How to preview Apple loops
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Feb 13, 2009 1:08 am    Post subject: How to preview Apple loops
Subject description: with Logic Pro 8 and a MOTU 828 MK3
As far as I know the preview of Apple loops, with Logic Pro 8 and a MOTU 828 MK3, is automatically sent to outputs 1 and 2 of this audio interface.
The problem is that its main outputs are seen by Logic as outputs 9 and 10 where I have connected my audio monitors.
So, how to preview them?
I solved the problem this way:
I connected outputs 1 and 2 to an audio patch bay and from there I can send the signals to a couple of free inputs of my audio interface.
It is a convoluted solution but it works. If someone knows of a better solution let me know.
EdisonRex
Audio files: 171
PostPosted: Fri Feb 13, 2009 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
can't you go into Audio Midi Setup (in Applications\Utilities) and modify them there? I know I can in my MOTU 2496, I would have thought that the 828 was similar.
Garret: It's so retro.
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Feb 13, 2009 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it has something to do with Logic. I can not do anything from Audio Midi Setup.
 Filesize:  50.58 KB
 Viewed:  5211 Time(s)
