modelling an fm patch from pluggo
Page 1 of 1 [7 Posts]
mattmumu
PostPosted: Tue Sep 28, 2010 3:38 pm    Post subject: modelling an fm patch from pluggo
Subject description: patch modelling
I don't know if this is the correct place to post this question. I would like to model a particular preset from a pluggo plugin fm 4op, attached is the screen shot. For those experienced g2 modular programmers, is this particular patch a possibility, it is called film strip testtone. In other words as a total beginner should I even attempt it? it is just it would be nice not to take out a laptop just to run one or 2 sounds for live!
an editor view of the plugin
 Filesize:  12.66 KB
 Viewed:  6369 Time(s)
a graphical view of the plugin
 Filesize:  80.41 KB
 Viewed:  260 Time(s)
PostPosted: Wed Sep 29, 2010 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Everything is possible with the G2 - do you have more information about what a film strip testtone is, and maybe some illustration of pluggo's signal chain?
Regardless, you should always try stuff on the G2, that's what it's for. Smile You'll run into all kinds of happy accidents on the way.
/Stefan
G2 patch files: 625
PostPosted: Wed Sep 29, 2010 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Like Stefan says, should be possible.
I don't have pluggo so I don't know what it is supposed to sound like. Here is a structural patch you can use for a start. Probably the tricky bit will be matching the envelope shapes and levels. One option would be to switch the pluggo patch to an algorithm where all operators go to the output, then audition each, one at a time.
FilmStrip.pch2
 Filename:  FilmStrip.pch2
 Filesize:  1.67 KB
 Downloaded:  1301 Time(s)
mattmumu
PostPosted: Thu Sep 30, 2010 10:08 am    Post subject: fm 4 pluggo patch Reply with quote  Mark this post and the followings unread
Thanks for this I will check it out, the only information I have about the patch, apart from hearing it are the 2 screen grabs I did of the preset.
mattmumu
PostPosted: Thu Sep 30, 2010 11:51 am    Post subject: filmstrip testtone pluggo patch Reply with quote  Mark this post and the followings unread
Have only so much info from the pluggo interface, have tweaked the envelopes etc and frequencies. attached is the sound of the pluggo preset c note held down for a few seconds, then just played instaneously, likewise up the register and down. also attached the tweaked patch
film strip test tone C..mp3
an mp3 of the pluggo preset
 Filename:  film strip test tone C..mp3
 Filesize:  1.22 MB
 Downloaded:  366 Time(s)
filmstrip_559 ed1.pch2
an edited version of the patch you kindly postted
 Filename:  filmstrip_559 ed1.pch2
 Filesize:  1.67 KB
 Downloaded:  1109 Time(s)
G2 patch files: 625
PostPosted: Thu Sep 30, 2010 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for posting the sound sample. I assumed the numbers on the faders showed ratios but it sounds like it is using the other operators as lfo's. The G2 phase mod operator uses true Yamaha style FM which is actualy phase modulation. Pluggo does not sound as if it does FM the same. The good news is, you can just use multiple regular triangle lfo's modulating a regular triangle osc to emulate the patch.
You may get closer with this patch, sorry I don't have time to tweak it too much today.
anotherPatch.pch2
 Filename:  anotherPatch.pch2
 Filesize:  1.48 KB
 Downloaded:  1295 Time(s)
mattmumu
PostPosted: Fri Oct 01, 2010 9:46 am    Post subject: filmstrip testtone pluggo patch
Subject description: recreating a plugin preset
Hi, Ian,
Thanks for posting this new patch, I am starting to get a handle on how to program and what to connect etc. The real issue with this sound is in creating the same settings, and more particularly the envelopes for each oscillator.
Is there a way of designing your own envelopes by building subroutines, using logic gates and an envelope with control inputs. I am not expecting someone to do it, I just wondered without me tearing my hair out, whther it is theoretically possible with the G2. I have emailed the pluggo designers of the preset, (hopefully they may get back to me) asking for some of the parameter settings, what frequencies, what time and gain factors for the envelopes, and whther there are any under the hood settings with the fm modulation.
