Trapezoid VCA anybody?
Page 5 of 7 [160 Posts]
Would you buy a Jh Trapezoid VCA PCB?
no - only interested in the original EMS circuit (this is not goint to happen - sorry)
2%
 2%  [ 1 ]
yes - if it emulates the behaviour of the EMS circuit, and doesn't need component selecting
97%
 97%  [ 40 ]
Total Votes : 41
janvanvolt
PostPosted: Tue Nov 02, 2010 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anybody got an idea for the frontpanel (5U?)
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
MR-808
PostPosted: Tue Nov 02, 2010 9:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
My partner in synth-building is working on one. I hope to have something worth showing soon!
numbertalk
PostPosted: Wed Nov 03, 2010 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hoping someone doesn't mind clearing a few things up for me.
1) What exactly is the "switch trigger" input? Is it there in addition to the push-button input to give you an extra spot for easily connecting with the "audio trig" connection"? Would you want to put a jack here? If so, what input would you expect here that's different from what you'd feed into the "gate" input?
2) EDIT - I believe I understand the audio trigger - the summed input audio is converted into a trigger which you can feed into switch trigger input (or I'm guessing anywhere else in your modular you can use a trigger).
3) Just to make sure, the push button input expects a normally-open momentary switch, with the 2 lugs connected to the 2 pads, right?
jhaible
PostPosted: Wed Nov 03, 2010 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. Smile
Switch trigger is used by old Korg and Moog synthesizers. Not a gate voltage, but a switch closing a contact to GND.
Pushbutton and S-Trigger have the same function. And you can use on to connect with the Audio trigger output, to get some weird self-trigger function. (Emphasis on weird).
Gate is an ordinary 5V positive-going Voltage Trigger ("Gate") input.
JH.
numbertalk
PostPosted: Wed Nov 03, 2010 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent thanks Very Happy
Yes. Smile
JH.
emdot_ambient
PostPosted: Wed Nov 03, 2010 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Idea Like a footswitch to trigger without using yer hands....
Blimey, that took me a while to piece together!
numbertalk
PostPosted: Thu Nov 04, 2010 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH,
Looks like the value and taper of pot for InitGain is missing from the schematic - what should it be?
jhaible
PostPosted: Fri Nov 05, 2010 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
Hi JH,
linear
JH.
numbertalk
PostPosted: Fri Nov 05, 2010 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
And what value? 100K?
jhaible wrote:
numbertalk wrote:
Hi JH,
linear
JH.
jhaible
PostPosted: Fri Nov 05, 2010 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
numbertalk wrote:
Hi JH,
linear
JH.
Anything between 10k and 100k will do.
Recommended: 10k
JH.
numbertalk
PostPosted: Fri Nov 05, 2010 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very kindly for the timely response.
One last thing I'm hoping you wouldn't mind saying a little about when you get a chance is the buffered versus unbuffered inputs and outputs. I'm starting to design a panel and am trying to figure out which type to include or if it would make sense to include a couple of both types together.
I understand the active summing of the input, the buffering, the signal inversion and the ability to boost the output signal by adjusting R70, but what I'm not clear about, when you say the buffered input circuit can be used to "bring the input levels down", are the implications there. Such as, what is the "ideal" signal level for this circuit? What happens to the summed signal when input through the unbuffered "core inputs" - is it being attenuated by the circuit? I know you mentioned earlier in the thread that if the input signal is high enough then the FET VCA will color the sound, but that's all the info I could find on signal levels.
Finally, what is the signal level at the unbuffered VCA output? I'd like to work out the right value of R70 to bring that signal level up to 10Vp-p at the buffered output.
jhaible
PostPosted: Fri Nov 05, 2010 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
The VCA core is using the very same signal levels as the EMS VCS3.
JH.
numbertalk
PostPosted: Fri Nov 05, 2010 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, but I'm still not clear on what effect the input signal level has when using the buffered inputs versus the core inputs.
Maybe it makes more sense to ask this way - if I'm using this module in a modular synth with 10Vp-p signals, would it make sense to use the buffered input as shown in the schematic, with R56=10K? Would this configuration "massage" the signal to make it more appropriate for the circuit? Then I could adjust R70 on the buffered output to bring the level back up to 10Vp-p? If so, does this mean I would have a problem with using this module with a synth with outputs closer to instrument level, and for that would I then want core inputs as well? Just trying to figure out which inputs would be appropriate given my situation and if there would be any reason to have one of each. Again, I understand the other things about using buffered inputs and outputs, just trying to figure out the input signal level aspect as it regards this circuit.
Thanks again.
JH.
jhaible
PostPosted: Fri Nov 05, 2010 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
It's always a matter of taste how much you want to oerdrive a VCA like this. The resistor values in the schematics are a good starting point if you use input attenuators. If the output level is too small, increase R70.
JH.
numbertalk
PostPosted: Fri Nov 05, 2010 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks JH. You pretty much hit the nail on the head of why I want to figure this out. I have an EMS VCF clone that, when used with my 10V VCO signals, does not sound so good - it requires proper attenuation to get that killer sound. So want to make sure I am set up for the best experience before I have a panel made.
So with either the core inputs or the buffer you would suggest input attenuators? Sorry to be a pain but one more question - what value of pot would you suggest? I'm not good at figuring that out - as a guess, 100K if using the buffered inputs? What value if using the core inputs?
Thanks again!
JH.
jhaible
PostPosted: Fri Nov 05, 2010 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
10k log (audio taper) would be a good value for the attenuator(s).
JH.
Thanks again!
JH.
numbertalk
PostPosted: Fri Nov 05, 2010 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also, for anyone using the BOM that was attached earlier, it specifies a 1M trimmer but from the schematic looks like it should be 2M.
JH.
Thanks again!
JH.
jhaible
PostPosted: Fri Nov 05, 2010 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right. (2M, 2M2, or 2M5 will work)
JH.
JH.
Thanks again!
JH.
numbertalk
PostPosted: Fri Nov 05, 2010 6:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also, not to be nitpicky, but for anyone going strictly by the BOM posted on this thread, the 100K trimmer is a single-turn, not a multi-turn.
numbertalk
PostPosted: Tue Nov 09, 2010 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
One more question, since like I proved earlier, I'm not good at figuring out the best values/tapers for these things - if I want to add an attenuator for the Decay CV in, what value/taper pot would be good for that?
jhaible
PostPosted: Tue Nov 09, 2010 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
This depends on the knob response you prefer.
My preference is to use no attenator pot at the oinput for the Decay CV at all. but use a 10k linear pot at the DeacyCVPol connector instead: Then you have a (linear) reversible attenuator.
JH.
numbertalk
PostPosted: Tue Nov 09, 2010 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
This sounds much better - thanks!
JH.
zarko
PostPosted: Thu Nov 25, 2010 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
here is my small contibution its the front panel in dotcom format 2U 222x108 mm
 Filesize:  552.39 KB
 Viewed:  410 Time(s)
jhaible
PostPosted: Thu Nov 25, 2010 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just a hint:
In a system with input attenuators (most modular concepts) you should add an input attenuator potentiometer, or better a reversible attenuator, for the Decay Time CV.
In an EMS-like system, where there are no input attenuators, you should have an *output* attenuator for each output, typically a 5k log potentiometer.
JH.
zarko
PostPosted: Fri Nov 26, 2010 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jurgen, i made a new front panel with the attenuator pot,would you tell
me what do you think about Wink
 Filesize:  505.04 KB
 Viewed:  292 Time(s)
