noise circuit stripboard layout (as seen in efm wildcat)
vladosh
PostPosted: Sat Feb 26, 2011 9:18 am    Post subject: noise circuit stripboard layout (as seen in efm wildcat) Reply with quote  Mark this post and the followings unread
just thought i'd share .. after i build a s/h now i must have a noise source i've tried a simpler schematic but it was clipping something maybe the transistor was too loud i chose the highest hfe .. later i read in a post that i should have choose the lowest one .. so i'm gonna try this circuit .. like that .. this is the noise circuit from the EFM wildcat .. the transistors are 2n3904
greetings
vladosh
 Filesize:  109.48 KB
 Viewed:  301 Time(s)
citric acid
PostPosted: Thu Sep 29, 2011 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
hi,
nice one ..i will try this ...im in stipeboard fever ...so if you have more simple layouts..please let me know Smile
thanks
cit
http://soundcloud.com/citric-acid-303
vladosh
PostPosted: Thu Sep 29, 2011 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Cit
You can try that Sample and Hold i posted here in this section .. the one from Osamu Hoshuyama is very simple but i like it a lot .. i'm thinking on making 2 -3 more of those ..
Greetings
Vlad
transistor logic
PostPosted: Tue Sep 18, 2012 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
is there just that one trace to cut . i guess there is also under the chip , never built on strip board before
vladosh
PostPosted: Wed Sep 19, 2012 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
hi logic .. yes under the chip those 4 are cut i should have posted a layout with the copper side too maybe .and now i see a mistake i made ..that 10uF electrolitic capacitor should have cut trace underneath too .the schematic is in this pdf ..should not be complicated i hope http://www.modular.fonik.de/files/EFMforum/orgEFMfiles/wildcat_001.pdf
