Photos of what you've built with JH PCBs
Page 8 of 9 [215 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8, 9 Next
jumunius
PostPosted: Sun Sep 26, 2010 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="defex"]
jumunius wrote:
defex wrote:
Here is another LVCO
If i build another one i will make a circuit board for the pots, it would save a lot of time.
That's funny, I was thinking your solution might be cheaper and easier than pot chiclets. I guess having done it you would disagree.
magman
PostPosted: Mon Sep 27, 2010 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I believe there are two main variants of these BI/TT Tech pots, the P260P and P260T.
The P260P are classed as Side adjust and have the pins designed to mount the pot to a PCB with the shaft in line with the PCB.
The P260T is classed as a Top adjust and have longer pins that are designed to mount the pot to a PCB with the shaft at 90 degrees to the PCB.
Here's a link to a datasheet that may make things a little clearer:
http://www.rapidonline.com/netalogue/specs/68-1175e.pdf
It looks to me that the variant defex has used is the P260T. Most of the P260 series I have seen for sale (and bought from places like Rapid in the UK) are the P260P type. A neat solution to panel wiring though. Wink
Oh, and by the way, for MTA connectors to fit this pin spacing you will need MTA100 connectors, not MTA156 (0.1" compared to 0.156").
I hope that makes things a little clearer.
Regards
Magman
jumunius
PostPosted: Mon Sep 27, 2010 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, indeed that does make it clearer. I've looked all over for variations on the P260 and have found the same, that the P260P is the only one generally available. I'm saving up to buy 240 from a US distributor... God knows how many I'd have to buy if I were to order the P260T.
-Jim
defex
PostPosted: Tue Sep 28, 2010 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="jumunius"]
I meant creating a whole single sided board for all of the PC mount pots and having just a couple of big headers instead of all those small ones. Just to make it neater. I can do that pretty fast now and the pulsar pro paper + laminator makes it really easy
for smaller projects i will keep doing it this way, it does have the advantage of making it easy to replace a pot if one dies.
sduck
PostPosted: Mon Oct 18, 2010 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
A page back you can see my first Son of Storm Tide Flanger build - but I recently built another one for someone else, and took the opportunity to tweak the panel a little. I moved the pots around, so that the ones I was using the most were all at the top, and added the v/oct tracking knob I completely forgot on the first one.
Son of Storm Tide Flanger II front
Son of Storm Tide Flanger II back 1
JoeMorris
PostPosted: Wed Dec 08, 2010 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
finally got my triple chorus, krautrock phaser and tau behind a proper labellled panel rather than a cheap piece of anyonymous plastic. never one for being economical, I've let these little beauties stretch their legs amongst no less than 4, yes count 'em 4U of spacious grounds. gave them my own names, as I am often wont to do for a bit of fun. A firm nod is always directed towards Mr Haible whenever their provenance is discussed, however.
L-1
PostPosted: Fri Dec 17, 2010 8:27 am    Post subject: JH Living VCO's are ready and works! Reply with quote  Mark this post and the followings unread
I just added mixer. Great design. Recommended for all DIYers.
 Filesize:  45.45 KB
 Viewed:  331 Time(s)
 Filesize:  71 KB
 Viewed:  301 Time(s)
 Filesize:  68.74 KB
 Viewed:  291 Time(s)
L-1
PostPosted: Fri Dec 17, 2010 8:44 am    Post subject: JH String Filter Reply with quote  Mark this post and the followings unread
String Filter sounds very good. Thanks Juergen! Will buy other your projects.
 Filesize:  59.49 KB
 Viewed:  289 Time(s)
 Filesize:  62.79 KB
 Viewed:  281 Time(s)
 Filesize:  58.24 KB
 Viewed:  279 Time(s)
emdot_ambient
PostPosted: Mon Dec 20, 2010 1:20 pm    Post subject: Re: JH Living VCO's are ready and works! Reply with quote  Mark this post and the followings unread
@L-1 thumb up Very nice Living VCO build! I love the mounting bracket. I'm considering something very similar on a large panel I'm building now.
Luka
PostPosted: Mon Jan 03, 2011 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
krautrock & resonator
paper covers until i can get some vinyl stickers made up
problemchild
melbourne australia
zarko
PostPosted: Thu Mar 17, 2011 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello all some pics of the Jurgen module i build.
The living vcos
 Filesize:  1.63 MB
 Viewed:  311 Time(s)
zarko
PostPosted: Thu Mar 17, 2011 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
The FSH1A FREQ SHIFTER.
 Filesize:  1.22 MB
 Viewed:  313 Time(s)
 Filesize:  2.06 MB
 Viewed:  273 Time(s)
 Filesize:  1.82 MB
 Viewed:  430 Time(s)
zarko
PostPosted: Thu Mar 17, 2011 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
The Krautrock phaser.
 Filesize:  1.21 MB
 Viewed:  285 Time(s)
 Filesize:  1.62 MB
 Viewed:  282 Time(s)
zarko
PostPosted: Thu Mar 17, 2011 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
The Polymoog Resonator
 Filesize:  1.33 MB
 Viewed:  299 Time(s)
zarko
zarko
PostPosted: Thu Mar 17, 2011 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
The S.O.S.T.F
 Filesize:  1.38 MB
 Viewed:  291 Time(s)
zarko
PostPosted: Thu Mar 17, 2011 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
And the last one the Variable Slope Filter Phaser,all these module have a great and strong sounding. Thanks Jürgen Wink
 Filesize:  1.43 MB
 Viewed:  294 Time(s)
sduck
PostPosted: Thu Mar 17, 2011 9:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! Great stuff zarko!
zarko
PostPosted: Fri Mar 18, 2011 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks,your modules are very nice too, and your front panels are clean in comparaison of mine. Wink
mph
PostPosted: Sat Mar 19, 2011 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats zarko!
I'd like to see them in your huge white Yusynth.
zarko
PostPosted: Mon Mar 21, 2011 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Merci MPH pas encore comme le yusynth est plein de doit fabriquer un autre meuble Wink
Not yet because i have to build an other cabinet my Yusynth is full Wink
Luka
PostPosted: Wed Aug 29, 2012 8:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
finished my fs-1
Smile
https://vimeo.com/48439978
problemchild
melbourne australia
The Bad Producer
PostPosted: Fri Sep 07, 2012 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
wicked Luka!!!
The Bad Producer
PostPosted: Thu Mar 07, 2013 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Been a while since posting anything here, but here is a Solina Chorus module I finished t'other day. I'm really pleased with the finish on this, something I've been considering for some time and now feel able to show and continue using for all my builds from now on... Now to repanel all the other stuff!
sonicwarrior
PostPosted: Fri Apr 12, 2013 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
How could I miss this thread?
Here is my CA3046 Tau Phaser I finished last year.
 Filesize:  85.59 KB
 Viewed:  459 Time(s)
 Filesize:  82.84 KB
 Viewed:  477 Time(s)
