weird synth box that uses lots of 10K pots
Page 1 of 1 [8 Posts]
wax+wire
PostPosted: Wed Apr 20, 2016 1:08 am    Post subject: weird synth box that uses lots of 10K pots Reply with quote  Mark this post and the followings unread
Hi.
I have a bunch (16) of 10K pots from an old project. I want to reuse them and make a weird noise synth box (like an APC) perhaps with CV in and a simple step sequencer.
Any recommendations on circuits that exist out there that use predominantly 10K pots ?
thanks in advance
fiveman
PostPosted: Sun May 29, 2016 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
An EMS VCS3 Mk1 uses all 10k pots
J-chot
PostPosted: Sun May 28, 2017 9:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
If they are audio tapered, you could make a matrix mixer....
Audio files: 29
PostPosted: Sun May 28, 2017 10:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've got a load of 5K 9mm pots I should find a use for...
Skysurfer
PostPosted: Mon Oct 09, 2017 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
In the same boat ~200 50K linears that need a project.
haebbmaster
PostPosted: Mon Oct 09, 2017 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
16 step 12 Track sequencer
Make modular synthesizers great again!
Modular Synthesizer DIY blog: http://modular.haebbmaster.de
PostPosted: Mon Oct 09, 2017 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Benjolin uses 11 10K pots...
http://electro-music.com/forum/forum-185.html
Edit: Actually, the original probably only uses 7. But some common mods for CV ins and audio in to the filter gets you up to 11
LFLab
PostPosted: Fri Oct 13, 2017 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Build a double benjolin, for ultimate cross modulating madness!
