New YUSYNTH Clock Divider module
Page 1 of 1 [16 Posts]
yusynth
PostPosted: Sat Jul 26, 2008 12:51 am    Post subject: New YUSYNTH Clock Divider module Reply with quote  Mark this post and the followings unread
Here is a new YUSYNTH module :
The Clock Divider which provides three independent decimal counter that can be selected to divide clock signals by 1, 2, 3, 4, 5, 6, 7 or 8. Very handy to control and synchronize two or three analogue sequencers or to trig events at regular steps.
Check it here :
http://yusynth.net/Modular/index.html
or directly here
http://yusynth.net/Modular/EN/DIVIDER/index.html
Yves
ericcoleridge
PostPosted: Sat Jul 26, 2008 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
This is fantastic, another great and highly useful Yu-Synth module; I really like the fact that it's three dividers in one module. I have a CGS divider that hasn't been paneled yet; I think I'd like to combine the two now.
Is there any plan to offer a PCB through Bride Chamber (I just as well buy manufactured board than etch one)?
yusynth
PostPosted: Sat Jul 26, 2008 1:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Not yet but I think there will.
Right now the modules that are planned to be distributed by Bridechamber are :
Diode VCF
Minimoog VCF
Ring Modulator
Random Module
Min/Max
Those already available are :
Saw animator
ARP4072 VCF
CV standards
Fixed Filter Bank
Yves
Yves
bugbrand
PostPosted: Sat Jul 26, 2008 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Good work Yves!
I love these sort of modules and have DIYed similar before - though I'd never seen the AND function on the output (Step1 and clock) - that's a great addition as my modules hadn't been able to the 'clock through' function.
My two cents is that you could use the full divide by 10 possibilities - personally I love having things that aren't your regular binary multiples (four beats, repeat four times, ad infinitum, etc). Just takes a rotary switch with two extra notches - connect Step10 for 9 beats or leave totally open for 10 beats.
Polyrhythmics!
http://www.bugbrand.co.uk
yusynth
PostPosted: Sat Jul 26, 2008 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes it will be available at Bridechamber's but not until next fall from what I understood (and also the Logical module)
Yves
Etaoin
PostPosted: Sun Jul 27, 2008 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
By the way, (I haven't finished my panel yet, so haven't tried it), but it's probably fast enough to divide down square waves in the audio range as well, retaining pwm?
http://www.casia.org/modular/
yusynth
PostPosted: Sun Jul 27, 2008 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I have not tried it in the audio range, but I see no reason why it wouldn't work... The pulse shape of the original is maintained that means that after dividing you add more and more blank steps and consequently the PW ratio diminishes proportionaly (it becomes a narrower pulse with respect to the repeating period).
Yves
Etaoin
PostPosted: Wed Jul 30, 2008 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Forgot to post my 2U Frac panel layout...
I opted for the 10-step divider suggested by bugs.
Yusynth Clock Divider
 Filesize:  126.26 KB
 Viewed:  206 Time(s)
yusynth
PostPosted: Wed Jul 30, 2008 12:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Etaoin
This photo will soon appear in the gallery section of module's page.
Yves
Yves
Etaoin
PostPosted: Wed Jul 30, 2008 12:33 am    Post subject: Reply with quote  Mark this post and the followings unread
By the way, it works great. I now finally have a module that can sync the MFOS sequencer from a 24ppq clock! A lot of modules can't clock the MFOS seq for some reason.
Now all I need to do is add a remote reset to the sequencer...
yusynth
PostPosted: Sun Dec 14, 2008 2:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
I have updated the circuit, I changed the values of R39 and R40 to higher values in order to have a higher input impedance for the reset input.
Yves
PostPosted: Tue Feb 03, 2009 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
i took a look at the schematic an i wonder, what is the initial status of the LEDs with no clock connected? are they "on"? or do the diodes do the trick? i am not quite sure about that.
fonitronik at
yusynth
PostPosted: Tue Feb 03, 2009 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Dark, in fact they can only lit when both the input clock is high and the 0 output of the counter is high. The diodes D4 and D5 and the resistor R9 act as a logical AND gate. This way, when no clock is connected no signal is available at the output and the LED is dark. When the rotary is on the first position (/1) the LED pulses at the clock rate and the output is a copy of the clock signal (same rate and same PW).
Yves
PostPosted: Tue Feb 03, 2009 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you very much for the quick reply and clarification, sir.
great idea to use the 4017 for that purpose, yves!
fonitronik at
littlem4tt
PostPosted: Fri Sep 06, 2013 8:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
What a fantastic little module. I have made a eurorack version (12v), once again by taking the original pcb design and using photoshop to cut the circuit in half to create a new footprint. Thanks again Yves!
 Filesize:  59.69 KB
 Viewed:  6066 Time(s)
 Filesize:  93.42 KB
 Viewed:  87 Time(s)
littlem4tt
PostPosted: Sat Sep 07, 2013 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I would also like to add that sending audio through it works great and you can get new timbres just by dividing down. For example passing my system x osc through it makes it sound more like a Juno 106. Pulse width stays fairly intact more noticeable on scope than ears though so usable. Plus you have the added ability to jam inversions.
For those interested, playing a c5 note gives you these pitches out:
In, c5 original pitch
1/2, c4
1/3, f3
1/4 c3
1/5 g#2
1/6 f2
1/7 d2 (slightly sharp)
1/8 c1
So much fun to be had!!
