 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Tyring to use the Morphs on channel 1 but...
Page 1 of 1 [6 Posts]
nuriel77
PostPosted: Sat May 24, 2008 7:31 am    Post subject: Tyring to use the Morphs on channel 1 but... Reply with quote  Mark this post and the followings unread
hi,
I made this performance, but somehow i do not manage to assign the morph parameters. I only manage to get the pitch stick control the morph values, but when assigned to wheel or pedal the morph dont seem to do nothing.
maybe someone can cofirm this?
thanks!
Mini-DjNuri.prf2
 Filename:  Mini-DjNuri.prf2
 Filesize:  16.22 KB
 Downloaded:  1088 Time(s)
Audio files: 216
PostPosted: Sat May 24, 2008 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure what you mean, but in the attached patch it looks like there are no morphs at all.
To use morphs you click on the knob for the morph you want to use to make it the focused morph.
Then you click/drag on the knobs that you want to be in that morph group to set their morph range from some minimum to some maximum value.
Then when you change the morph knob (or when it is associated with some controller (which it is by default), the associated controller (like the pitch stick or the mod wheel)) the effect is that the morph controls the knobs that are in the group.
I think the manual does a better job in explaining it Embarassed Laughing
nuriel77
PostPosted: Sun May 25, 2008 4:22 pm    Post subject: morphs... Reply with quote  Mark this post and the followings unread
Hey Jan,
I know how to assign morphs Smile I always manage to assign / use morphs.
what happened to me on this patch: I do manage to assign parameters to the various morphs, but when i try to use them, nothing works! (Try to assign the modwheel to one or more parameters like freq cutoff, and see if it does anything?)
Thnks.
G2 patch files: 625
PostPosted: Sun May 25, 2008 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice prf Smile
Slot A has the button under mod morph set to knob which disables the physical mod wheel.
I thought I had the same problem as you reported, until I realised I hadn't set the keyboard focus the the slot I was playing with. Embarassed
Assigning and using mod wheel morphs seems to work here on my G2 key.
Audio files: 216
PostPosted: Sun May 25, 2008 5:07 pm    Post subject: Re: morphs... Reply with quote  Mark this post and the followings unread
Ok, I didn't see any, so I thought that was the problem ...
That doesn't work for an engine, so I can't try unfortunately.
nuriel77
PostPosted: Mon May 26, 2008 5:12 pm    Post subject: Re: morphs... Reply with quote  Mark this post and the followings unread
Hi!
Well I got the answer I needed. I had to read more in depth in the manual. I was sure I already went over the chapter of morphs, but I forgot that under the morph knobs there are also buttons! And I didnt see when I started the performance that the button under the control pedal and modwheel where actually set to knob Smile
I need to thank Rob for solving this simple issue for me!
thanks for trying to help though
best regards,
nuriel
Sorry I was maybe unclear about what it was I was trying to get done...
