  Various Artists Live streaming concert in memory of Antimon
Problem building miniAudicle
Page 1 of 1 [4 Posts]
ilSignorCarlo
PostPosted: Fri Feb 22, 2008 12:57 pm    Post subject: Problem building miniAudicle Reply with quote  Mark this post and the followings unread
Hi, I am completely new to Chuck.
I am trying to get it working on Linux Ubuntu 7.10.
I installed Chuck with no problem, so when I type "chuck" in the shell, I get:
[chuck]: no input files... (try --help)
I followed the instructions for building miniAudicle, and now when I go in the directory wxw/ and type ./miniAudicle I get the following error:
Code:
./miniAudicle: error while loading shared libraries: libwx_gtk2_stc-2.6.so.0: cannot open shared object file: No such file or directory
I think I have already installed the wx-widget. So, what am I missing?
Thanks
kijjaz
PostPosted: Fri Feb 22, 2008 10:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
eh.. I'm not sure..
usually I've got libwxgtk2.6-dev and libwxgtk2.6-0 packagen ready beforen compiling miniAudicle,
one time I tried compiling with 2.8 instead and it won't open the interface correctly.
I'm not sure, could you check if you've got only the wxgtk 2.6 version?
ilSignorCarlo
PostPosted: Sat Feb 23, 2008 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I have both 2.6 and 2.8.
But, if I give wx-config --list in the shell, I get:
Default config is gtk2-ansi-release-2.6
Default config will be used for output
Is there anything else I can do?
PostPosted: Sun Feb 24, 2008 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, Carlo!
You may want to send a mail to the users list to reach Spencer, I think he's in charge of that bit and he should know what's up with those versions. Once I got the hang of it compiling the Mini never gave me any issues but I don't know what the differences between our systems are and which ones of those matter. I did get good results on Ubuntu 7:10, so that OS as such isn't the issue, likely it's a minor configuration thingy.
You did get all "-dev" versions of the libraries where available? that seems to be the most common mistake people make (I did that wrong at first as well).
