 Forum index » Clavia Nord Modular » g2ools utilities
VOCODER PATCHES
Page 1 of 1 [6 Posts]
Reversible
PostPosted: Fri Nov 23, 2007 5:24 am    Post subject: VOCODER PATCHES
Subject description: Classic-Saw-Phase-Pulse-Simple-Lead >>>> Vocoder
Hello, I am looking for this vocoder patches, the originals are G1 patches, I need it converted to G2:
Classic Vocoder
Saw Vocoder
Phase Vocoder
Pulse Vocoder
Simple Vocoder
Vocoder Lead
Somebody made this work in the past but the .zip files are erased today.
Check this topic please:
http://electro-music.com/forum/topic-15405-250.html
If somebody can help me will be great, I really need this patches...
(the files I am finding are not converted in the zip files collected by blue hell as G1 to G2 libraries.... sadly...)
THANKS IN ADVANCE!!!!!!
Kassen
PostPosted: Fri Nov 23, 2007 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
A NM-based phase vocoder? Are you serious? That would be quite exciting.
Kassen
Reversible
PostPosted: Fri Nov 23, 2007 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
YES!
Is very rare cause the patches of that list are original G1 (NM):
Classic Vocoder
Saw Vocoder
Phase Vocoder
Pulse Vocoder
Simple Vocoder
Vocoder Lead
but that patches are not converted to G2, if you check the G1 to G2 index you can see it...
but that conversion exists...
Smile
PostPosted: Sat Nov 24, 2007 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I did a search for files called *.pch2 on the converted patch archive and I found 750 patches containing the word "vocoder". I made a small selection from these that might match your criteria ... not sure if it is what you need, but you could do a search on the converted archive yourself to look for better fitting ones I guess.
vocoders.zip
Some pch2 versions of classic vocoder patches.
 Filename:  vocoders.zip
 Filesize:  10.75 KB
 Downloaded:  720 Time(s)
Reversible
PostPosted: Mon Nov 26, 2007 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
THX Blue Hell!!!
I am sure I can find the perfect vokoooodeeerrrr!!
Now I am working with the Patch Mutator and the vocoder pacthes that I found here, the Patch Mutator is one of the best ways to make fresh and quick patches and it´s perfect to make quick vocoders with some variations.
I found a pacht with "freeze", this is a really good parameter to play it in live but I don´t know how and where to insert in a standart vocoder patch..., sorry but I am learning to work with my G2...., some help will be great!!!
Thanks one more time for the zip file!!
(NOTE: I found some patches in the archive converted from G1 to G2 that not working because the in input signal is changed from Left to Right..., the work input must be Left)
R
mister_ludo
PostPosted: Thu Jan 03, 2008 4:31 am    Post subject:  phase vocoder
Subject description: real phase vocoder
Hello everybody,
I'm also new to this forum,...I've just bought a second hand G2X,..after having a V-synth.I've spent my holliday reading lot's of cool stuff,..this forum is really great!
I'm wondering if the phase vocoding, like in the v synth is possible with the G2X.
Is it possible in fact to modify the formant in real time? much better than just add a morph equalizer? or freeze the sound? like the variphrase algorithm?
