Variable Slope Filter / Phaser
Page 8 of 8 [181 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8
interested?
yes
88%
 88%  [ 38 ]
no
11%
 11%  [ 5 ]
Total Votes : 43
The Bad Producer
PostPosted: Sat Apr 13, 2013 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've just pulled my module, and reverse engineered it (still can't believe I have no idea what I did there!)
I've drawn a diagram of the switch connections, hope it makes sense, the labelling for the contacts might be incorrect, but you'll get the idea!
Actually I wonder if it is right, seems to make sense I think...
sduck
PostPosted: Sat Apr 13, 2013 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I think that about nails it! Completely bypasses the mix pot when in the filter position. Good work!
The Bad Producer
PostPosted: Sun Apr 14, 2013 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, after playing around with it last night in more of a 'test' mode - rather than using it for music - I reckon you could do without the switch if you wanted, there doesn't seem to be any difference between pot full wet and switch on...
It IS useful as a performance on/off switch though, and for that reason alone I would include it...
Boerge
PostPosted: Tue Jun 11, 2013 12:21 pm    Post subject: Adjustment Reply with quote  Mark this post and the followings unread
Hi all,
trying to adjust the Varislope Filter I run into problems. I followed the steps on Jurgens website, but the only voltage I could adjust was the -7.5 Volts on R82, the other points never reach this voltage, for example the voltage on R71 doesnt go lower than ca. -3 Volts. I changed the three LM13700 and also the TL072 (U12), but no change. On pin 1 of U12 I measure ~10 Volts, can anybody confirm this? I had the cutoff pot not connected, the LFO depth pot in ccw position and the CV inputs shorted to GND.
regards
Boerge
...ich will doch nur löten...
sduck
PostPosted: Mon Jun 17, 2013 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
JoeMorris
PostPosted: Sun Apr 23, 2017 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I love my variable slope filter (that I built way back in 2009) - but I have noticed on the waveforms that the positive parts of the waveform are trunacted compared with the negtaive parts of the waveform, meaning a loss of bandwidth. Anyone with more knowledge than me have any ideas why this might be the case and how i might go about sorting it?
