Interested? |
No - no need for a FFB |
7% |
[ 3 ] |
No - not without real inductors |
5% |
[ 2 ] |
Yes - as long as you get "the sound" with your technology |
86% |
[ 33 ] |
Total Votes : 38 |
mono-poly
Joined: Jul 07, 2004 Posts: 935 Location: Rotterdam, Netherlands
Posted: Fri Mar 12, 2010 2:14 am Post subject:
Why not go for a Buchla 294/295 clone? |
TekniK
Posted: Fri Mar 12, 2010 5:44 am Post subject:
mono-poly wrote: | Why not go for a Buchla 294/295 clone? |
because this is already designed and i guess it sounds good.
Buchla clones is only for wanabee's
Only motivations plz,no de-motivations  |
jhaible
Posted: Sun Apr 04, 2010 7:37 am Post subject:
Update
This is just an update for the concept; not presenting any board previews yet. But I'm thinking about this project again.
Some people want inductors. Real inductors. They are hard to make - you basically have to wind your own coils - but some people want them anyway. And there are reasons for this. Inductors don't create noise. They may pick up noise/hum from an external source, but they don't contribute their own noise like Gyrator or GIC filters.
My concept, using the original Moog topology with GICs, will also allow the use of real inductors. So I plan to offer both options on the same PCB.
You can either populate the boards with low-noise GIG circuits (basically low impedance active circuitry with opamps that can drive the required current) - or you can omit the GIC stuff and use real inductors instead. I'll provide footprins for both (interleaved in order not to waste too much board space), and you can also use inductors with other form factor and connect them to the board with twisted wire.
There will also be an option to build the big filter bank (914) or the small one (907A), using a set of 3, or 2 PCBs.
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
The Bad Producer
Joined: Mar 08, 2009 Posts: 273 Location: The Manhole
Posted: Sun Apr 04, 2010 9:36 am Post subject:
I must say that does sound very interesting, but I have to ask ( ) will you be able to provide any info on how to make the inductors, or the specs so that we could possible source/make our own?
 _________________ http://loudestwarning.tumblr.com/ |
TekniK
Posted: Sun Apr 04, 2010 10:04 am Post subject:
With both option u made everyone happy.
Personaly,as long as i can fit the pcb(s) behind a 5u front am in,otherwise not. |
jhaible
Posted: Sun Apr 04, 2010 11:22 am Post subject:
The Bad Producer wrote: | I must say that does sound very interesting, but I have to ask ( ) will you be able to provide any info on how to make the inductors, or the specs so that we could possible source/make our own?
I did this some years ago for a handfull of inductors.
You choose a core with high aL factor, like this:
http://de.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2126609
and then you put on a few hundred turns of thin wire.
It's not as complicated as it sounds, but it takes time and it's more expensive than a GIC circuit with a decent dual opamp.
You can see one of these RM cores in my modified Farfisa VIP500. I needed a resonant circuit, and adding a single 560mH inductor was an easier solution than adding active circuitry in that case:
http://www.jhaible.de/farfisa/jh_farfisa.html
I had to put the inductor off-board to avoid the pick up of a magnetic field ( http://www.jhaible.de/farfisa/vip500_jh_LM_modifications_pic.jpg ), but normally, these cores can be soldered directly into a PCB.
jhaible
Posted: Sun Apr 04, 2010 11:26 am Post subject:
TekniK wrote: | With both option u made everyone happy.
Boards will be the same size as always, 160mm x 100mm
jhaible
Posted: Fri Apr 09, 2010 7:33 am Post subject:
Update:
http://www.jhaible.de/ffb/fixed_filter_bank.html
(No footprint for Inductors on the board as intended. But you can still use real inductors and mount them off-board.)
decaying.sine
Joined: Aug 31, 2009 Posts: 92 Location: New Haven, CT, USA
Posted: Sun Apr 11, 2010 6:26 am Post subject:
Interested in 1-2 boards. |
jhaible
Posted: Sun Apr 11, 2010 7:58 am Post subject:
decaying.sine wrote: | Interested in 1-2 boards. |
You will need at least 2 board, for the 907.
Or 3 boards, for the 914.
decaying.sine
Posted: Sun Apr 11, 2010 8:07 am Post subject:
Oops. I meant 1-2 sets of three boards  |
intercorni
Posted: Mon Apr 12, 2010 3:13 am Post subject:
I'd be very interested in 3 boards. |
keithwin
Posted: Mon Apr 12, 2010 4:56 am Post subject:
I would take at least 3 boards for a 914, possibly six.
cheers
Keith |
ach_gott
Posted: Mon Apr 12, 2010 1:00 pm Post subject:
I'm in for 6 (2x3). Poor backlog  |
TekniK
Posted: Mon Apr 12, 2010 3:58 pm Post subject:
Like i wrote before,am in for 2x2 pcb's |
forbin
Joined: Jan 29, 2009 Posts: 120 Location: Fremantle, Australia
Posted: Wed Apr 14, 2010 5:57 pm Post subject:
There are some quite useful tips for inductor winding and core sourcing on the Gyraf Audio website. They have a design for a Pultec equalizer that uses thermionic valves. Look under DIY and then Pultec at: http://www.gyraf.dk/ |
dcreatorx
Posted: Sat Apr 17, 2010 4:34 am Post subject:
boards |
I will take 1 set of 3 boards too Jurgen, let's go for it ! |
numbertalk
Posted: Thu Apr 22, 2010 8:27 am Post subject:
Count me in for a set - will probably opt for the 2-board 907 version. |
vtl5c3
Posted: Fri Apr 23, 2010 10:57 am Post subject:
I'm in for a pair, so I can make a 907 clone. I'll use the YuSynth layout to do the 914. More wallet friendly that way! |
jhaible
Posted: Sat Apr 24, 2010 11:18 am Post subject:
1. Enjoy the new pictures:
2. Do *not* buy a lot of OPA2134's for this, as the prewiew pictures did suggest.
Use NE5532 or better(!) RC4558 for alle those simulated inductors.
mono-poly
Posted: Sat Apr 24, 2010 4:26 pm Post subject:
Juergen is there info how many windings you need on the inductors etc? |
jhaible
Posted: Sat Apr 24, 2010 11:58 pm Post subject:
mono-poly wrote: | Juergen is there info how many windings you need on the inductors etc? |
I will publish the inductance of each inductor. The number of windings n then depends on the a_L of the core you choose:
L = a_L * n**2 =>
n = SQRT( L / a_L )
jhaible
Posted: Sun Apr 25, 2010 12:12 am Post subject:
I changed the thread title to adapt it to the latest development.
BTW, this modulte can be powered with +/-15V or +/-12V, so you can use it in +/-12V modular systems without changes.
And you can run it as a standalone module with a 16V AC wallwart or mains transformer, of course.
jhaible
Posted: Sun Apr 25, 2010 6:43 am Post subject:
I made some quick and dirty audio demos on the weekend - under suboptimal conditions, with allogator clips and field recorder, but I think it shows some of how this will sound:
http://www.jhaible.de/ffb/701_demo2.mp3
http://www.jhaible.de/ffb/701_demo1.mp3 (sorry for the hum - it's the dirty setup, not the filterbank)
Project description and pictures here:
PCBs will be available on 15.07.2010
jhaible
Posted: Mon Apr 26, 2010 7:39 am Post subject:
jhaible wrote: |
I will publish the inductance of each inductor |
http://www.jhaible.de/ffb/907_high_induct_discrete_psu_overlay.pdf
http://www.jhaible.de/ffb/907_low_induct_overlay.pdf
