Bananalogue
Posted: Sat May 24, 2008 2:38 am Post subject:
Bananalogue VCS diy board set available |
Hi folks! I've decided to offer a VERY limited number (15) of Bananalogue VCS PCB sets to the synth DIY community. The set is four boards, three for components and pcb mount hardware with a fourth optional bridge board (you could opt to use fly wires if you want to play with different panel designs). Please note the following caveats BEFORE ordering from me:
1. these are an early revision of the Bananalogue VCS and the PCBs don't have any spare room vertically to squeeze into a frac/euro rack. we redesigned after this revision to allow more room between the rack rails - so please consider that.
2. i will not be offering ANY support or documentation for these PCBs, we simply don't have the time, so not a good project for beginners!
3. the PCBs have all the component values and placement silkscreened on them. if you have successfully built one of Ken Stone's CGS boards you should be familiar with this system. if you have NOT built a CGS board i would STRONGLY discourage you from starting here.
so, if you are still bold enough - email me with your shipping address and i will send you my paypal account. sets are $40 each, and shipping should be about $3 USA, $6 overseas
and they are a very pretty red:
ehdyn
Joined: Sep 13, 2007 Posts: 33 Location: Caerdydd, Palau
Posted: Sat May 24, 2008 10:44 am Post subject:
Hello,
Any plans to do another run of the VCS, or euro the ARP?
Thank you |
guitarfool
Bananalogue
Posted: Sat May 24, 2008 1:23 pm Post subject:
| ehdyn wrote: | Hello,
Thank you |
we will continue making the VCS as a module.
the euro version of the LPFA is still a ways into the future, but we know people are very interested, so it'll happen.
no schematics with this project, sorry. |
Funky40
G2 patch files: 5
Posted: Sat May 24, 2008 2:36 pm Post subject:
1. are there any spacial or hard to find parts needed ?
2. are all the wirepoints named clear ? ( this is sometimes hard on Kens boards, and one needs to look to the schemas )
3. from the layout it is the same as the Manufactured module, so one could get help from a Friend who have the VCS ? |
sduck
Posted: Sat May 24, 2008 3:16 pm Post subject:
| I sent an email to the info@ address listed on your web page - is this the correct one to send to? I want one! |
Bananalogue
Posted: Sat May 24, 2008 4:20 pm Post subject:
| Funky40 wrote: | 1. are there any spacial or hard to find parts needed ?
1. you can find everything at mouser.com
2. there are only two components that are not pcb mounted, the cycle switch and the "cv slope both" jack
3. it only resembles it in color, the layout is completely different, but you might be able to figure it out by comparing. the components involved are exactly the same, just juggled around a bit to make it fit better in a frac/euro rack system. |
Funky40
G2 patch files: 5
Posted: Sun May 25, 2008 1:31 am Post subject:
thanks.
ok, i take one and will mail you now |
Bananalogue
Posted: Mon May 26, 2008 10:58 pm Post subject:
| just a few more left, please PM if interested. |
Funky40
G2 patch files: 5
Posted: Wed Jun 18, 2008 1:57 am Post subject:
Hi Banaplug,
1. ) i need to know all the pot values ( this is urgent as a friend has a Mouser order open, so i can take them with him )
2. ) also if all trannys are 2N3906 or 2N3904 ?
3. and if the Trimmer is labeled with 100R or 100K
sorry, but those are not labelled or readable.
oh, and thanks for the Boards
Funky |
Bananalogue
Posted: Thu Jun 19, 2008 4:08 pm Post subject:
no problem, i use 313-1510F-10K and 313-1600F-50K
thats 2x 10k log and 2x 50k lin with the built in pull switch
both actually, if you look really close at the silkscreen you can see the NPN and PNP trannys are marked in schematic.
100K
alrighty! i have just a feeeeeew more board sets if anyone else would like to jump on this! i'm an NOT one for hyperbole, but this module is one of the most flexible i have ever encountered.
best wishes
seth |
CJ Miller
Posted: Thu Jun 19, 2008 5:26 pm Post subject:
It's worth considering! I bought one set, these are really nice quality boards. Not built them yet, but it's a brilliant circuit also. If you've been on the fence about buying the regular VCS module, but can't quite afford it, here's your chance. Beautiful work.
