LFO and ADSR modulation of VCA
Page 1 of 1 [22 Posts]
stefanv
PostPosted: Wed Feb 03, 2010 1:57 pm    Post subject:  LFO and ADSR modulation of VCA Reply with quote  Mark this post and the followings unread
I'm in the process of building analog-synth-like features into a PAiA Stringz'n'Thingz string synthesizer (keeping all the capabilities of that as well). I plan to post the details on my web site when I'm done (and I'll post some pics and info here too), but I have a question for you all:
I plan to provide both ADSR and LFO modulation of the amplitude, and I'm wondering if people generally use two separate VCAs for that? I realize it's possible to sum the ADSR and LFO voltages, but then one of three things will happen:
1. If the LFO output has its lower peaks at 0V and its upper peaks at say 1V, then the sound through the VCA will continue being turned on and off even after the ADSR has gone back down to 0.
2. If the LFO output has its upper peaks at 0V and its lower peaks at say -1V, then once the ADSR output drops below 1V, the LFO will turn the sound fully off during parts of the cycle. So as the note fades away, a subtle tremolo will turn into a choppy "beeping".
3. If the LFO output is centered around 0V, then both of the above undesirable effects will happen.
It seems to me that one should use the LFO, together with a fixed bias voltage, to modulate one VCA, and then take the output of that VCA and feed it into another VCA controlled by the ADSR. In addition to avoiding the aforementioned undesired behaviors, this results in the LFO modulation remaining as a fixed percentage of the current volume, so that the tremolo won't become more pronounced as the overall volume decreases.
Am I missing something here?
Thanks, Stefan
LFO with 0 to 1V range, ADSR with 0 to 5V range, voltages summed. Notice beeps after ADSR has gone to zero.
 Filesize:  28.59 KB
 Viewed:  407 Time(s)
LFO with -1 to 0V range, ADSR with 0 to 5V range, voltages summed. Notice beeps just before ADSR reaches zero.
 Filesize:  22.59 KB
 Viewed:  315 Time(s)
LFO with -0.5 to 0.5V range, ADSR with 0 to 5V range, voltages summed. Notice beeps just before and after ADSR has gone to zero.
 Filesize:  25.26 KB
 Viewed:  291 Time(s)
LFO with 4.5 to 5.5V range controlling one VCA, ADSR with 0 to 5V range controlling the other. No beeps, and the LFO modulation is reduced in intensity as the volume drops off.
 Filesize:  20.12 KB
 Viewed:  285 Time(s)
Stefan Vorkoetter
http://www.stefanv.com
Audio files: 216
PostPosted: Wed Feb 03, 2010 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Stefan.
On the Nord Modular (a virtual analog) I'd use two VCAs for this.
Audio files: 31
PostPosted: Wed Feb 03, 2010 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might be able to accomplish this effect if you add a little negative bias to the combined ADSR and lfo voltages.
If your LFO is, say, 2 volts peak-to-peak, then with a -2 volt bias, no bleedthrough will occur when the ADSR is at zero.
What WILL happen is that the attack will vary depending on where the LFO is in its cycle.
Incidentally, I used this technique -- to mix an LFO and ADSR, for the lead (the ocarina-like) part in this track:
http://kevinkissinger.com/downloads/music/FluteImprov.mp3
btw -- cool avatar. From one pilot to another, Welcome! Cool
stefanv
PostPosted: Thu Feb 04, 2010 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Kevin. I think that's more or less what I did in the 2nd graph in my original post. The LFO is 1Vp-p, and there's a negative bias so that it remains below zero all the time, thus giving no bleedthrough after the ADSR is done. But, there are still the pulses during the last part of the release cycle, when the ADSR is almost-but-not-quite done. Perhaps in actual use, this doesn't matter, because the release times are relatively short and the LFO cycle times relatively long.
Cool that you're a pilot too! I'm amazed sometimes with the people that write to me that share 2 or 3 or 4 of my interests instead of just one (I'm into planes, model planes, vintage HP calculators, slide rules, Hammond organs, synths, and electronics in general).
Stefan Vorkoetter
Audio files: 31
PostPosted: Thu Feb 04, 2010 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
stefanv wrote:
...there are still the pulses during the last part of the release cycle, when the ADSR is almost-but-not-quite done. Perhaps in actual use, this doesn't matter, because the release times are relatively short and the LFO cycle times relatively long.
That's true. In my track, the lead part had a good deal of reverb and that masked the note tails.
stefanv wrote:
I'm amazed sometimes with the people that write to me that share 2 or 3 or 4 of my interests instead of just one.
You should plan to attend an electro-music festival -- I guarantee you that you'd have a great time.
riley smith
PostPosted: Mon Mar 08, 2010 7:38 pm    Post subject: LFO-ADSR modulation Reply with quote  Mark this post and the followings unread
Here's another idea. My Emu VCAs have a mode where one control input acts as a multiplier for the other. This allows you to have tremolo that decays properly to zero. This is all done in the control circuit without adding another VCA.
stefanv
PostPosted: Tue Mar 09, 2010 7:10 am    Post subject: Re: LFO-ADSR modulation Reply with quote  Mark this post and the followings unread
So it's multiplying the control voltages instead of adding them? I think that basically means there are still two VCAs, but one of them is being used to modulate the control voltage of the other (instead of modulating the audio).
