  Muied Lumens Frequencies
Is there a more efficient way of implementing OSC than...?
Page 1 of 1 [2 Posts]
Dr. Spankenstein
PostPosted: Fri Feb 22, 2008 4:04 pm    Post subject: Is there a more efficient way of implementing OSC than...? Reply with quote  Mark this post and the followings unread
Setting up a separate shred for each and every variable that is to be received by ChucK?
For example can this code be written more concisely as one shred?
Code:
fun void OSCReceiveCutPosition()
   OscRecv MaxMSPReceiveCutPosition;
   6449 => MaxMSPReceiveCutPosition.port;
   MaxMSPReceiveCutPosition.listen();
   MaxMSPReceiveCutPosition.event("/CutPosition, f") @=> OscEvent MaxMSPCutPosition;
   while(true)
      MaxMSPCutPosition => now;
          while ( MaxMSPCutPosition.nextMsg() != 0 )
         MaxMSPCutPosition.getFloat() => OSCCutPosition;
         OSCCutPositionUpdated.signal();
         //<<<"Current Max/MSP value", OSCCutPosition>>>;
fun void OSCReceiveCutLength()
   OscRecv MaxMSPReceiveCutLength;
   6449 => MaxMSPReceiveCutLength.port;
   MaxMSPReceiveCutLength.listen();
   MaxMSPReceiveCutLength.event("/CutLength, f") @=> OscEvent MaxMSPCutLength;
   while(true)
      MaxMSPCutLength => now;
          while ( MaxMSPCutLength.nextMsg() != 0 )
         MaxMSPCutLength.getFloat() => OSCCutLength;
         //OSCCutPositionUpdated.signal();
fun void OSCReceiveNumberOfStutters()
   OscRecv MaxMSPReceiveNumberOfStutters;
   6449 => MaxMSPReceiveNumberOfStutters.port;
   MaxMSPReceiveNumberOfStutters.listen();
   MaxMSPReceiveNumberOfStutters.event("/NumberOfStutters, f") @=> OscEvent MaxMSPNumberOfStutters;
   while(true)
      MaxMSPNumberOfStutters => now;
          while ( MaxMSPNumberOfStutters.nextMsg() != 0 )
         MaxMSPNumberOfStutters.getFloat() => OSCNumberOfStutters;
fun void OSCReceiveBufferFile()
   OscRecv MaxMSPReceiveBufferFile;
   6449 => MaxMSPReceiveBufferFile.port;
   MaxMSPReceiveBufferFile.listen();
   MaxMSPReceiveBufferFile.event("/BufferFile, s") @=> OscEvent MaxMSPBufferFile;
   while(true)
      MaxMSPBufferFile => now;
          while ( MaxMSPBufferFile.nextMsg() != 0 )
         MaxMSPBufferFile.getString() => OSCBuffer;
Thanks,
Rhys
P.S. Most of the variables mentioned above are part of a bigger programme, and as such this code wont work by itself. I just thought I'd copy n paste the OSC part as an example.
Dr. Spankenstein
PostPosted: Sat Feb 23, 2008 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
If I were to wait for each message to arrive what order would they arrive in, if they are all sent at once?
In other words, how do I sync what is going on in ChucK to OSC.
I have the data sent to ChucK via OSC and then run ChucK once the data has been updated.
