Activate/Deactivate Slots with midi?
Page 1 of 1 [9 Posts]
gomidas
G2 patch files: 6
PostPosted: Sat Mar 12, 2011 5:47 am    Post subject:  Activate/Deactivate Slots with midi?
Subject description: midi or not midi, that is the ?...
Hello,
Can somebody confirm that I cannot activate/deactivate a slot with midi?
PostPosted: Sat Mar 12, 2011 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
That seems reasonable - deactivating a slot requires a recompilation of the slots, causing a moment's silence. I'm not aware of any such action that can be done over MIDI.
/Stefan
gomidas
G2 patch files: 6
PostPosted: Mon Mar 14, 2011 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
So I must take care before I power off my G2 Engine that the slots are activated in patch mode before I go to a gig, if not... there is no way to do it without a computer...
I think I might sell my 2 G2 engines to buy A REAL G2 Keyboard...
Thank you ANTIMON
speak_onion
PostPosted: Mon Mar 14, 2011 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
You could just save a performance that has all the slots activated, send PC to global channel to load that performance, and then send PCs on each slot channel to select the patches you want on each slot. Or if you are only using a single patch in each slot for the gig, you could just make a performance with those patches and load it each time.
PostPosted: Mon Mar 14, 2011 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you ANTIMON
Have you wiped all performances? The G2 always starts up with the first performance, IIRC.
I only use my Engine at home in the bedroom - I can imagine it's pretty limited for live use. Even so, I wouldn't mind a keyboard...
If you're not concerned with CPU usage, simply turning down the volume on slots you don't use can be done over MIDI. Just saying.
speak_onion
PostPosted: Mon Mar 14, 2011 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I've played a lot of shows with mine and never felt limited. You just need a good controller. Those Novation Remote controllers seem to work for a lot of people. I use the Remote Zero and prefer the totally customizable layout of many knobs, sliders, and buttons, to the limited 8 knob/8 button layout on the keys.
exeterdown
PostPosted: Fri Jan 24, 2014 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
This is exactly the kind of stuff I was worried about if I was going to buy an Engine. I was worried I'd have to set up buttons in each patch to change programs/patches and didn't want to "paint myself into a corner" so to speak.
I haven't touched things like Performances on the Keyboard yet.
Derek Cook
PostPosted: Wed Feb 05, 2014 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the late reply! I have a Nord G2 Engine (bargain for £400 in 2005!), and have never had any issues controlling it live. I have some good controllers though!
  • Roland FC300 Foot Pedals
  • Yamaha EX5 (a great controller keyboard as well as an excellent synth
  • Novation Remote 61
So as long as you have good controllers, and are prepared to do a little programming of those controllers, the Nord G2 engine is far from limiting! If I came across a G2X for a bargain price mind..... Smile
I always run the G2 Engine in performance mode.
I must admit when I purchased the G2 Engine, I was nervous about lack of a UI, but once I figured out how to change performances and do the controller mapping, it was never an issue.
Regards
Derek Cook
www.echoes-music.co.uk
www.purefloyd.co.uk
www.carregddu.co.uk
www.xfactory-librarians.co.uk
www.ex5tech.com
exeterdown
PostPosted: Thu Feb 13, 2014 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Any particular tips or hurdles which you bumped into which might save a new Engine user some time and stress?
