JovianPyx
Joined: Nov 20, 2007 Posts: 1988 Location: West Red Spot, Jupiter
Audio files: 224
JovianPyx
Audio files: 224
Joined: Dec 11, 2010 Posts: 966 Location: Toronto, Ontario - Canada
Posted: Sun Nov 11, 2012 5:45 pm Post subject:
It sounds awesome. Amazing job! _________________ JacobWatters.com |
JovianPyx
Audio files: 224
Posted: Tue Nov 20, 2012 3:14 pm Post subject:
I have two more samples. They are both from a MIDI file I adapted for the Harpie.
One has the reflection filter Fc low, the other has the setting higher.
The piece is "Entry of the Gladiators" by Julius Fucick. Many of you will recognize it. I was playing different MIDI files through the Harpie and twizzling the timbre knobs and I like the way it plays this. If you listen, I hope you like these.
Description: |
Lower reflection filter setting Entry of the Gladiators by Julius Fucick |
Download |
Filename: |
Fucick_Entry_of_the_Gladiators_lower_filter.mp3 |
Filesize: |
2.74 MB |
Downloaded: |
1145 Time(s) |
Description: |
Higher reflection filter setting Entry of the Gladiators by Julius Fucick |
Download |
Filename: |
Fucick_Entry_of_the_Gladiators_higher_filter.mp3 |
Filesize: |
2.76 MB |
Downloaded: |
1109 Time(s) |
_________________ FPGA, dsPIC and Fatman Synth Stuff
Posted: Tue Nov 20, 2012 7:52 pm Post subject:
Got any Scott Joplin files?
That sounds awesome. I know, I need to find a new adjective. |
JovianPyx
Audio files: 224
Posted: Fri Nov 23, 2012 9:15 am Post subject:
I would like to thank Tom Wiltshire (who may be a member here) and Blue Hell for their help in getting things started up with dsPIC development. _________________ FPGA, dsPIC and Fatman Synth Stuff
Posted: Fri Nov 23, 2012 9:20 am Post subject:
And thank you for documenting your steps, so there's a chance some of us might follow (eventually...backlog.... ) |
Audio files: 278
Posted: Fri Nov 23, 2012 12:30 pm Post subject:
Glad I could help Scott, you're doing great stuff with it! _________________ Jan
JovianPyx
Audio files: 224
Posted: Mon Nov 26, 2012 4:41 pm Post subject:
I've built another DIY stripboard dsPIC with a Microchip 23K256 SPI SRAM. This is a 32 kilobyte SRAM organized in bytes. I connected the SRAM to the dsPIC with 2.5 inch wires and used no termination. The SPI SRAM operates nicely at an SPI data rate of 10 megabits per second (max for the dsPIC).
One thing I discovered is that the SRAM bar-CS pin cannot be tied low to force the IC to always be selected. The documentation could be a bit more clear about the actual function of bar-CS. They call it "chip select" which indeed it is, but it also serves to terminate the previous command. If bar-CS is simply help low, the SRAM does not function correctly. Each full transaction to or from the SRAM requires:
1) Bring bar-CS low
2) Send command
3) If write, send data. If read, accept the read data
4) Bring bar-CS high
In the documentation it is mentioned that bringing bar-CS high terminates the previously executed command. It does not clearly state that each SRAM transaction must be bracketed by a bar-CS low and bar-CS high. When bar-CS is low, it selects the SRAM and causes it to enter command mode. When bar-CS is raised, the SRAM terminates whatever it was doing (which is fine if it is timed so that the previous transaction is fully completed).
EDIT ADD:
In order for read from SRAM operations to be successful, it is necessary to make sure that the data being read from the SRAM SDO pin remains synchronized at all times. The dsPIC will shift data on SDI in whether it is a read operation or not. It is up to the driver to figure out how to do this. In my simple test program, I just wrote code to read the buffer register for each byte written to SDO. Most of these are dummy reads, but they keep the register synchronized so that when the real read data is there, it can be read out of the register. This is a bit confusing because one might think that if they are in the process of sending command data to the SRAM, then there's no valid data to read - and that is true, but if the dummy reads are not done, the SPI overrun indicator bit is set and further attempts to read the SDO line will fail. I am now looking into using DMA so that perhaps I can avoid using up CPU cycles to manage these reads. If the reads can done by the DMA controller, then this is work that gets done "for free" so to speak. (I do hope this last paragraph makes sense, it's late and I'm very tired, but wanted to add this information). _________________ FPGA, dsPIC and Fatman Synth Stuff
JovianPyx
Audio files: 224
JovianPyx
Audio files: 224
Posted: Mon Jul 29, 2013 2:53 pm Post subject:
Been a long time since I've added anything.
