Tellun Neural Agonizer
Page 3 of 6 [140 Posts]
Luka
PostPosted: Tue Sep 09, 2008 9:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
at this stage they are all gone
of all the orders 90% have confirmed their numbers too
if anyone drops at the 11th hour ill let you know
problemchild
melbourne australia
bugfight
PostPosted: Fri Oct 10, 2008 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
update: tanks are ordered (on tuesday, sorry i've been too
busy this week to enjoy the forum)
it will take about 3 weeks before they ship them...
i got some packing tips when i ordered.
next we will need to determine the best shipping method.
i think the best thing will be each member can choose his
level of risk, but if you choose to forgo insurance/tracking,
you must not try to recover funds if the risk doesn't pan out
and the package is lost...
also everybody needs to agree to handle lost packages through
insurance and not try to use paypal chargebacks.
i was strongly advised by some folks with direct knowledge of
such things, that usps express mail international is the best way
for non-usa packages, but it is pricey.
there will also be some small charge for packing materials
we won't be able to get accurate costs until i have them in hand
and packed...
sneakthief
PostPosted: Fri Oct 10, 2008 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
speaking of the tanks, it's good to use longer coaxial cables to connect them to the boards. that way you can place them away from your modular and other sources of RF interference.
they're pretty sensitive and have been known to pick up the sound of a robot sneezing 1km away.
Sneak-Thief - raw electrofunk
bubblechamber
PostPosted: Fri Oct 10, 2008 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
i was planning on building a small box for each tank out of 1" MDF to isolate them as much as possible, is this overkill on my part? i tend to go a little toward the obsessive side. I've seen a few big plate reverbs and they are always in big, sealed wooden cases, that's sort of what i'm going on.
david
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
JohnLRice
PostPosted: Fri Oct 10, 2008 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
david
I'm not a magnatizm scientist (probably can't even spell it! Wink ) but I'm pretty sure that MDF or wood etc isn't going to make much difference in blocking out interference. Plate reverbs are most likely in big wooden cases bacause the plates are big and heavy and need ample and stable support. What you want is something like mu-metal or similar alternatives. See the links below:
http://www.mumetal.com/about_mumetal.html
http://www.lessemf.com/mag-shld.html
Actually . . . I think the tanks themselves 'may' be made out of mu-metal, at least they usually loook like they are. That would be worth checking into because if they are then you'd only need a peice big enough to sheild the opening.
Best of luck!
sneakthief
PostPosted: Fri Oct 10, 2008 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
even if you put a mu-metal plate on the back, they're still ridiculously sensitive - but luckily not unmanageably so.
read Tellun's guide on tank placement to see what I mean. he also used back plates but still had to juggle their placement:
http://tellun.com/motm/diy/tln156/TLN-156a.html
Luka
PostPosted: Sun Oct 12, 2008 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
and packed...
thnx jim
problemchild
melbourne australia
NV
PostPosted: Mon Oct 13, 2008 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I know that the order has already been placed, but if anyone decides they don't have the money or change their mind I will gladly jump in and pay for a set of tanks. Probably a long shot but worth a try I guess.
Luka
PostPosted: Mon Oct 13, 2008 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
ok no prob NV
i think there was some people who also said this as well awhile ago, so if a few people pull out ill let you know. probably not looking good though, everyone sounds pretty keen on them.
problemchild
melbourne australia
JohnLRice
PostPosted: Sat Nov 08, 2008 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
So, I know something would of been said if there was news but . . . . anything to say? and news? Wink
Luka
PostPosted: Sat Nov 08, 2008 3:40 am    Post subject: Reply with quote  Mark this post and the followings unread
i havent heard anything john
guessing it will be soon as the order went in about the 5th of october and they said a month. perhaps Jim has some info
problemchild
melbourne australia
bugfight
PostPosted: Sat Nov 08, 2008 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
funny timing, the package arrived last night.
i didn't even know they had shipped them...
