Jez or Rob's Adventures in Sound
Page 3 of 46 [1133 Posts]
Goto page: Previous 1, 2, 3, 4, 5, ..., 44, 45, 46 Next
Audio files: 263
PostPosted: Sat Oct 10, 2009 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
EdisonRex wrote:
Dark and ambient, but very satisfying. Smile
Thanks Paul Smile
It was literally an 'adventure in sound' for me Cool
Audio files: 263
PostPosted: Wed Oct 14, 2009 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
any clues as to what might be on tonight's show Rob?
Audio files: 347
PostPosted: Wed Oct 14, 2009 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight is one song, the exploration of small things, lingering on the spot, and possibly moving a little here and there too.
Muied Lumens Base Star
Audio files: 263
PostPosted: Wed Oct 14, 2009 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
'sounds' interesting Smile
shanemorris
Audio files: 83
PostPosted: Wed Oct 14, 2009 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool Stuff Rob! Great #2! Laughing
ElectroCasa
Audio files: 216
PostPosted: Wed Oct 14, 2009 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great adventure, some cool stuff - the singing was nice!
Audio files: 347
PostPosted: Thu Oct 15, 2009 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you all for tuning in. Smile
The set yesterday was in many ways influenced by other shows here on the electro-music radio, even if it may not be immediately apparent. At the end I played a track made previously, called "the snowflake effect", featuring a pitched down blackbird from Norway.
This is an edited version because I had one or two unintended silent moments during the show. Embarassed
rob-ais2.mp3
Rob's second AIS performance, 14th October 2009 - "Deeper into the sky".
 Filename:  rob-ais2.mp3
 Filesize:  53.69 MB
 Downloaded:  1018 Time(s)
PostPosted: Fri Oct 16, 2009 3:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Just listened through it (unfortunately Jez And Rob's adventures is a little too much past bedtime for me to listen live) - marvellous! That blackbird was pretty eerie. alien
/Stefan
Audio files: 347
PostPosted: Fri Oct 16, 2009 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Antimon. Smile
After Jez' show next week, Sweden will turn the clocks back one hour for daylight saving hours (25th of October), so the show will be one hour earlier. Maybe that will help?
EdisonRex
Audio files: 171
PostPosted: Fri Oct 16, 2009 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, Rob, I listened to it. I really enjoyed the show. I wonder where you get your inspirations? Cool
Garret: It's so retro.
Audio files: 347
PostPosted: Fri Oct 16, 2009 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Big influence from you! Smile I tried to do some solos, but I desperately need to work on my timing and keyboard work. I had some inspiration in the structure of how the shows are set up as well, and the pad sounds you use. Smile
Les' vocoder gave me some ideas, as did Jez' tweakings, Jan's noodles and Shane's Space Port. The radio is so full of talent (not to mention knowledge and skills!) that that it makes me feel all warm and fuzzy inside being part of it. Very Happy
PostPosted: Fri Oct 16, 2009 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, it's that time of year again. I think I'll try to do a couple of late night wednesdays...
Edit: removed imposing picture to keep the thread focus
/Stefan
Audio files: 263
PostPosted: Wed Oct 21, 2009 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's show will feature some improvised kaossillations and some microkorg and will be a sort of companion piece to my last show as it features the other half of the equipment I will be taking to EM-2009
Audio files: 263
PostPosted: Fri Oct 23, 2009 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Episode 5 came together at the very last minute, using my new Kaossillator and mini-KP with my microKorg and Boardweevil and DD-20 for live looping. I enjoyed it Smile
Adventures_In_Sound_005_211009.mp3
Adventures In Sound - Episode 5 - Kaoss Improv
 Filename:  Adventures_In_Sound_005_211009.mp3
 Filesize:  68.84 MB
 Downloaded:  1727 Time(s)
Audio files: 216
PostPosted: Fri Oct 23, 2009 5:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
modulator_esp wrote:
I enjoyed it Smile
You were not alone in that Laughing
Audio files: 263
PostPosted: Fri Oct 23, 2009 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I enjoyed it Smile
Thanks Jan
and thanks for listening
Audio files: 347
PostPosted: Wed Oct 28, 2009 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight is a little bit of a stunt, using only images to create sound. Attached is a long image that does not only represent the audio you are hearing in tonight's show, it is the composition itself, which has been used directly to create what you hear.
