Front panel sticker?
Page 2 of 2 [27 Posts]
Goto page: Previous 1, 2
Broadwave
Audio files: 6
PostPosted: Tue Oct 09, 2012 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
@isak - Adobe Illustrator (I'm still on CS3) is fairly simple to use, but any decent "Vector" graphics program will do. I used to use Corel Draw on a PC before I switched to a Mac.
@ DES - No I've not tried that. I've deliberately kept away from an Alu finish, as I didn't want it to look like a Doepfer system Wink
@elmegil - I got a set of 6 punches from eBay that does holes from 3 - 8mm. Just line up the punch with the holes you need, and whack it with a hammer. You end up with perfectly round holes, and it's also a great stress reliever!!!
I tried a home laminator but I found that the artwork warped too much. My local print shop uses a much thicker laminate... you end up with perfectly flat artwork, so you don't have to worry about floppy edges Very Happy
Synth DIY Projects
Musical Doodlings
isak
PostPosted: Tue Oct 09, 2012 11:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Andy.
I started to work with illustrator yesterday, looks fairly easy.
Thanks for the advice Smile
