Streaming Linux Clients?
Page 1 of 1 [9 Posts]
nobody
PostPosted: Thu Oct 21, 2010 3:54 pm    Post subject: Streaming Linux Clients?
Subject description: Argh
Anyone have any suggestions for stream clients that run under Linux? Edcast under Wine is no good for me. I'm trying things as I find them, but so far, no luck. This is just about a Linux-only household, so I'd appreciate any advice.
I could just set up my own streaming service, but I'd really like to be a part of shows here, too.
Fenris
PostPosted: Thu Oct 21, 2010 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi there
These links may be useful. They all seem to suggest a common app so fingers crossed this will be of some help to you.
http://www.yolinux.com/TUTORIALS/LinuxTutorialAudioStreaming.html
http://www.linuxjournal.com/article/9280
http://tldp.org/HOWTO/MP3-HOWTO-11.html
http://www.linux.ie/articles/streamingaudio.php
regards
Fenris
Windows OS Sir?
No thanks. I'd rather shove wasps up my ass
nobody
PostPosted: Fri Oct 22, 2010 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Fenris. Cool
The only problem I have with MuSE is that it won't connect by default to my sound devices. Hopefully after playing around with it, I'll figure it out. If not, then it looks like I'll simply have to create my own streaming station.
Fenris
PostPosted: Fri Oct 22, 2010 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah I See. My Linux Ubuntu is not such an exotic setup so I'm afraid I know nothing as such.
Maybe this will help, if this is related to your issue -
Also check 'Jack' at the Ubuntu forums it seems you are not alone with issues with muse. Unless it's your posts I've found Laughing
http://ohioloco.ubuntuforums.org/showthread.php?t=843012
regards
Fenris
Windows OS Sir?
wmonk
PostPosted: Sun Oct 24, 2010 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I use edcast_jack with jack, and audacious to stream prerecorded music. Works great!
Weblog!
nobody
PostPosted: Sun Oct 24, 2010 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Woody dude! Where's them config files? If you PM'd me, you might have typo'd my username. If you're still willing to share them with me, that'd be super-groovy.
(Edit: there is no one by a name other than Woody mentioned here!)
wmonk
PostPosted: Sun Oct 24, 2010 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Ssssht, my name is Woody.
Anyway, here my config file, I hashed out the port number and password, you have to figure those out yourself.
Woody
empublic2.cfg.txt
 Filename:  empublic2.cfg.txt
 Filesize:  1.35 KB
 Downloaded:  154 Time(s)
Weblog!
nobody
PostPosted: Sun Oct 24, 2010 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, T - uh, Woody! Smile
Maybe you're me, with an inverted M... compress
wmonk
PostPosted: Sun Oct 24, 2010 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
My whole life is inverted
Normal me is loooong goooone, but has woody kind of quality to it.
www.youtube.com/watch?v=-gwXJsWHupg
Weblog!
