Trapezoid VCA anybody?
Page 1 of 7 [160 Posts]
Would you buy a Jh Trapezoid VCA PCB?
no - only interested in the original EMS circuit (this is not goint to happen - sorry)
2%
 2%  [ 1 ]
yes - if it emulates the behaviour of the EMS circuit, and doesn't need component selecting
97%
 97%  [ 40 ]
Total Votes : 41
jhaible
PostPosted: Sun Jul 25, 2010 10:09 am    Post subject: Trapezoid VCA anybody? Reply with quote  Mark this post and the followings unread
I wonder how many interest there would be in a Trapezoid VCA PCB.
It would - of course - be designed to emulate the behaviour of the famous EMS Synthi A and VCS3 Trapezoid, and it would be - of course - not be a direct copy of the EMS circuit.
Let me know.
JH.
jhaible
PostPosted: Sun Jul 25, 2010 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.youtube.com/watch?v=MlIKIr3Ef5c
http://www.jhaible.de/trapezoid/jh_trapezoid_vca_1.mp3
Quick and dirty demo.
Farfisa VIP 500 thru the Trapezoid VCA + Phaser + BBD Delay
JH.
StephenGiles
PostPosted: Sun Jul 25, 2010 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
That rang a bell!
http://www.youtube.com/watch?v=0bU7fT9oZMI
Adam-V
PostPosted: Sun Jul 25, 2010 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Making this one available would be just brilliant Jürgen.
Would the trapezoid signal be made externally available for use as a CV source for things other than the VCA?
Adam-V
jhaible
PostPosted: Sun Jul 25, 2010 10:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, absolutely.
Positive and negative, and you choose the peak output voltage.
JH.
diablojoy
PostPosted: Sun Jul 25, 2010 10:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice Smile i would want at least 2 i think
TekniK
PostPosted: Sun Jul 25, 2010 11:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
what is it exactly,a pcb with vca + AR generator?
Adam-V
PostPosted: Sun Jul 25, 2010 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
Yes, absolutely.
JH.
Brilliant!!!!! I'd be up for a number of them then.
Adam-V
a100user
PostPosted: Mon Jul 26, 2010 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Interested indeed Jurgen
David
jumunius
PostPosted: Mon Jul 26, 2010 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, one please!
PostPosted: Tue Jul 27, 2010 12:36 pm    Post subject: Re: Trapezoid VCA anybody? Reply with quote  Mark this post and the followings unread
Of course when you put it like that, it's a YES-YES situation!
YES! Very Happy
ACHTUNG!
PostPosted: Tue Jul 27, 2010 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do your homework! Rolling Eyes Wink
The EMS trapezoid ain't no simple AR generator!!
ACHTUNG!
TekniK
PostPosted: Tue Jul 27, 2010 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
what is it then thats its so special?
numbertalk
PostPosted: Tue Jul 27, 2010 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Count me in for 1
ejr27233
PostPosted: Tue Jul 27, 2010 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for 2 PCB's
jhaible
PostPosted: Tue Jul 27, 2010 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hard to explain.
When I build that Synthi Clone, I thought a single, restricted envelope like that would hardly be enough for a synthesizer. So I added a Hold-ADSR envelope.
More than 10 years later, a cannot remember a single occasion when I made use of that HADSR. I always used the Trapezoid.
(This applies to FX sounds and to modulating external signals only. Playing melodies asks for an ADSR.)
JH.
TekniK
PostPosted: Tue Jul 27, 2010 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok,and does this vca design add some smoothness or something to the sound.
Your YT demo sounds nice,but its just because of the AR effect or?
PostPosted: Tue Jul 27, 2010 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's funny JH, because I actually DID always wonder why you did this. Now I know! Very Happy
ACHTUNG!
G2 patch files: 625
PostPosted: Tue Jul 27, 2010 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Having an envelope that can sustain for as long as a key is held can be useful sometimes. How about a modification so that the hold time control could be switched to 'Gate' mode?
jhaible
PostPosted: Tue Jul 27, 2010 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's already in there. Standard Gate and / or Switch trigger input.
The On-Time parameter is important for the auto-cycle mode, not so much for the gated mode.
JH.
jhaible
PostPosted: Wed Jul 28, 2010 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there a standard for +/-12V connectors?
Or are they alle different?
Could anyone point me to dimensional drawings and pinout of the most common +/-12V connectors, please?
JH.
a100user
PostPosted: Wed Jul 28, 2010 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Jurgen
Doepfer have some good info here:
http://www.doepfer.de/a100_man/a100t_e.htm
With the exception of Analoge Systems this is what all Euro makers adopt
David
jhaible
PostPosted: Wed Jul 28, 2010 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
a100user wrote:
Jurgen
David
Thank you - I'll go for the 10-pin version then.
How many space does it need around the actual footprint?
Best let me know the size of the whole rectangele to be left free on the board ...
First time I ever integrate a D connector on one of my boards. Smile Smile Smile
JH.
a100user
PostPosted: Wed Jul 28, 2010 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't have a module here at the moment but the ribbon headers are quite low profile so you could probably get away with 5mm all round the pins.
I believe this is the correct spec for the 16 pin version
http://www.farnell.com/cad/308052.pdf
Some folks use this type as it's polorized and prevents them plugging the module the wrong way round
jhaible
PostPosted: Wed Jul 28, 2010 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
JH.
