Vosim Processor
Page 1 of 1 [20 Posts]
andrewF
PostPosted: Sun Jul 05, 2009 6:35 am    Post subject: Vosim Processor
Subject description: VOice SIMulation
Hi all
i started a page to document a build of this module
vosim
The article & schematic were in Electronotes #130 (pages 3-10).
I have never found any other info on this design so decided this thread and my page will have to do. There are various versions of it for the Nord and in software.
just etched the PCB so far, when/if it gets finished and works will get some 'scope shots and samples up.
Has somebody built one of these?
creatorlars
PostPosted: Sun Jul 05, 2009 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Very interesting. I have an extra 633 laying around so I'll be keeping an eye on this! Smile Thanks for documenting and sharing.
cloudscapes
PostPosted: Sun Jul 05, 2009 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting! I've got a couple 633's lying around as well
Sonic Crayon DIY effects lab
PostPosted: Sun Jul 05, 2009 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
arrgh. my EN collection ends with issue 108.
maybe i should complete it!?
fluxmonkey
PostPosted: Mon Jul 06, 2009 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
kewl. i've had my eye on that project for a while, even scored a pair of AD533s (hellish expensive) for the purpose. what changes did you have to make to use the 633? (beyond the change from round to DIL footprint).
will follow yr progress, thanks for sharing!
bbob
www.fluxmonkey.com
andrewF
PostPosted: Mon Jul 06, 2009 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
It is the 1st time I have used an AD633, so just read thru the datasheet and compared it to the AD533.
in the AD633 datasheet fig.4 Pg.4 shows how to connect it to act as a squarer/freq doubler with a positive output, which seems to be the purpose of the AD533 in the Vosim.
I am hoping this will work as is and the trimpots will not be required, nor will the output amplitude need to be adjusted (optimist Laughing ).
if the trimpots are needed they can be accessed with just some links and if the output is too low i have placed holes to put resistors as necessary that will increase the output. You can see examples of how this is done on fig.5 and fig.8 (with equations)
Of course a few track changes, nothing very difficult - 20 minutes in photoshop
Probably the PCB could be reduced to half its size using quad op-amp packages, but let's see what its like 1st.
synthmonger
PostPosted: Sat Jul 11, 2009 10:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
anything new? Very interested in this.
Youtube!
modular demos!
Whacky tunes!
andrewF
PostPosted: Sun Jul 12, 2009 4:38 am    Post subject: Reply with quote  Mark this post and the followings unread
naa just etched the PCB so far
been caught up in another project - which is almost completed
hopefully will stuff&test it this week
widdly
PostPosted: Sun Jul 12, 2009 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it the same as the Kaegi VOSIM?
Repeating enveloped sin^2 burst followed by silence where the length of the burst + length of silence is the period of the fundamental and the sin is period of the formant?
I was thinking that you could approximate PAF synthesis on a modular.
output
VCA c--- sin wave oscillator at Formant frequency
Lag generator with separate rise/fall controls (controls bandwidth and skirt)
offset by 5v
A pulse wave at the fundamental
Alternatively you could replace the pulse/offset/lag with a VCS envelope.
andrewF
PostPosted: Sun Jul 12, 2009 7:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes Kaegi's
this cct could be hooked up with modules but I don't think it would be exactly the same as the E/N cct.
back in 07 I asked about the Vosim on the E-M Nord forum - here
some interesting replies and MP3s to check out
widdly
PostPosted: Tue Jul 14, 2009 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting. I'll have to try out some of those nord patches.
I've been playing with the paf~ generator in pd and day dreaming about getting an FS1r
andrewF
PostPosted: Wed Jul 22, 2009 2:15 am    Post subject: Reply with quote  Mark this post and the followings unread
just an update.
PCB stuffed and partly wired up
started thinking about the sync out.
The Vosim processor needs to be able to switch the VCO off to create pauses.
This is done in a similar fashion to hard sync on many VCOs, the difference is a regular hard sync usually has a cap, say 100pF, on the input path, meaning the sync signal is just a pulse, just enough to briefly short the cap.
so although the Vosim label says 'sync out' it is not sync as we know it.
i had a look around and decided Thomas Henry's VCO 1 would be suitable, it has a good sine out, only needs a 3080 and a quad opamp (without the pulse out subcircuit) and some people have already tested placing a fet over the intergrator cap to sync it.
so gotta build a new VCO.
am considering building a standalone synth based on this cct. To operate, it also requires an EG or LFO. A couple of those, maybe a joystick or Serge touch responsive switch and it'll be singing Daisy Bell....no worries Laughing
 Filesize:  50.14 KB
 Viewed:  10580 Time(s)
andrewF
PostPosted: Fri Jul 24, 2009 1:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Finished and works
vid and some build info here
fluxmonkey
PostPosted: Fri Jul 24, 2009 7:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
inspiring! good work.
www.fluxmonkey.com
andrewF
PostPosted: Thu Dec 10, 2009 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finally got this one into a panel on my minisyn :
some more sounds from it
here
and
here
on my Vosim page.
These were made with Ian's Jerkster humping the leg off a Thomas Henry VCO, the VCO sine out is hardwired to the Vosim input and the Vosim sync out does its duty to the OTA in the VCO. Nothing else, I just tweaked the settings of the Vosim here'n'there
synthmonger
PostPosted: Thu Dec 10, 2009 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now this sounds fun! Wink
Youtube!
modular demos!
Whacky tunes!
andrewF
PostPosted: Mon Sep 27, 2010 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a footnote regarding this module. The original designer, Dev Gualtieri, sent me an nice email this morning with pix of his original VOSIM and some of his synths he built back in the seventies.
He okay'd me to post them -
http://www.sdiy.org/pinky/vosim/vosim.html
scroll down
yusynth
PostPosted: Tue Sep 28, 2010 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent, I like those pictures of early synths and prototypes. Makes us feel a lot more humble Wink
Yves
andrewF
PostPosted: Tue Sep 28, 2010 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Definitely - imagine building all that without internet
TheAncientOne
PostPosted: Wed Sep 29, 2010 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
For those who want to 'Try before building', there is a VOSIM generator in CSound.
Some later experimenters used other wave shapes, and kind of generalised VOSIM into a branch of granular synthesis.
There are a few references in Curtis Roads book "The Music Machine". All the original papers are either locked into the dreaded JSTOR, or the AES who want $20 for a download.
Stan Tempelaars book "Signal Processing, Speech and Music" has more details, though it's not a cheap book, unless you can find a bargain second hand copy.
I think you'd need bunch of MARF style envelope generators to control the thing properly. The samples sounded amazing, though.
Brilliant job!
Mike
