ARP Soloist Info Needed
Page 1 of 1 [7 Posts]
BrassTeacher
PostPosted: Mon Sep 06, 2010 12:54 am    Post subject:  ARP Soloist Info Needed Reply with quote  Mark this post and the followings unread
Hi All,
I recently picked up (CHEAP! Mr. Green ) all the submodules from an old ARP Soloist. This the original ARP Soloist, not the Pro Soloist or DGX.
I have as yet been unable to find any info on the pinouts and connections for the submodules, excepting the 4027 VCO (LOTS of info on that one out there!). If anyone has the pinouts/connections, or even a full service manual for the ARP Soloist, I REALLY need the info. The submodules are all "fixed" filters:
4030 - Violin
4031 - Cello
4032 - English Horn, Oboe, Banjo (yes, Banjo )
4033 - Bassoon, Electric Bass, Electric Piano
I intend to build these into a modular filterbank for a friend, assuming they are functional. At the moment I don't have enough info to test them. Stupid me assumed that I'd be able to find the info just as easily as any other ARP synth, but I was quite mistaken .
And yes, these are the older potted type, with 1972 date markings, which means they are solid epoxy all the way through, not a thin layer of epoxy over silicone, so there's no way to just open them up and look.
Any info at all would be greatly appreciated!
BrassTeacher
PostPosted: Wed Sep 15, 2010 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
cannot_fr
PostPosted: Thu Sep 30, 2010 2:26 pm    Post subject: service manual for pro solist
Subject description: service manual for pro solist
hello
If you want, I have the service manual n°: 90001801 for arp
manual service for pro soloist model 270 and pro dgx model 2720
tell me, the manual weight 19 mo and I can use Yousendit ...
I'm the happy owner of a prosoloist and prodgx ... and other ARP
The manual was very useful for adjust the machine
give me your mail by MP
bye
flutterplucker
PostPosted: Thu Dec 05, 2013 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Opened mine for some maintenance and bang! on the modules they have the schematic right on each of them!..
 Filesize:  1.04 MB
 Viewed:  298 Time(s)
BrassTeacher
PostPosted: Mon Dec 23, 2013 7:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
THANKS! I owe you big time! thanks
Now all I need to do is figure out how/what to wire to the "enable" pins. I'm going to assume +5V will activate it, via some type of analog switch?
Don Taylor
Plyer of All Trades, Master of None...
Mike54
PostPosted: Wed Feb 19, 2014 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Need the arp 2700 soloist service manual and schematics
Maybe someone have one
thanks
Beetchiki52
PostPosted: Mon May 19, 2014 10:14 am    Post subject: Service Manual ARP 2700 Reply with quote  Mark this post and the followings unread
I have an old copy for ARP 2701
SERVICE MANUAL ARP PRO SOLOIST 2701.pdf
 Filename:  SERVICE MANUAL ARP PRO SOLOIST 2701.pdf
 Filesize:  13.71 MB
 Downloaded:  241 Time(s)
