  Les Hall The Les Hall Show
2010 Build Pictures
Page 2 of 24 [576 Posts]
Goto page: Previous 1, 2, 3, 4, ..., 22, 23, 24 Next
strategy
PostPosted: Sun Feb 07, 2010 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is the Gristleizer done from the PCB issued recently on this forum and at and on diystompboxes.com.
I shall use it to start a Throbbing Gristle cover band, tentatively named Pulsating Tissue. (Just kidding)
I don't recommend building the fuzz pictured with this device, it is a complicated build and very difficult to dial in sensible settings with.
- Strategy
community-library.net/strategyhome.htm
creekree
PostPosted: Sun Feb 07, 2010 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
who would've thought that i actually would get something finished eventually maybe?
emerging from my pile of almost-ready-but-missing-one-component soon-to-be-not-just-electronic-junk-anymore-stuff i give you STOMPIT!
this is a dual ken stone stomp box adapter that a friend asked me to make for his doepfer system. lots of recycled components (check those HUGE resistors!) and my own pcb layout. frontpanel turned out not as good as i hoped - the darker spots are supposed to look like dripping spraypaint but do a poor job at it.
apart from that the thing works great. because i am such a good friend i even wrote him a manual Laughing
 Filesize:  82.52 KB
 Viewed:  186 Time(s)
 Filesize:  86.38 KB
 Viewed:  200 Time(s)
Audio files: 124
PostPosted: Sun Feb 07, 2010 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
[quote="strategy"]
Cool build, 'hmm is this edible i wonder' Smile
epicyclus@skrogmusic.plus.com
Audio files: 124
PostPosted: Sun Feb 07, 2010 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
creekree......
that's great , i will have to get mine finished, i see behringer do a multi FX stompbox , seen them under £30.00 new on ebay..
-minus-
PostPosted: Thu Feb 11, 2010 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Completed moments ago, my first device for 2010: an Art Harrison 'Cocophonator'.
http://theremin.us/Circuit_Library/cacophonator.html
Built on stripboard with a RGB colour change LED mounted in the central pot.
Now to wake up the neighbourhood at 4.50AM! Twisted Evil
Apologies for the dodgy photos taken using a phone... I'll edit and post better ones when I get my hands on a camera.
 Filesize:  307.94 KB
 Viewed:  182 Time(s)
 Filesize:  348.45 KB
 Viewed:  174 Time(s)
strategy
PostPosted: Thu Feb 11, 2010 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I really like the "LED knob" is that something you can get like that off the shelf, or did you modify the knob to accommodate the LED?
Cool build!
- Strategy
http://home.att.net/~theremin1/Circuit_Library/cacophonator.html
-minus-
PostPosted: Thu Feb 11, 2010 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
No, I modified an existing knob. Cut a bit off the top off a spline shaft metric pot to accommodate the LED. Fed the plastic insulation off some wire onto the legs of the LED to insulate them, then slotted the LED legs into the slot cut into the pot shaft. Had to pry the slot open a bit to get the legs in! I drilled a hole in the top of the knob for the LED to poke through. Had to file the collar of the LED a bit to make it fit.
Under the pot knob, I drilled a hole into the box to feed the wires in. Would have been a lot easier had I mounted the LED off centre... like a pointer or something. Still, it wasn't impossible. The LED automatically changes from red to green to blue to purple to pink etc...
macumbista
PostPosted: Fri Feb 12, 2010 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my take on the Makenoise Maths, built with CGS PCBs.
Full details:
http://macumbista.net/?p=421
Front panel (designed in Inkscape):
Audio clip (Soundcloud):
http://soundcloud.com/macumbista/voltage-controlled-slopes-analog-logic-test
Synth-pr0n!:
At home in the full system (module in lower right corner):
...which is documented here:
http://macumbista.net/?page_id=529
Enjoy!!!!
Derek
Esoteric drones and nonlinear distortion
Custom/handmade experimental instruments
macumbista.net
The Bad Producer
PostPosted: Fri Feb 12, 2010 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is great Derek!
I've been toying with a Eurorack panel for two of these, but you've inspired me (after listening to your demo, and seeing your synth) to add the Analogue Logic board to mine as well, thanks!
This is the version without:
Charlie
PS Sliders arrived safely, thank you sooo much!
http://soundcloud.com/thebadproducer
Audio files: 31
PostPosted: Fri Feb 12, 2010 10:54 pm    Post subject: So far, so good for 2010 Reply with quote  Mark this post and the followings unread
Just finished populating the Klee Sequencer boards and an MPS board.
I'm still working on the panel designs. Also begining to populate two MFOS Voltage Quantizers. Nothing to show for them except a bag of parts, though.
 Filesize:  4.99 MB
 Viewed:  185 Time(s)
 Filesize:  4.52 MB
 Viewed:  179 Time(s)
adamon
PostPosted: Sat Feb 13, 2010 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks great Kevin!
www.soundcloud.com/adamon
iorobyy
PostPosted: Sun Feb 14, 2010 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is my productions
-korg ms10 desktop clone
-minimoog clone --- bassline version
-juno106 vcf and vca clone
 Filesize:  940.82 KB
 Viewed:  206 Time(s)
 Filesize:  754.72 KB
 Viewed:  176 Time(s)
 Filesize:  1.28 MB
 Viewed:  184 Time(s)
 Filesize:  808.62 KB
 Viewed:  186 Time(s)
iorobyy
PostPosted: Sun Feb 14, 2010 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
other pics of my minimoog clone and modular and my borg led eyes synth cat
 Filesize:  754.21 KB
 Viewed:  172 Time(s)
 Filesize:  925.75 KB
 Viewed:  187 Time(s)
 Filesize:  840.76 KB
 Viewed:  181 Time(s)
 Filesize:  847.78 KB
 Viewed:  159 Time(s)
TekniK
PostPosted: Sun Feb 14, 2010 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like the ms10 clone and the cat
droffset
PostPosted: Mon Feb 22, 2010 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, finally something to add to this thread.