I ended up going with two VCAs in my design, since they're pretty cheap and easy to build. Now I just have to find the time to start actual physical work on this project (all the schematics and board layouts are done, and I have all the parts except some of the pots).
Stefan Vorkoetter
emdot_ambient
PostPosted: Fri May 07, 2010 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a little brain storm here...If you use a Voltage Controlled ADSR, you could run the LFO into the Sustain CV of the Envelope instead of into the VCA itself. Then, the LFO will only modulate the VCA when the Envelope is in its Sustain cycle. Not as flexible as both an LFO and Envelope input to the VCA, but it might be all you need.
Question It's a thought.
stefanv
PostPosted: Sat May 08, 2010 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, that would work too, but I've gone with the dual VCA approach instead. The board is all built now, and I'm on the home stretch, wiring everything together.
Stefan Vorkoetter
stefanv
PostPosted: Thu May 20, 2010 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
In case anyone's interested, I've posted some pictures with captions of the progress so far on my web site:
http://www.stefanv.com/electronics/paia_stringz_n_thingz.html
I'll eventually turn this into a full blown article like the others on my site, with all the details of the updates and mods I made.
Stefan Vorkoetter
emdot_ambient
PostPosted: Thu May 20, 2010 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Dude...man, that's a LOT of work. Looking great, though. Can't wait to see/hear it finished!
stefanv
PostPosted: Thu May 20, 2010 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Lately, it's just been tedious, but not difficult work. However, just the other day, when the project was just a little past the stage you see in the last picture, I decided to apply power to the three tone generator/keying boards, with the signals connected directly to an amp. Much to my relief, everything worked: the old PAiA boards with new caps, my 8 new note blocks, and my new master clock.
I kind of wish I'd been keeping track of my hours spent on this. Although I spent a fair number of hours wiring and soldering, I think I probably spent even more hours designing and redesigning (including redesigning some of the PAiA circuitry). I've been fortunate enough to get in touch with Marvin Jones, the original designer.
Stefan Vorkoetter
stefanv
PostPosted: Tue Jul 06, 2010 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
It's done!
I posted an announcement on the PAiA sub forum: http://electro-music.com/forum/topic-42875.html
Stefan Vorkoetter
rage_q3
PostPosted: Thu Nov 28, 2013 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey guys,
I can't get a clue how to mix output of the VCAs to achieve the "correct" effect without bleeps... If I'll mix two via a simple mixer the bleeps won't go away. It would be great if you guys can clarify this moment.
P.S. I am in process of building my first modular synth and totally new to modular synthesizers in overall and now dig deeply in everything related to sound sculpting and synthesis methods thus treat me like a newbie Smile
Audio files: 216
PostPosted: Tue Dec 31, 2013 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah oh .. oops ... sorry rage_q3 .. I just now see you posted here.
I would use one VCA to modulate the output of the other one .. so .. not add them in a mixer but multiply rather.
Audio files: 216
PostPosted: Wed Jan 01, 2014 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
some more thoughts about it ... you seemed to want to add two VCA signals, where I think they should be multiplied ... a VCA essentially being a multiplier ... so .. two cascaded VCAs where one applies an envelope and the other applies the LFO. The LFO would need an offset added to it to make it a positive only signal.
rage_q3
PostPosted: Wed Jan 15, 2014 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
it would be great if you can post an image of the patch in nord modular g2 showing this idea. i cant get a clue how to multiply the two vca signals? the mixer will just sum them.
Audio files: 216
PostPosted: Thu Jan 16, 2014 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
VCA ==multiplier ... so you just put one after the other, no need for anything additional (except the LFO and the envelope) .. hmm not even that is needed as the Envelope modules have a VCA built in already.
Ok, waiting for the next backup failure here at work ... will download the Clavia demo SW.
Audio files: 216
PostPosted: Thu Jan 16, 2014 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Mapping onto biased-lfo-two-vcas.gif in the originating post.
Three examples of the same thing, leftmost being the simplest rightmost mapping best to original description.
G2 patch example, see thread for comment.
 Filesize:  135.53 KB
 Viewed:  162 Time(s)
rage_q3
PostPosted: Mon Jan 20, 2014 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for your reply, kinda helpful! Now I really understand that VCA is working like a multiplier. Was unaware of that.
The leftmost example is really simple, the AM input allows to modulate the whole level of the envelope using any external source. Now i understand how to make a sequenced pattern with note gaps since the note sequencer doesn't provide a way to skip a note to get a silence instead like in all DAWs the piano roll allows. In g2 I can just send a zero value using a value sequencer in the AM input of the envelope and viola Smile ! and it allows to control the sequencer velocity as well.
But what is the downside of this method with modulating the AM input? I didn't hear the difference between all the methods though I understand that the middle example is the same as the leftmost but with external VCA applied. And the 3rd one is really a closest to the original description.
Btw, you said that the lfo is biased but I didn't notice that...its just a regular unipolar lfo at a 2.72 hz frequency. would be great if you can explain it.
rage_q3
PostPosted: Fri Jan 24, 2014 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
i got it, the lfo is a positive only! thx!
Audio files: 216
PostPosted: Fri Jan 24, 2014 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
All three are the same ...