Thanks again, Seth! |
Ilanode
Posted: Fri Jun 20, 2008 1:24 am Post subject:
| CJ Miller wrote: | | If you've been on the fence about buying the regular VCS module, but can't quite afford it, here's your chance. Beautiful work. |
So true! BTW the pots can be aquired from Small Bear Electronics for a better price. To my best knowledge their part #s are: 1010A and 1005B.
Thanks, Seth! |
Luka
Ilanode
Posted: Fri Jun 20, 2008 2:50 am Post subject:
| Luka wrote: | | who else got one? [...]it would be cool to band together and chat if we hit any snags |
Got 2 of them. Looking at the boards it seems to be a pretty straightforward job. All querries I had were answered by Seth's posting. However, in case of probs this thread will be the snag exchange, I guess. Last edited by Ilanode on Fri Jun 20, 2008 3:49 am; edited 1 time in total |
Funky40
G2 patch files: 5
Posted: Fri Jun 20, 2008 3:35 am Post subject:
Thanks Seth !
Yes, no open questions now. The Build looks easy.
No problematic parts as Seth Mentioned.
Yes, PNP and NPN is viewable good, no problems there.
I was just not shute about the Type.
| CJ Miller wrote: | If you've been on the fence about buying the regular VCS module, but can't quite afford it, here's your chance. Beautiful work.
Exactly ! |
Luka
creatorlars
Posted: Fri Jun 20, 2008 9:43 am Post subject:
Thanks for the parts notes, Seth!
I got these boards too. I'll be building it over the next couple months probably, so I'll be watching this thread to compare notes. |
Luka
Ilanode
Posted: Sun Jul 13, 2008 4:19 am Post subject:
I did a parts list but it could be wrong since I haven't started to build the PCB yet. So pls check for possible errors
Resistors
100r 1
1k 2
100k 10
150k 2
2k2 3
220k 4
330r 1
33k 2
330k 3
47k 1
470k 5
68k 1
8k2 1
82k 4
820k 3
1m 5
10m 2
Semis
2N3904 3
2N3906 3
1N4148 6
ZD 5V6 1
TL072 1
TL074 1
LM3900 1
Caps
10n 2
100n 4
2n2 1
47pf 2
0,47µF/30V 1
Trimpot
100K
LED 1
Switch 1 SPDT
Jacks 9
Pots (Please see my post dated: 20th Aug. 2008)
Alpha 1010A 2 313-1510F-10K log (= part #)
Alpha 1005B 2 313-1600F-50K lin/switch (= part #) Last edited by Ilanode on Wed Aug 20, 2008 6:32 am; edited 1 time in total |
Luka
Ilanode
Posted: Wed Aug 20, 2008 6:31 am Post subject:
Still picking part and thought I was almost through when ordering these pots:
| Bananalogue wrote: | | i use 313-1510F-10K and 313-1600F-50K |
Now I've to realize that they won't fit onto the board. At their end they have a small flat shaped pin to the PSB to stabalize the pot. However, the board wants up to 5 tiny pins at the this place!
No what? Bowing off the "flat shaped pin"? Sawing it off? Enlarging the tiny holes on the board itself so the "flat shaped pin" will fit? And if so how to achieve that? |
goldenechos
Joined: Jun 06, 2007 Posts: 201 Location: Marshall, NC
Posted: Wed Aug 20, 2008 6:53 pm Post subject:
| Ilanode wrote: | Still picking part and thought I was almost through when ordering these pots:
I own 2 VCS from Banalogue (built by Seth I assume) and on both of them that last pin is either bent outward (so that it does not connect to anything) OR it had been trimmed off.
You have the right part.
Tony |
Ilanode
Posted: Thu Aug 21, 2008 12:17 am Post subject:
| Thanks! Any idea how to trim that thingie? Is sawdust a concern or may I saw, file, rasp etc at will? |
goldenechos
Posted: Thu Aug 21, 2008 4:25 am Post subject:
| Ilanode wrote: | | Thanks! Any idea how to trim that thingie? Is sawdust a concern or may I saw, file, rasp etc at will? |
I would clip the tab before installing the pot. Just use wire snips or tinn snips, no saw needed.
Tony |
