funkyfarm
Posted: Wed Mar 05, 2008 8:01 am Post subject:
VCA in exponential mode |
can anybody throw a sample which could illustrate an interesting use of VCAs in exponential mode (i.e. not LINEAR) ?
On each vca I build, I always add a switch for LIN/EXP mode but I have to admit they always stay in the upper position.
EXP is better for percussive sounds !?
linear adsr with exp vca, exp adsr go with linear vca...
i'm lost and (sadly) unconvinced. |
yusynth
Posted: Wed Mar 05, 2008 9:05 am Post subject:
Personally, the only useful use of the expo mode in a VCA is for using MIDI velocity CV to modulate the output of an ADSR EG _________________ Yves |
Etaoin
Joined: Jun 30, 2005 Posts: 760 Location: Utrecht, NL
Posted: Wed Mar 05, 2008 10:46 am Post subject:
I always use my VCA in log mode when connected to my ADSR. I seem to have better control that way (Yusynth ADSR to MFOS log/lin VCA).
By the way, are we mixing exp and log or are there three types of VCAs, log, lin and exp? _________________ http://www.casia.org/modular/ |
widdly
Posted: Wed Mar 05, 2008 7:19 pm Post subject:
Exponential VCA are handy for tremolo and panning. Last edited by widdly on Thu Aug 05, 2010 10:19 pm; edited 1 time in total |
Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
Posted: Thu Mar 06, 2008 3:11 am Post subject:
| Quote: | | By the way, are we mixing exp and log or are there three types of VCAs, log, lin and exp? |
Wikipedia says the expo function is the inverse of the log function, so if Ray Wilsons vca's really are log (and not exp), and exponential vca'a are good for tremolo and panning, that explains why I get better tremolo out of the lin setting of my Ray Wilson vca's than with the log setting. Actually, I haven't yet found the log setting useful for anything, and pretty hard to set up interms of the cv-offset control.
This log/exp thing has had me confused too...
C[/quote] |
funkyfarm
Posted: Thu Mar 06, 2008 9:37 am Post subject:
thank you for answering.
that's an interesting use yves...
As you coriolis i've found cv-offset control to behave strangely, anyway...not the same.
Etaoin, won't your eg sound as "thin peaks" in this mode ?
Has anyone try the EnvyLope/Papareil Linear ADSR EG ?
http://m.bareille.free.fr/modular1/adsr/mb_cvadsr2.htm
(your samples sound so quiet ) |
Dave Kendall
Posted: Thu Mar 06, 2008 1:34 pm Post subject:
Yeah - I'm a bit confused too
I'm assuming that normally, lin, log and expo refer to the effect on the input signal of *any* VCA when controlled by a linear CV..... (?)
As an aside, I've seen some pan pots described as "equal power" - Mackie stuff used to mention that IIRC. Would that be log or expo or something else?
(- edited to remove the effect of beer just before posting  Last edited by Dave Kendall on Thu Mar 06, 2008 4:59 pm; edited 1 time in total |
Etaoin
Posted: Thu Mar 06, 2008 1:40 pm Post subject:
Ray has pictures of what he calls lin and log on his VCA.
This log looks suspiciously exponential to me.
MFOS lin:
MFOS log:
