noob : no sound with examples
twilightz0ne
PostPosted: Fri Dec 18, 2009 2:25 pm    Post subject: noob : no sound with examples Reply with quote  Mark this post and the followings unread
Hello ,
I installed chuck but i dont hear any sound from the examples .
Im running chuck in cmd on vista.
I hope there is anyone hear who can help me.
Quite annoying to want to play with a sound when you dont hear any.
this is my first take at audio programming but i program in java a lot
I hope there are some chuck goeroes around here who can help ...
this is my probe
[chuck]: found 6 device(s) ...
[chuck]: ------( chuck -- dac1 )---------------
[chuck]: device name = "Primair geluidsstuurprogramma"
[chuck]: probe [success] ...
[chuck]: # output channels = 2
[chuck]: # input channels  = 0
[chuck]: # duplex Channels = 0
[chuck]: default device = YES
[chuck]: natively supported data formats:
[chuck]:    8-bit int
[chuck]:   16-bit int
[chuck]: supported sample rates:
[chuck]:   100 Hz
[chuck]:   200000 Hz
[chuck]:
[chuck]: ------( chuck -- dac2 )---------------
[chuck]: device name = "Speakers (Realtek High Definition Audio)"
[chuck]: default device = NO
[chuck]:    8-bit int
[chuck]:   16-bit int
[chuck]:   100 Hz
[chuck]:   200000 Hz
[chuck]:
[chuck]: ------( chuck -- dac3 )---------------
[chuck]: device name = "Realtek Digital Output(Optical) (Realtek High Definition Audio)"
[chuck]:    8-bit int
[chuck]:   16-bit int
[chuck]:   100 Hz
[chuck]:   200000 Hz
[chuck]:
[chuck]: ------( chuck -- dac4 )---------------
[chuck]: device name = "Realtek HDMI Output (Realtek High Definition Audio)"
[chuck]:    8-bit int
[chuck]:   16-bit int
[chuck]:   100 Hz
[chuck]:   200000 Hz
[chuck]:
[chuck]: ------( chuck -- dac5 )---------------
[chuck]: device name = "Primair stuurprogramma voor opnemen van geluid"
[chuck]: # output channels = 0
[chuck]: # input channels  = 2
[chuck]:    8-bit int
[chuck]:   16-bit int
[chuck]:   11025 Hz
[chuck]:   22050 Hz
[chuck]:   44100 Hz
[chuck]:
[chuck]: ------( chuck -- dac6 )---------------
[chuck]: device name = "Vastleggen (Pinnacle PCTV 310i Capture Device)"
[chuck]:    8-bit int
[chuck]:   16-bit int
[chuck]:   11025 Hz
[chuck]:   22050 Hz
[chuck]:   44100 Hz
[chuck]:
[chuck](via RtMidi): RtMidiIn::initialize: no MIDI input devices currently available.
[chuck]: ------( chuck -- 0 MIDI inputs )------
[chuck]:
[chuck]: ------( chuck -- 1 MIDI outputs )-----
[chuck]:     [0] : "Microsoft GS Wavetable Synth"
[chuck]:
this is my verbose output when i try to run a sample : in this case larry++
C:\chuck-1.2.1.3\chuck-1.2.1.3-exe\examples\basic>chuck -v larry++.ck
[chuck]:(2:SYSTEM): setting log level to: 5 (INFORM)...
[chuck]:(2:SYSTEM): initializing virtual machine...
[chuck]:(2:SYSTEM):  | behavior: HALT
[chuck]:(2:SYSTEM):  | locking down special objects...
[chuck]:(2:SYSTEM):  | allocating shreduler...
[chuck]:(2:SYSTEM):  | allocating messaging buffers...
[chuck]:(2:SYSTEM):  | real-time audio: YES
[chuck]:(2:SYSTEM):  | mode: CALLBACK
[chuck]:(2:SYSTEM):  | sample rate: 44100
[chuck]:(2:SYSTEM):  | buffer size: 512
[chuck]:(2:SYSTEM):  | num buffers: 8
[chuck]:(2:SYSTEM):  | devices adc: 0 dac: 0 (default 0)
[chuck]:(2:SYSTEM):  | adaptive block processing: 0
[chuck]:(2:SYSTEM):  | channels in: 2 out: 2
[chuck]:(2:SYSTEM): initializing compiler...
