can You tell me if this one is OK for my device?
Audio files: 278
Posted: Wed Oct 17, 2007 10:14 am Post subject:
That one should be fine.
But you'll have to do some wiring yourself _________________ Jan
metasonix
Posted: Wed Oct 17, 2007 1:10 pm Post subject:
sallyjackmei :
I'm sorry your USA power adapter melted. It's a real danger buying them from our US dealers or on the used market. Most adapters sold in the US won't work properly on 50Hz mains--they get very hot. And there's no way to tell if a given transformer will work on 50 hz or not.
I have added some suggestions for power supplies for our products if used in Europe, to our website:
http://metasonix.com/forums.html?option=com_content&task=view&id=22&Itemid=39
The transformers intended for powering 12v halogen lighting (like the one whose photo you posted above) ARE OK to use with our products. You need to take the cable off the USA adapter and attach it to the transformer's secondary or output terminals. |
sallyjackmei
Posted: Wed Oct 17, 2007 1:55 pm Post subject:
Thank You...
My French Dealer don't tell me thoses important informations!
Ok now, it works... i just try to work Metasonix with my MidKeyb and Kenton Solo mkII !!!
Do you know if a specific cable os required for CV GAte?
Audio cable? mono?...
What a mess to hear some sounds |
Audio files: 278
Posted: Wed Oct 17, 2007 2:05 pm Post subject:
sallyjackmei wrote: | What a mess to hear some sounds |
Well, it works _________________ Jan
sallyjackmei
Posted: Wed Oct 17, 2007 2:14 pm Post subject:
i try .... i try...
But can't use my Midi Keyb at this time...
Maybe a cable problem.don't find which cable i have to use with my Kenton Solo .
Hard to understand all sentences when you are french !!!!!
Technicals terms are hard to understand!
Thank you again for your help! |
sallyjackmei
Posted: Thu Nov 08, 2007 3:00 am Post subject:
OK !!!!!!
My Dealer made me a Big Supply.
Now my Metasonix Works!!!! Yeah!!!!!
BUT, i still don't succeed in playing keys with my Kenton Solo.
My Keyboard makes a sound but always the same key.. no pitch!!!!! |
EdisonRex
Audio files: 172
Posted: Thu Nov 08, 2007 7:58 am Post subject:
Oh, that is great to hear. Glad it makes noise now. _________________ Garret: It's so retro.
Kent
Joined: Mar 31, 2008 Posts: 53 Location: All over Europe & elsewhere (Mostly Paris)
Posted: Fri Nov 21, 2008 10:34 am Post subject:
metasonix wrote: | sallyjackmei :
I'd like to add that Conrad Electronics does have international webpages. I was slogging through the German page and when I entered my ship-to address, it asked me to order from the French page instead. Way cooler (for me as I read French far better than Deutsch!) & the price for the transformer was much cheaper as well. Rockin!
It is probably easiest to start here: http://www.conrad.com/ |
