2008/03/11 Nomad 0.3 pre-release Update 2 available for DL
Page 1 of 2 [27 Posts]
chresan
PostPosted: Tue Mar 11, 2008 10:30 am    Post subject: 2008/03/11 Nomad 0.3 pre-release Update 2 available for DL Reply with quote  Mark this post and the followings unread
we published an update of the Nomad 0.3 release right now .
Fixes
- module pane does not show modules
- module/connector popup not shown
- Invalid plug exception -> no connection possible
net.sf.nmedit.jsynth.SynthException: Invalid plug MidiPlug[name=MIDI HUBBLE MIDI 2,vendor=Unknown vendor,description=No details available] for net.sf.nmedit.jsynth.midi.MidiPort[name='pc-out',type=TRANSMITTER,plug=MidiPlug[name=Microsoft MIDI-Mapper,vendor=Unknown vendor,description=Windows MIDI_MAPPER]].
at net.sf.nmedit.jsynth.midi.MidiPort.setPlug(MidiPort.java:110)
Please download the updated release from http://nmedit.sourceforge.net/
I am very sorry this happened. Embarassed
Christian
http://nmedit.sf.net
nathan
PostPosted: Tue Mar 11, 2008 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice guys!
we'll get at the perfect editor, step by step, altogether hand in hand.
nathan
PostPosted: Tue Mar 11, 2008 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
only weird thing now is that the knobs dont turn visually correct.
but only visually. weird..
gomidas
G2 patch files: 6
PostPosted: Tue Mar 11, 2008 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
MACROS RULES, THAAAAANKS..
1.I'm using Mac(intel) OSX 10.5.2
2.ONLY Mandolane can give me MIDI, plumstone is PPC ONLY(freeware), osxmidispi and mmj DON'T WORK for me.
http://www.mandolane.co.uk/
3.IT WORKS with http://www.mandolane.co.uk/swMandoMidi.html and the platform independent http://downloads.sourceforge.net/nmedit/nomad-0-3_2.zip?use_mirror=osdn.
Great Work thumleft
m:o
PostPosted: Tue Mar 11, 2008 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Big thanks to you !! Works like geschnitten brot here ! Smile
You have really made a lovely work on this - the only thing to make me perfect happy is to find the switch between horizontal and vertical mouse control.......am i blind?
gomidas
G2 patch files: 6
PostPosted: Tue Mar 11, 2008 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello mSurprised, do you use mac or win? ppc ,intel? osxmidispi or other? Sorry to bother my friend it's just to know...
m:o
PostPosted: Tue Mar 11, 2008 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey gomidas!
im on a windows desktop with XP Sp3 and a Terratec MidiHubble as Midi i/o.
I guess you're on a mac, so i can't help - sorry.
gomidas
G2 patch files: 6
PostPosted: Tue Mar 11, 2008 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok!!!!! cool!!!!
Have fun mSurprised
wesen
PostPosted: Tue Mar 11, 2008 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey gomidas,
I have the exact same config as you, but mmj and osxmidispi work for me. What is the problem when you use those? Is the EDIROL not recognized?
Regards, manuel
chresan
PostPosted: Tue Mar 11, 2008 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi gomidas,
when you tried our osxmidispi, did you remove the other SPIs (mmj,mandalone) ? It could be that they interfere with each other.
Christian
P.S.: Java 1.5 = Java 5, Java 1.6 = Java 6
gomidas
G2 patch files: 6
PostPosted: Tue Mar 11, 2008 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will try this as soon as I get back home...thanks for the tip Very Happy
gomidas
G2 patch files: 6
PostPosted: Wed Mar 12, 2008 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
AND AGAIN.. MACROS RUUUUUULES!!!!!!!!!!!! Twisted Evil
gomidas
G2 patch files: 6
PostPosted: Wed Mar 12, 2008 2:26 am    Post subject: Reply with quote  Mark this post and the followings unread
EDIT: IT WORKS with http://www.mandolane.co.uk/swMandoMidi.html and the platform independent http://downloads.sourceforge.net/nmedit/nomad-0-3_2.zip?use_mirror=osdn.