3 lovely DS8 drum synth clones using the Marc Barielle PCBs
Edit: Spelling mistakes.
robotfunk
PostPosted: Mon Feb 22, 2010 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
that colour looks familiar Smile
I'm working on a Midibox Sequencer V4, and planning to do a proper case for it but since I had the bare guts working needed something to keep it into place unlike this:
so I made a temporary box like this Smile
droffset
PostPosted: Mon Feb 22, 2010 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks good! MDF is useful eh? Smile
Inventor
Audio files: 265
PostPosted: Mon Feb 22, 2010 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do breadboards count? These are two projects for some electro-music radio shows that I've designed and constructed. On the left is the Quad Osc Lunetta, four square wave oscillators fed into an R2R ladder and buffered out to an 1/8" jack. On the right is a pair of Boolean Sequencer Lunetta circuits of different designs. Be sure to catch the Inventor's Inventions Shows if you have an interest in Lunetta circuits.
Les
The first two Lunetta Beginner's Projects
 Filesize:  272.26 KB
 Viewed:  162 Time(s)
shawn
PostPosted: Fri Feb 26, 2010 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finally debugged 1/2 of my dual PT2399 delay module that was build last year but since it's fully functional now I'm counting it as a 2010 build. Real front panels will come later. Smile
Inventor
Audio files: 265
PostPosted: Fri Feb 26, 2010 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a photo of the circuit board that I built last night. I've been designing this Karplus Strong board for months with the help of my electro-music friends. It is an analog implementation of the famous Karplus Strong string synthesis digital algorithm published in 1983. As far as I know it is the first beast of it's kind, unless you know otherwise... and it sounds really cool!
Les
My first working Karplus Strong PCB
 Filesize:  216.8 KB
 Viewed:  173 Time(s)
julianw
PostPosted: Fri Feb 26, 2010 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work Les. I'm stuffing the pcb right now, just saw the notes on dubugging, great info there - can't wait to get this baby fired up just need some BBD chips, 1st thing to do is hook up the Oberheim Strummer via MidiCV. Meanwhile I'll print the expo convertor docs and try to get my head around that.
Inventor
Audio files: 265
PostPosted: Fri Feb 26, 2010 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, well at least now we know that it works, so any problems will be easier to discover. Good luck with your build, Julian!
Les
Audio files: 31
PostPosted: Mon Mar 01, 2010 9:24 am    Post subject: My MPS is alive! Reply with quote  Mark this post and the followings unread
This module is now up an running and working well. I was up late exploring the sounds that it makes.
The panel layout, lettering, and color is designed to blend with my existing Aries equipment.
This was the first panel that I've made with the DecalPro materials.
 Filesize:  1.51 MB
 Viewed:  202 Time(s)
View showing the circuit board
 Filesize:  1.5 MB
 Viewed:  173 Time(s)
ericcoleridge
PostPosted: Mon Mar 01, 2010 10:31 am    Post subject: Re: My MPS is alive! Reply with quote  Mark this post and the followings unread
How do you get your white lettering on the blackground?
I have some blank dot.com panels that I'd like to use, but I don't know of anyway to get print onto them besides using labels or stickers. Would prefer to be able layout and print graphics.
Audio files: 31
PostPosted: Mon Mar 01, 2010 11:23 am    Post subject: Re: My MPS is alive! Reply with quote  Mark this post and the followings unread
ericcoleridge wrote:
How do you get your white lettering on the background?
I first painted the panels with a satin black paint.
The DecalPro process is a toner transfer method. I printed the panel graphic on a lazer printer in black lettering on supplied toner transfer paper.
After that, one chooses a foil with the color one wants -- in my case, the satin silver color best matches the aluminum color on the Aries. (Although it appears to be white lettering in the photos, it is really an aluminum-looking color. Of course, there are white foils, too. One can choose between metallic-looking colors and just regular ink-link colors.
Anyway, one sandwiches the printed image (on the transfer paper) with the foil -- the foil adheres wherever there is toner.
The next step is the trickiest -- one must run this through the laminator with the clear (mylar) foil that eventually becomes the decal. Once the mylar is "fused" to the carrier paper, then one puts the whole think in a tray of water -- just like a decal. The image, in turn, is transferred to the clear mylar -- ready to be pressed on to the panel.
It is best to buy the kit they supply and work with the examples. There is a bit of a learning curve with it and it is easy to make mistakes. My decal application is not perfect... hopefully I will improve as I gain more experience with it.
The photo shows the new panel next to the existing modules so you can see how it has the same general "look" of the other modules.
(You may think, "hey -- it is close to the color of the wall." - well, my wall is light grey Smile )
 Filesize:  4.81 MB
 Viewed:  187 Time(s)