I've made a simple synth board with a dsPIC33F (28 pin DIP), 2 TL074 and 1 6N138 to make a MIDI synth. I'm using both ASM30 and C30. Some of the synth components are coded in assembly language and all of the synth logic is written in C.
Currently, the synth consists of 2 oscillators, each oscillator drives 2 wavetables. the 2 wavetables are sinewave and distorted sinewave. Velocity pan-interpolats between the two tables. The 2nd oscillator is tuned an octave above the first and is more prominent with stronger velocity. The result is a fairly convincing flute sound. It seems that I have more CPU power (about 100 free CPU cycles), so I will add some noise for a bit more fun. _________________ FPGA, dsPIC and Fatman Synth Stuff
Dan Lavin
Joined: Nov 09, 2006 Posts: 649 Location: Spring Lake, Mi, USA
Audio files: 21
Posted: Mon Jul 29, 2013 6:07 pm Post subject:
Cool Scott! Hopefully you'll post the code when complete. This sounds like it would make a nice addition to my studio! _________________ Synth DIY since 1977! |
JovianPyx
Audio files: 224
Posted: Tue Jul 30, 2013 3:50 pm Post subject:
Hi Dan,
As much as I have enjoyed posting such details in the past, I am seriously considering moving my projects into a commercial realm, so I really cannot publish the full details of this.
I would like to make this project and others like it available to people at a fair price, that being one that contains the cost and also compensates me (to some small degee) for the work I put into it. I am considering a range of options including, bare boards, assembled boards, assembled boards with a pre-programmed dsPIC IC as well as just the pre-programmed dsPIC IC.
Right now this is in the "proof of concept" stage. The testing has shown that I can embed a MIDI controller in the dsPIC along with a voice engine and the two seem to play nicely together. I am not finished with all of the "what if" stuff yet, but soon. What I have at this point is a basic functional synthesizer that sounds pretty good. I plan to post some sound samples when I get the design more complete. _________________ FPGA, dsPIC and Fatman Synth Stuff
Dan Lavin
Audio files: 21
Posted: Tue Jul 30, 2013 7:21 pm Post subject:
That's fine Scott! I certainly don't mind paying for it. I've done that with my Shruthi, Sammich FM, bass boy and a few more things. A flute-like synth would be cool for the home studio! _________________ Synth DIY since 1977! |
JovianPyx
Audio files: 224
JovianPyx
Audio files: 224
Posted: Thu Aug 01, 2013 4:55 pm Post subject:
Please note that the above sample has some rather generic settings. This is also a "budding prototype". When I did the sample I was excited that the damn thing worked at all and just did some crazy numeric trimming to get what is in the mp3. I've been told that the sound has too much "chiff" from the noise generator. This makes it sound a bit like a pipe organ thing.
I plan to have 4 pots to control how things are mixed, chiff amount would be one of those things. Such a set of controls would allow more control over exactly how this sounds. The pot inputs are already wired, I just need to buy some pots and wire them up.
Still a work in progress... _________________ FPGA, dsPIC and Fatman Synth Stuff
Posted: Thu Aug 01, 2013 6:44 pm Post subject:
I did get the sound of pipe organ out of several bits of it, but it still sounded cool. As far as "chiff" goes, I'll call that my vocabulary word for the day |
JovianPyx
Audio files: 224
Posted: Thu Aug 01, 2013 7:44 pm Post subject:
Well, none of that sounds bad at all. This (so far) is a very basic design and I plan much more user control over the sound. I call it a flute synth, but I'd prefer it to wind up being a pipe synth, as in lots of different pipes. One of the knobs will control the amount of "chiff", another will probably control the amount of sine versus sine plus 2nd and 3rd harmonics. another knob may control the timing of the ADSRs.
At the moment I'm working on portamento and pitch wheel. Still deciding how to implement mod wheel. _________________ FPGA, dsPIC and Fatman Synth Stuff
JovianPyx
Audio files: 224
Audio files: 278
Posted: Wed Aug 07, 2013 6:07 am Post subject:
Sounds good to me. _________________ Jan
JovianPyx
Audio files: 224
Posted: Mon Aug 19, 2013 5:23 pm Post subject:
Awesome song. I love the variations that the harpie does. _________________ JacobWatters.com |
JovianPyx
Audio files: 224
JovianPyx
Audio files: 224
JovianPyx
Audio files: 224
