Jack_Hertz
Joined: May 14, 2010 Posts: 333 Location: Pacifica, CA
Audio files: 119
Posted: Tue Dec 28, 2010 11:10 am Post subject:
Time Drone with Jack Hertz - Show Archives |
Time Drone is weekly show featuring two hours of ambient music by Jack Hertz and guests. Time Drone is focused on experimenting with very long forms of live improvisation that are meant to slow or extend the listeners' perception of time.
Time Drone airs every Thursday starting at 10 PM EST / 7 PM PST streaming live on http://StillStream.com.
Please feel welcome to download and listen to recordings from past shows below. Note: these recordings are mixes taken directly from the live stream. Noise, bad levels, distortion, dropouts and other issues may be heard.
| Description: |
| Filesize: |
306.12 KB |
| Viewed: |
85 Time(s) |
| Description: |
 Download |
| Filename: |
Time-Drone-2010-12-06.mp3 |
| Filesize: |
110.38 MB |
| Downloaded: |
416 Time(s) |
| Description: |
 Download |
| Filename: |
Time-Drone-2010-12-13.mp3 |
| Filesize: |
104.73 MB |
| Downloaded: |
366 Time(s) |
| Description: |
 Download |
| Filename: |
Time-Drone-2010-12-20.mp3 |
| Filesize: |
109.82 MB |
| Downloaded: |
367 Time(s) |
| Description: |
 Download |
| Filename: |
Time-Drone-2010-12-27.mp3 |
| Filesize: |
109.65 MB |
| Downloaded: |
365 Time(s) |
_________________ Web Site - Encyclotronica Last edited by Jack_Hertz on Sun Feb 05, 2012 10:00 am; edited 20 times in total |
Muied Lumens
Joined: Apr 24, 2009 Posts: 1337 Location: Bristol UK
Audio files: 209
Posted: Tue Dec 28, 2010 4:14 pm Post subject:
Droneloaded. Thanks.  _________________ robsol
Muied Lumens Base Star |
nobody
Posted: Tue Dec 28, 2010 4:26 pm Post subject:
| I think I heard the show once. Very nice! I'd love to be a guest some time. |
Jack_Hertz
Audio files: 119
Posted: Tue Dec 28, 2010 5:21 pm Post subject:
| audiodef wrote: | | I think I heard the show once. Very nice! I'd love to be a guest some time. |
I would love to have you. Everyone, are most welcome to send me your drones and loops. I will be glad to use them on the show.
Likewise, if you'd like to join me for a live stream drone jam. Send me a note so we can set something up. _________________ Web Site - Encyclotronica Last edited by Jack_Hertz on Tue Dec 28, 2010 6:51 pm; edited 1 time in total |
Joined: Feb 04, 2005 Posts: 2143 Location: Nottingham, UK
Audio files: 153
nobody
Posted: Thu Dec 30, 2010 8:06 am Post subject:
I was just reading the brain/thought controlled music thread that 1:11 started when I came up with an idea, sitting in view of an electric range-top oven. This idea would work well for Time Drone, as it requires patience and time.
Put a (or more than one) heat sensor above an electric range-top. Maybe even a heat sensor inside the oven. Fiddle with the heat levels of the individual coils (and oven, if used). Now that I think of it, this would work better with individual sensors for each coil. Have the heat sensors control whatever - cutoff, resonance, VCA and pitch, for example.
Get some pretty sensitive heat sensors and I'm guessing you could introduce variations by waving your hands (or something fireproof) between the stove coils and the sensor.
