AUDIO/MIDI impossible to set
erasmo52
PostPosted: Sat Nov 14, 2009 12:41 am    Post subject: AUDIO/MIDI impossible to set Reply with quote  Mark this post and the followings unread
Installed the Nord Modular G2 Demo 1.40 version under Windows XP and it works finely.
But if I install it under Windows Vista 32 Bit it is impossible for me to set the AUDIO/MIDI. When I go in Setup Menu and I select AUDIO/MIDI, I receive an error message telling me "Not enough memory". Why?
There is any external interface connected.
Can somebody tell me something to fix my problem?
Erasmo
PostPosted: Sat Nov 14, 2009 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
If the software does not explicitly say thats it's compatable with Vista 32, then there is no guarantee that it will work under that OS.
The fix would be to continue to run it under XP sorry to say.
Bill
PostPosted: Sat Nov 14, 2009 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome Erasmo,
You could try compatibility mode ... right click on the icon, select properties, go to the compatibility tab and try some different settings there.
It probably is an issue with a driver ... here on this Vista the program just works as is.