[chuck]:(3:SEVERE):  | initializing type checker...
[chuck]:(3:SEVERE):  |  | adding base classes...
[chuck]:(3:SEVERE):  |  |  | class 'object'
[chuck]:(3:SEVERE):  |  |  | class 'array'
[chuck]:(3:SEVERE):  |  |  | class 'string'
[chuck]:(3:SEVERE):  |  |  | class 'ugen'
[chuck]:(3:SEVERE):  |  |  | class 'uanablob'
[chuck]:(3:SEVERE):  |  |  | class 'uana'
[chuck]:(3:SEVERE):  |  |  | class 'shred'
[chuck]:(3:SEVERE):  |  |  | class 'event'
[chuck]:(3:SEVERE):  |  |  | class 'io'
[chuck]:(3:SEVERE):  |  |  | class 'fileio'
[chuck]:(3:SEVERE):  |  |  | class 'class'
[chuck]:(3:SEVERE):  | initializing emitter...
[chuck]:(3:SEVERE):  | loading built-in modules...
[chuck]:(3:SEVERE):  |  | module osc...
[chuck]:(3:SEVERE):  |  | module xxx...
[chuck]:(3:SEVERE):  |  | module filter...
[chuck]:(3:SEVERE):  |  | module STK...
[chuck]:(3:SEVERE):  |  | module xform...
[chuck]:(3:SEVERE):  |  | module extract...
[chuck]:(3:SEVERE):  |  | class 'machine'...
[chuck]:(3:SEVERE):  |  | class 'std'...
[chuck]:(5:INFORM):  |  | initializing KBHitManager...
[chuck]:(5:INFORM):  |  | starting kb loop...
[chuck]:(3:SEVERE):  |  | class 'math'...
[chuck]:(3:SEVERE):  |  | class 'opsc'...
[chuck]:(2:SYSTEM): type dependency resolution: MANUAL
[chuck]:(2:SYSTEM): initializing synthesis engine...
[chuck]:(3:SEVERE):  | initializing 'dac'...
[chuck]:(3:SEVERE):  | initializing 'adc'...
[chuck]:(3:SEVERE):  | initializing 'blackhole'...
[chuck]:(2:SYSTEM):  | initializing 'real-time' audio...
[chuck]:(5:INFORM):  |  | initializing callback...
[chuck]:(3:SEVERE):  | allocating buffers for 512 x 2 samples...
[chuck]:(3:SEVERE): starting compilation...
[chuck]:(5:INFORM): setting thread priority to: 2...
[chuck]:(2:SYSTEM): starting listener on port: 8888...
[chuck]:(2:SYSTEM): running virtual machine...
[chuck]:(3:SEVERE):  | initializing audio buffers...
[chuck]:(3:SEVERE):  | virtual machine running...
[chuck]:(5:INFORM): (sndbuf): reading 'special:glot_pop'...
[chuck]:(3:SEVERE): starting real-time audio...
[chuck]:(3:SEVERE): starting real-time watch dog processs...
[chuck]:(5:INFORM):  | watchdog timeout: 0.500000::second
[chuck]:(5:INFORM):  | watchdog thread priority: 2
[chuck]:(5:INFORM):  | watchdog countermeasure priority: -2
[chuck]:(3:SEVERE): real-time watchdog counter-measure activating...
Kassen
PostPosted: Fri Dec 18, 2009 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Strangely none of the converters that have outputs indicate supporting normal sample rates. I'm at a loss here, I don;t know enough about Vista's audio.
If your soundcard supports ASIO you could try the ASIO version from this forum? That would be a interesting test.
Kassen
twilightz0ne
PostPosted: Sat Dec 19, 2009 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
no ASIO support ...
Kassen
PostPosted: Sat Dec 19, 2009 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Very odd.
You aren't accidentally running something that might be laying claim to the soundcard? What heppens if you try to run a example after closing all other programs that could make a sound? Did you try compatibility mode?
I'm starting to suspect there may simply be a bug in how RTAudio (the library that we use for sound in/out) interacts with Vista. We do need to update the version of RTAudio that we are using anyway.
Do we have any Vista experts around?
Kassen