To read it, start from left and work your way through to the end. Horizontal lines convert into tones, while big bright areas convert into noise. Top is high frequencies and bottom is low frequencies. Brightness indicates loudness, and colour has no effect, apart from making it a little bit more interesting to look at.
It may be difficult to follow exactly what is happening, because the image is linear (in terms of frequency) while the sound itself is logarithmic. Therefore, a lot of frequency information lies in the bottom tenth of the image... If you have problems following the score, log into the chat and I'll give you a pointer as to where we are. Smile
The image below was converted to sound using Adobe Audition 3, and edited in Gimp. There is a lot of scope for more experimentation, as you can also export audio from AA3, but I have restricted myself to only going one way this time.
All the effects that you hear in the track are from the image editing. I did some subtle tweaking after converting the image to sound, notably making it stereo and adjusting levels a bit.
I hope you enjoy it. Smile
Oh, and the image may take some time to load, even though I have tried everything in my power to make it as light as possible. (The original image is similar in size to the audio file...)
Edit: I have updated the image with time cues every 2.5 minutes so it is easier to follow where you are. They are not exact to the second but they are close enough for the purpose they hold. Know that the blue vertical lines and the time indicators are not part of the sound (everything else in the image is). The sound file has also been attached to this post.
The "score" for AIS image to sound project 28th of October 2009. Follow this while listening to the sound file AISsound6.
 Filesize:  7 MB
 Viewed:  401 Time(s)
AISsound6.mp3
The sound for AIS image to sound project 28th of October 2009. If you are interested, the image that was used to create this track is AISscore6.jpg.
 Filename:  AISsound6.mp3
 Filesize:  55.71 MB
 Downloaded:  1079 Time(s)
Audio files: 347
PostPosted: Wed Oct 28, 2009 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also note that the show starts one hour earlier tonight, in countries which changed from summer to winter time this weekend.
Audio files: 263
PostPosted: Sun Nov 01, 2009 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
downloading now Smile
Audio files: 263
PostPosted: Tue Nov 03, 2009 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
listened to it last night, sounded good with the planes flying over Smile
Audio files: 263
PostPosted: Tue Nov 03, 2009 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've spent a lot of today putting my episode together
It's a sonic travelogue made up of field recordings with added stuff
Danno Gee Ray
PostPosted: Tue Nov 03, 2009 7:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any crickets?
Audio files: 263
PostPosted: Tue Nov 03, 2009 7:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Danno Gee Ray wrote:
Any crickets?
Oh yes, there certainly is, many thanks for telling me about him, as well as the cricket there's some other stuff from Star Lake, including the infamous door slam and some rain and even a couple of guest speakers, but they got a bit buried in the mix.
Danno Gee Ray
PostPosted: Tue Nov 03, 2009 8:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool.
Audio files: 263
PostPosted: Mon Nov 09, 2009 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Episode 7 of Adventures In Sound was produced in my hotel room in Newark on the 3rd November using field recordings from Star Lake Camp, improvised sample based pieces recorded during electro-music 09, field recordings from a trip into New York, drones produced on the morning before I left for electro-music and an improvised piece recorded in my hotel room using a Yamahe VSS30, Mini KP and DD-20 looper.
Thanks to Rob for streaming it for me on Wednesday 4th November
The field recordings used in this set are now available here
Adventures_In_Sound_007_041109.mp3
Adventures In Sound - Episode 7 - Drones in the USA
 Filename:  Adventures_In_Sound_007_041109.mp3
 Filesize:  54.93 MB
 Downloaded:  1758 Time(s)
