 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
Weather Forecast
modular
G2 patch files: 72
PostPosted: Wed Oct 20, 2004 12:00 pm    Post subject: Weather Forecast Reply with quote  Mark this post and the followings unread
This is the my Dual Moods patch where I switched on Arpeggiator in every variations added control changes modules to control things in patch.
I've rearranged all with new seven variations (var. 8 is substantially the same of the original patch where now I control the morph group with CC)
I think this patch setup with its modules so combined, and rob's dual filter
inserted, allow to produce many interesting variations and lot of possible solutions. So I'll continue to work on it , next step could be make this as part of a slot performance and add sequencers modules to build a noodle.
Weather Forecast.pch2
Arpeggiator based patch but with a lot of possibilities to manipulate it
 Filename:  Weather Forecast.pch2
 Filesize:  6.46 KB
 Downloaded:  1825 Time(s)
Audio files: 228
PostPosted: Wed Oct 20, 2004 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, these sounds have balls...