today i will pack one up and weigh it at the post office.
from there we can work out shipping details...
btw, do we want to test these in some way before i send them?
i haven't assembled the na pcb yet...
neandrewthal
PostPosted: Sat Nov 08, 2008 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yay. My panel and PCB's are ready and waiting Very Happy
Luka
PostPosted: Sat Nov 08, 2008 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
great news jim
perhaps someone has a NA set built that we can send to test, otherwise i found a simple reverb schem which could be used
i'll send an email around and get people's opinions
problemchild
melbourne australia
neandrewthal
PostPosted: Sat Nov 08, 2008 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can test a set, but if it doesn't work, I wouldn't be too quick to blame it on the tanks Embarassed
bugfight
PostPosted: Sat Nov 08, 2008 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
these babies are large and kinda heavy, shipping weight for 2 is gonna be 4 lbs.
i'll also need to find some more boxes, i only have one that is the right size.
re testing, i was thinking maybe i can use my blues jr or likesuchas...
Luka
PostPosted: Thu Nov 13, 2008 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smile
problemchild
melbourne australia
JohnLRice
PostPosted: Thu Nov 13, 2008 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
HEY!!!! Mad Wink
So, are those white things rubber isolation mounts? Do they come with the tanks?
Luka
PostPosted: Thu Nov 13, 2008 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm not sure, have to ask Jim
i sent out an email to everyone to confirm their paypal/shipping addresses (just to be sure) so if anyone didnt get it drop me a pm/email
Jim is recommending usps express shipping, but you can work that out with him. it is reasonably expensive but worth it for care and trust. we don't want no ace ventura delivery styles with these things
Smile
problemchild
melbourne australia
JohnLRice
PostPosted: Thu Nov 13, 2008 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smile
Oh! I thought you already had yours! Laughing I was jealous!
I just got an invoice from Jim for the shipping and handling and paid it already. Cool
bugfight
PostPosted: Thu Nov 13, 2008 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
i've invoiced everybody now.
let me know if you haven't recieved a paypal request
the rubber grommets are there, but no bolts or screws.
i gather either is fine...
...Jim is recommending usps express shipping,
just to be clear: for usa and canada, express is not needed.
for australia and japan, the cost is not too much more
and i hear there have been a lot of lost packages out that way.
express includes tracking and insurance and comes highly
recommended by some folks who ship a lot overseas...
i think we're ok using priority for uk and switz too...
just let me know if you 2 wanna bump it up...
hehe "fragile" means "throw it," right?
Funky40
G2 patch files: 5
PostPosted: Fri Nov 14, 2008 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, regarding the options:
Scott is mentioning lots of options about part values and such things.
I should start populating the Boards. The cabinet with the Tanks was allready built in March.
What should i do, just follow the docs and BOM and ignore all the mentioned options, or are there some one should make ?
I also have made notices to make some CV inputs with attenuators when reading the docs early this year,
What do you guys think who have running the Tellun NA allready ?
any replies or tipps are appreciated,
thanks
neandrewthal
PostPosted: Sat Nov 22, 2008 1:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Got my tanks today Very Happy They are huge! Way bigger than I expected. I`m gonna have to stack them, and my cabinet is 15 x 42 inches in the bottom. Big thanks to everyone who made this possible, especially Luke and Jim.
Now, If only I didn`t have to go to work day and night all weekend Evil or Very Mad
JohnLRice
PostPosted: Sat Nov 22, 2008 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Ditto for me too! Cool Thanks Luke, Jim and everyone! I've got one single perfect place to mount them and I hope to God that the hum is tolerable otherwise I'm not sure where I'm going to mount them!
Now . . . since I have the tanks, circuit boards and front panel, all I have to do is order most of the rest of the parts and then build it, that's all! Laughing
bugfight
PostPosted: Tue Nov 25, 2008 8:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok all packages sent, if anybody didn't get a ship notice from me, check your spam filter
