AC DC VCA Quick question
Page 1 of 1 [12 Posts]
joshco
PostPosted: Sun Oct 25, 2009 4:05 am    Post subject: AC DC VCA Quick question Reply with quote  Mark this post and the followings unread
Hello,
Currently I´m building some VCA´s, theres a DC and a AC Version.
What does this mean in general, are there any differences in sound or in amplification?
best regards
yusynth
PostPosted: Sun Oct 25, 2009 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
The AC version is solely dedicated to process audio signals that's why there are capacitors in series with the INPUTS. These capacitors are there to filter out any DC component.
The DC version is more versatile because it can be used for processing either CVs or audio signals.
Yves
joshco
PostPosted: Sun Oct 25, 2009 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Allright, the caps remove the dc signal in the audio material, whereas the DC version is able to amplify DC signals too.
Thank you!
robboten
PostPosted: Mon Feb 25, 2013 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
In the schematic for the simple VCA module there are two stars at the LED and the circuit around it. Does that mean that the LED only works with the AC version? That could explain why I get no light... And if so, is it possible to have light with the DC version as well?
yusynth
PostPosted: Tue Feb 26, 2013 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
If you have installed all these optional components and use it in DC mode then the LED can bright but only for a negative input voltage. The LED circuit was designed for AC only as indicated.
Yves
robboten
PostPosted: Tue Feb 26, 2013 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I see. Thank you for your reply!
And also a big <3 for all your work on the modules you have published! I just love everything about them! The clearness of the pictures, the easy to follow schematics, the pcb-layouts and the functions. For me as a noob on the field this has helped me understand so much! Build my fourth module today (Noise, VCA, ADSR, S&H) and is so happy about it all! Next up is a mixer or the Steiner VCF. Probably ending up with all of them sooner or later... it's so much fun! So thank you again so much!
dancelwerk
PostPosted: Mon Aug 17, 2015 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi to all, I want to build the DC version but I have no clear what components I have to remove,
is * for the components AC and ** for the DC or viceversa?
I want to say, if I build the DC version, should i be remove Q4, D1, and C3 and C4?
thanks in advance.
Fernando.
alanwilder81
PostPosted: Mon Sep 05, 2016 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
a big thanks to Yves Usson for delivering us such amazing material and schematics. i am trying to build my own synth, and i have a couple of questions regarding the student project supervised by T. Rochebois : building a small analogue synth
http://yusynth.net/index_en.php?&arg=1
has any of you ever built that nice CV GATE TRIGGER keyboard controller?
it looks amazingly simple and low components count.
if Yves or anyone else may give me a help, it would be greatly appreciated.
cheers Very Happy
yusynth
PostPosted: Tue Sep 06, 2016 1:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
No I haven't built it, but it was a student project that was successfully completed and the schematics published by Thierry were all tested therefore I guess you may be pretty confident in these. I see no flaw in them.
Yves
alanwilder81
PostPosted: Fri Oct 07, 2016 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
hi gang,
i succesfully built the US1 VCA. It works,though exibits a very annoying "pop" or "click" on the beginning of the ADSR sound articulation.
Any ideas? thanks.
 Filesize:  45.85 KB
 Viewed:  107 Time(s)
yusynth
PostPosted: Sat Oct 08, 2016 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Either you didn't match the transistors of the differential pair or you did not adjust the trimmer correctly. Also you should use 1% tolerance for the resistors auround the second 741.
Yves
alanwilder81
PostPosted: Sun Oct 09, 2016 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks very much Yves as usual
