  Antimon Antimon Waves
 Forum index » Instruments and Equipment » Cubase
Help with Midi Device
Stomper
PostPosted: Tue Oct 06, 2009 12:38 pm    Post subject: Help with Midi Device
Subject description: Cubase 5
Im struggeling with installing a new midi device (which is not in the list), i went trough the manual a few times but it doesnt work as it should be.
I tried searching on youtube for one, but all i got was the same tutorial that is on the DVD which explain how to install one that is listed.
im realy desperate here with this issue so ill be glad if anyone can point out the right direction.
I did manage to get it to work, just not as it should be.
The GUI only opens if i press the 'open user panels' on the midi channel strip. but it doesnt open like you would open a VSTi GUI. insted im getting the external instrument settings (delay and return gain).
The 'user panel' in the inspector are blank and the parameters get set back to defulte every time i open the GUI (WTF?).
All the knobs work though and changes what they should in the external synth and i can also automate (need to enable read every time i open a project).
so i think i did got close, but still not as it should be.
i went through the manual again and again and again, but cant find what im doing wrong.
Regards,
Stomper.
