96ppqn recording sequencer
t4k4sh1
PostPosted: Tue Jul 06, 2010 7:12 pm    Post subject: 96ppqn recording sequencer
Subject description: records keyboard play up to 4 bars at 96ppqn
I am trying to build a recordable sequencer that can be saved with patch. I appreciate the delay line ideas but I would like to save what I played with the patch.
On this, there are series of note sequencers running at 96ppqn and records MIDI note number and gate on/off. When Gate is on, note is recorded and when off, the bottom note is recorded, so playing the note on keyboard will be ignored.
Sync - length of notes to be recorded (up to 4bars)
REC - wait for next loop postion then start recording, drop recording at the end of loop.
Punch - record/erase notes while pressed
There is a bug however, the logic lines for reset doesn't work correctly and causes the last steps and first to be acting strangely. Can anyone help me to solve the problem?
btw I have also made a sequencer that records PPQN position as binary number with note number like on every software sequencer. instead of using series of sequencers. I had manage to build one but it wasn't working as expected because of simlar clock problem as well..
Takashi
recSequencerSlotAtoB.pch2
 Filename:  recSequencerSlotAtoB.pch2
 Filesize:  10.9 KB
 Downloaded:  1192 Time(s)
t4k4sh1
PostPosted: Tue Jul 06, 2010 7:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
.. and here is a cut down version for G2demo..
recSequencerdemo.pch2
 Filename:  recSequencerdemo.pch2
 Filesize:  10.29 KB
 Downloaded:  1254 Time(s)
