Yusynth Modules in Euro (12 Volt) Systems
Page 2 of 3 [67 Posts]
Appliancide*
PostPosted: Wed Jan 04, 2012 8:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yves, would it be ok if I posted I posted information on building your modules for 12V systems over at Muffs? We are trying to put together a one stop resource for converting back and forth between 12V and 15V systems.
http://appliancide/blogspot.com
yusynth
PostPosted: Fri Jan 06, 2012 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
No problem, go ahead.
Yves
ltm
PostPosted: Tue Jan 15, 2013 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
-> yusynth: and and... what about the clock divider? Rolling Eyes
-> appliancide: do you have a link to this thread? maybe question 1 has already been "answered" there...
yusynth
PostPosted: Fri Jan 18, 2013 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Question Question Question Question
Yves
ltm
PostPosted: Sat Jan 19, 2013 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
oops... if it likes 12v without a modification (http://yusynth.net/Modular/EN/DIVIDER/)
yusynth
PostPosted: Sat Jan 19, 2013 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
OK I understand now... Yes it should work without modification at 12V.
Yves
ltm
PostPosted: Sat Jan 19, 2013 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smile cool/thank you!
flab
PostPosted: Mon Feb 11, 2013 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
well hello,
about the VCO(12 volts) as dstrength mentioned above - replacing R3=15K, and R5=130K, and R7=130K make the trick - is there a normal behaviour?
anyone tried it-
thank you in advance people-
flab
PostPosted: Tue Feb 12, 2013 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks like it is tricky enough=
so the best choice is to run in a way that is designed to run -
15v it is
robboten
PostPosted: Thu Aug 08, 2013 11:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also work with 12V in my modular. Am going to build the EMS filter and am wondering if I can just skip the regulator? And if so, which other components nearby I should change/remove? Also, how would -9V be generated from -12V?
NVM - found the answer in this thread - http://electro-music.com/forum/topic-24482-50.html
littlem4tt
PostPosted: Wed Aug 28, 2013 8:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had great fun building the wavefolder for eurorack. This was my first yusynth and pcb etch. I decided to add pads for the pots before I made the press and peel so I could then add short wires to the pcb. This way I could mount the pots straight onto the front panel.
I am very impressed with the sound of this module. It works great with synths and is fantastic on drums. I look forward to making many more yusynth modules!!!
 Filesize:  41.92 KB
 Viewed:  18556 Time(s)
 Filesize:  129.63 KB
 Viewed:  256 Time(s)
 Filesize:  115.6 KB
 Viewed:  278 Time(s)
littlem4tt
PostPosted: Wed Oct 09, 2013 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I have now added the superb Quad panner!
What a great module!
 Filesize:  75.92 KB
 Viewed:  273 Time(s)
littlem4tt
PostPosted: Sun Oct 13, 2013 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
So Yves Usson you have made me addicted to recreating your modules.
I thought that i had enough filters but no. I am so glad i made the Steiner filter as it is so different to anything else.
Thanks again Yves for making your work plublic.
 Filesize:  101.35 KB
 Viewed:  234 Time(s)
LektroiD
PostPosted: Tue Oct 15, 2013 12:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Without any intent of hijacking this thread (although it is Euro/Yusynth related). I was wondering if anyone knows where I can get Euro panels for Yusynth circuits.
LektroiD
littlem4tt
PostPosted: Sun Oct 27, 2013 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
My panels would be better if i could cut straight Rolling Eyes
I can also confirm the dual pulse delay module works great on 12v.
 Filesize:  318.51 KB
 Viewed:  271 Time(s)
yusynth
PostPosted: Fri Nov 01, 2013 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Today I posted on my site a new version of PCB for the Steiner VCF providing pads for a Eurorack PSU connector
Yves
littlem4tt
PostPosted: Sat Nov 02, 2013 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
you steal all my ideas Laughing
littlem4tt
PostPosted: Wed Dec 11, 2013 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your a genius dstrengh! I wanted to put my cv standard module in the 12volt rack and your resistor calculations worked perfectly. Thank you very much.
littlem4tt
PostPosted: Wed Dec 11, 2013 11:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
So here is my finished yusynth.
Running on 12volts I have CV Standards, Steiner VCF, Dual Auto Bend, Clock Divider, Dual Pulse Delay, Dual Gated Slew, Wavefolder, Saw Animator, Quadrature LFO and the 4 ch Stereo Mixer with CV panning.
I also have a Frequency Central PSU running 15v for the 2x Oscillators.
I can't thank you enough Yves for sharing your wonderful creations.
 Filesize:  123.01 KB
 Viewed:  396 Time(s)
chrisp
PostPosted: Sun Feb 23, 2014 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
i have a question about ARP 4072.
it's need some components changes to run perfectly on +\-12 as the Moog filter?
littlem4tt
PostPosted: Thu Mar 06, 2014 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whilst i should have been doing other things i decided to consolodate my yusynth on to single panels and use decal to create the legend.
Took 3 days in all convert.
 Filesize:  2.55 MB
 Viewed:  284 Time(s)
littlem4tt
PostPosted: Thu Mar 06, 2014 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
and from behind
 Filesize:  617.98 KB
 Viewed:  295 Time(s)
diablojoy
PostPosted: Thu Mar 06, 2014 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm is there interest in a 4HP version of the yves's simple VCA single cv input, signal input and only the 1 output , but there are connectors for the others if you want , i should get back a prototype in a couple of weeks.
this is the 2SC1583 version
did this one for myself and putting 4 behind a 16 hp panel
ask where the hell am I
as good an answer as any
01012k7
PostPosted: Mon Mar 10, 2014 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yusynth ADSR
 Filesize:  44.64 KB
 Viewed:  208 Time(s)
diablojoy
PostPosted: Mon Apr 07, 2014 1:10 am    Post subject: Reply with quote  Mark this post and the followings unread
VCA prototype seems to work as expected
still some testing to go to make absolutely certain
some crappy pics of quad version in 16HP
really like this VCA - simple and efficient, i plan on having 30 or so eventually
 Filesize:  392.39 KB
 Viewed:  210 Time(s)
 Filesize:  643.68 KB
 Viewed:  237 Time(s)
 Filesize:  445.15 KB
 Viewed:  242 Time(s)