Now I wish I had the means to do this. |
nobody
Posted: Thu Dec 30, 2010 8:11 am Post subject:
| Another idea: tie strings between small trees on a windy day, with the strings triggering controls when pulled or relaxed. Have multiple instances of this going further back into a forest so that the outer trees make more pronounced changes while the inner trees make less pronounced changes. |
Jack_Hertz
Audio files: 119
DES
Audio files: 6
Posted: Thu Dec 30, 2010 8:59 am Post subject:
My wife and I have tossed around the idea of making an Aeolian Harp. You can see some types here: http://www.harmonicwindharps.com/ Very cool sounding instruments
Might be pretty cool to use pickups to capture the sound - and also have several strings control sensors routed to control MIDI CC or CV type controls that are connected to filters, etc.. _________________ Dave
www.davesneed.com
www.myspace.com/desneed |
Jack_Hertz
Audio files: 119
Posted: Sat Jan 01, 2011 10:54 am Post subject:
Huh, that was a cool Dave. The harmonic sanctuary is very inspiring. I live in a windy place that I could do some interesting things with. Anyone know where I can get some pick up for steel cables? _________________ Web Site - Encyclotronica |
DES
Audio files: 6
Posted: Sat Jan 01, 2011 2:17 pm Post subject:
I would think - unless the wire was non-magnetic - that you could use guitar pickups. Or in a pinch use the small transistor radio earphones. You would have to work out an efficient way to couple the string to the diaphragm in the earphone though. They work pretty good as pickups. Years ago in high school I took one and screwed it onto the end of my flute (the end where the small cap comes off so you can adjust intonation) Put it on just tight enough for the diaphragm to contact the threaded rod. Worked pretty darned good!
Possibly also use piezo elements from old buzzers and such.... _________________ Dave
www.davesneed.com
Jack_Hertz
Audio files: 119
Posted: Mon Jan 03, 2011 1:07 pm Post subject:
Yes, Piezos are the way to go. I talked to a buddy who build custom Pick-ups and he said those with some 2-sided tape should do it. Now to find some cables.  _________________ Web Site - Encyclotronica |
Jack_Hertz
Audio files: 119
Jack_Hertz
Audio files: 119
nobody
Posted: Tue Jan 04, 2011 3:07 pm Post subject:
| Great set, Jack! |
D.Miñoza
Joined: Jun 15, 2009 Posts: 369 Location: CowTown, USA
Posted: Tue Jan 04, 2011 6:18 pm Post subject:
excellent set, jack.
~ _________________ *****************
soundcloud
relaxedmachinery |
shanemorris
Audio files: 83
Posted: Wed Jan 05, 2011 1:01 am Post subject:
Jack I have made Time Drone a sticky topic with the other regularly scheduled programs and added you to the radio schedule. Great to add another high quality show to our list. Thanks  _________________ ElectroCasa |
Audio files: 153
Posted: Wed Jan 05, 2011 3:48 am Post subject:
nice show Jack, I think I was still awake when it finished  _________________ Jez
music | adventures in sound |
Jack_Hertz
Audio files: 119
Posted: Wed Jan 05, 2011 2:49 pm Post subject:
Thanks muchly for tuning in. Hope I can keep it up with the down slow every week.  _________________ Web Site - Encyclotronica |
nobody
Posted: Mon Jan 10, 2011 7:04 pm Post subject:
In lieu of uploading, I thought I'd post a link to the flac, since it's around 200 MB.
http://audiodef.com/audio/flac/TimeDrone1.flac
This is my stand-alone drone that Jack incorporated into the show on 10 January. I thought I'd include it for the geek factor. |
Jack_Hertz
Audio files: 119
nobody
Posted: Tue Jan 11, 2011 12:28 pm Post subject:
This was fun. I have a few large, brightly-coloured triangular paper clips that I used to hold down keys on different synths.
I've posted the show to my own site. I just need to add a note explaining I was a guest on the show.
http://audiodef.com/shows.php?show_id=4
Edit: note added. Last edited by nobody on Thu Feb 17, 2011 8:03 pm; edited 2 times in total |
Jack_Hertz
Audio files: 119
Posted: Tue Jan 11, 2011 1:15 pm Post subject:
| audiodef wrote: | | This was fun. I have a few large, brightly-coloured triangular paper clips that I used to hold down keys on different synths. |
That was fun. Thanks for playing along.
That's a great idea. I use a footswtich plugged into the sustain input on my USB controller to keep stuff on. _________________ Web Site - Encyclotronica |
Joined: Apr 03, 2004 Posts: 19620 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Tue Jan 11, 2011 1:36 pm Post subject:
| Jack Hertz wrote: | | My account is out of space |
Is the file really larger than 900 MB?  _________________ Jan |
nobody
Posted: Wed Jan 12, 2011 9:07 am Post subject:
| Jack Hertz wrote: |
That's a great idea. I use a footswtich plugged into the sustain input on my USB controller to keep stuff on. |
I prefer foot switches, but I don't have any. Maybe I should move this up in my acquisition list - they aren't expensive. Some of my synths have hold functions, but it's a bit convoluted to quickly assign the function to a knob somewhere. |