Mac intel OSX 10.5.2
cebec
G2 patch files: 31
PostPosted: Thu Mar 20, 2008 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyone find a way to switch between horizontal and vertical mouse control of knobs in the editor?
chresan
PostPosted: Thu Mar 20, 2008 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Currently there is no way to change the behaviour. But in one of the next releases there will be such an option.
cebec
G2 patch files: 31
PostPosted: Thu Mar 20, 2008 6:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool. Just checking. Keep up the great work!
starpause
PostPosted: Thu Apr 03, 2008 9:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
when i start nomad-0-3_2 with "java- jar nomad.jar" on my ubuntu desktop nomad launches fine.
however, i can not connect to my micromodular. in fact, i can't even go to edit->preferences or file->preferences (both options are grayed out).
i was able to connect with the previous version of the editor.
any advice? thanks in advance and glad to see a new version!
edit:
after watching the screencasts i tried to connect to my micromod but got this error:
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
   at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
   at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
   at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
   at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
   at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:273)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:183)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:173)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:168)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:160)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:121)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
   at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:111)
   at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:400)
   ... 11 more
wanted to add that i'm using the midisport uno 1x1 ...
is there a tool like midiox for linux or mac osx? i think it's working though because the last version of nomad could connect.
Audio files: 219
PostPosted: Fri Apr 04, 2008 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just tried Nomad 0-3_2 on Vista with Java 1.6 with and Edirol UM-3ex, no good, no connection Crying or Very sad
It looks like a timeout on the heart beat ... would that be the real problem or could it be that MIDI is not neatly grouped into completed messages (an issue I've ran into at times with MIDI on windows)?
The Clavia editor seems to work on this config, although I didn't really test it yet.
Edit : I Do have the synth set for internal clock.
Anyway, here is my dump :
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1207345072963 [error=-1001]
   at java.awt.event.InvocationEvent.dispatch(Unknown Source)
   at java.awt.EventQueue.dispatchEvent(Unknown Source)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
   at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
   at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
   at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1207345072963 [error=-1001]
   at net.sf.nmedit.jnmprotocol2.NmProtocol.heartbeatImpl(NmProtocol.java:58)
   at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular$SchedulingProtocol.heartbeatImpl(NordModular.java:252)
   at net.sf.nmedit.jnmprotocol2.AbstractNmProtocol.heartbeat(AbstractNmProtocol.java:154)
   at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:114)
   at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:358)
   ... 11 more
chresan
PostPosted: Sat Apr 05, 2008 5:14 am    Post subject: Reply with quote  Mark this post and the followings unread
BlueHell:
We did not test Nomad on Vista because none of us has this OS. Nomad contains some code which tries to "correct" invalid sysex messages and I believe this causes some of the timeout problems. At the moment I can't say more than I will look into this.
Christian
chresan
PostPosted: Sat Apr 05, 2008 5:18 am    Post subject: Reply with quote  Mark this post and the followings unread
starpause:
The current release contains a bug which causes this exception. You have to set the synth midi clock to "internal" as workaround.
midisport + ubuntu should not cause any problems.
Christian
chresan
PostPosted: Sat Apr 05, 2008 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Bon appetite! Very Happy
Audio files: 219
PostPosted: Sat Apr 05, 2008 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I split off a couple of debug setup related posts to : http://electro-music.com/forum/topic-25377.html
Audio files: 219
PostPosted: Sat Apr 05, 2008 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Danke schön Very Happy
edit: oh this got a bit weird due to the split off, ah well, "dinner time" was what I said in the other thread.
starpause
PostPosted: Mon Apr 07, 2008 7:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
chresan, thank you! i will try that out.
any1 know if it's possible to set the midi clock to internal from the micro modular front panel? i don't see how and it's not mentioned in the manual. if not i will take my micro to work and use the windows editor
myspace
starpause
PostPosted: Mon Jul 21, 2008 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
update: i just checked my nord micromodular with "Nord modular editor v3.03" under windows, looks like i already had MIDI clock to internal. i tried toggling it back and forth just for good measure and starting nomad with the MIDI clock to both internal and external but "Preferences" was still grayed out in nomad's Edit menu, even under winXP
is this something that might be fixed in the head CVS build?
thanks!
myspace
