Hi Hat Groove... err thingy!
dNRML
PostPosted: Fri May 22, 2009 6:44 pm    Post subject: Hi Hat Groove... err thingy! Reply with quote  Mark this post and the followings unread
Hiya, I'm not sure if this has been done a million times or is common. Im still very new to the G2 and the forums but I thought I should share this as I haven't or can't recall seeing it in any of the sequenced or drum patches I've checked out. And I wasn't entirely sure where to post this. It could be a building block I suppose. But this seems like the correct place.
Ok... so Im a lazy LAZY bones when it comes to making hi hat patterns. But while messing around trying to learn something useful about the logic gate, I stumbled on clock signals and the logic gate and managed to make a hi hat pattern generator of sorts. It sounds great with or without swing. Has a sort of open hat accent feature and is dead simple to use. Just mess with the the clock divider values to change the groove.
Anyway, again, sorry if this is a total newby patch. But what the heck! I just want to try and give back to the community, you guys rock.
The kick and snare are added to give a little something with the patterns so you have context with the patterns. Variations 1-4 are active. The rest are empty.
As a side note, you can use the logic gate's output to trigger envelopes on a bass synth or what have you, and have the "ValSwitch" modulate attack and decay to decent affect. It sort of makes a bit of an accompaniment to the beat. As the manual says... "Experiment" Very Happy
ALSO, please excuse the levels... I dont have monitors yet and so my mixing levels are very very very sad.
Hi-Hat_Patterns_.pch2
 Filename:  Hi-Hat_Patterns_.pch2
 Filesize:  2.62 KB
 Downloaded:  1013 Time(s)
xav
G2 patch files: 7
PostPosted: Sat Feb 26, 2011 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks,
I love that!
