Inventor
Joined: Oct 13, 2007 Posts: 5964 Location: San Antonio, Tx, USA
Audio files: 258
Posted: Thu Jul 21, 2011 10:04 am Post subject:
Lunettatic ChucK program Subject description: A work in progress |
I was inspired by the Lunetta Challenge to create more with Lunettas, however I was tired of wiring stuff up. I also wanted to create something that I could share with others. So I decided to write a ChucK program that makes Lunettas.
I called the program Lunettatic for fun and started coding it up while broadcasting on my port at electro-music radio. I'm doing that now as i write this, and I used Nicecast to record just a short little segment of the first working version.
I've attached the code and the audio sample. The circuit is as follows: It's a Boolean Sequencer clocked at 6 Hz with a 12 bit counter (CD4040 model) and XOR gates going to a summing network at the output. Simple, yet sounds kind of pleasant. More later as I progress.
Les
| Description: |
| version 2 of Lunettatic ChucK program |
 Download |
| Filename: |
Lunettatic2.ck |
| Filesize: |
2.31 KB |
| Downloaded: |
80 Time(s) |
| Description: |
| Audio sample of version 2 of Lunettatic ChucK program |
 Download |
| Filename: |
Lunettatic2 20110721 1248.mp3 |
| Filesize: |
794.29 KB |
| Downloaded: |
172 Time(s) |
_________________ "Let's make noise for peace." - Kijjaz |
Inventor
Audio files: 258
Posted: Thu Jul 21, 2011 12:40 pm Post subject:
I added spatialization using a CD4052 mux model in ChucK software form. It works by a two-bit selection of the four spatial positions which use simulated resistor dividers to weight the inputs, more on left for left spatial position and more on right for right spatial position. Hear the bits bounce around in your head, wow what a beepy triip! enjoy!
Les
| Description: |
| version 4 program with spatialization |
 Download |
| Filename: |
Lunettatic4.ck |
| Filesize: |
4.19 KB |
| Downloaded: |
70 Time(s) |
| Description: |
 Download |
| Filename: |
Lunettatic4 20110721 1528.1.mp3 |
| Filesize: |
2.07 MB |
| Downloaded: |
142 Time(s) |
Inventor
Audio files: 258
Posted: Thu Jul 21, 2011 3:20 pm Post subject:
Here is the final version with spatialized sound and three voices.
Les
| Description: |
 Download |
| Filename: |
Lunettatic8.ck |
| Filesize: |
5.55 KB |
| Downloaded: |
96 Time(s) |
| Description: |
 Download |
| Filename: |
Lunettatic8 20110721 1813.mp3 |
| Filesize: |
781.22 KB |
| Downloaded: |
157 Time(s) |
Winstontaneous
Joined: Oct 31, 2008 Posts: 38 Location: Berkeley, CA
Posted: Fri Aug 12, 2011 1:01 pm Post subject:
Wacky and fun!
I've just barely started to scratch the surface of sound programming languages (pure data, Processing, Super Collider, Chuck).
Your examples and creativity are inspiring! |
