how strenuous a task is to insert an expansion board ?
Page 1 of 1 [6 Posts]
bolizar
PostPosted: Thu Jun 04, 2009 2:44 pm    Post subject: how strenuous a task is to insert an expansion board ? Reply with quote  Mark this post and the followings unread
...by yourself
PostPosted: Thu Jun 04, 2009 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
It only takes a philips head screw driver. Very easy. Anyone can do it in under 15 minutes. That includes time to stare in wonder at the inner beauty of the G2.
Did you buy the expansion already? dit comes with instructions for the whole process.
bolizar
PostPosted: Thu Jun 04, 2009 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey there supa, thanks for the quick reply,
well not yet actually, theres a guy on a local used gear site that sells it for 500 euros....is that a good price ?
I was contemplating buying it but dont even have enough funds anyway atm
PostPosted: Fri Jun 05, 2009 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check this link first:
http://electro-music.com/forum/viewtopic.php?highlight=expansion+card&t=33288
I'm not sure about prices in europe.
buzzr
PostPosted: Fri Jun 05, 2009 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's easy as pie....
Audio files: 369
PostPosted: Fri Jun 05, 2009 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup, I did it, no problem. You can always stumble and run a screwdriver straight into the thing if you have momentous bad luck, but usually it will be a breeze.
/Stefan
