CD4031 tap looper...
Page 1 of 2 [33 Posts]
kaputtpanzer
PostPosted: Mon Oct 03, 2011 5:58 am    Post subject:  CD4031 tap looper... Reply with quote  Mark this post and the followings unread
Hey,
I was wondering how to build one of these fancy tap loopers. I found this schematic (http://oi51.tinypic.com/34ye33c.jpg), but I am not sure how to combine it with the 40106 oscillators. Is there a complete schematic for something like this: http://www.youtube.com/watch?v=aD587BP67Ro
Thank you very much
stolenfat
PostPosted: Mon Oct 03, 2011 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
great find that SHIT IS AWESOME.
Kabzoer
PostPosted: Tue Oct 04, 2011 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I built one of these once, there is a schematic of it flying around somewhere on the internet, I'm busy looking for it!
Kabzoer
PostPosted: Tue Oct 04, 2011 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I found it! It's on the Blog of ConcreteDog:
http://concretedog.blogspot.com/2011/04/new-tap-looper-design.html
This one works great because it already gives an output if you're jamming the buttons to program it!
tjookum
Audio files: 26
PostPosted: Wed Oct 05, 2011 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
really need to build this! There was a very lengthy discussion about these on the sound of logic forums.
There are also the 4557(1 to 64 bit variable length) and 4562(128 bit). Both are hard to find but should add even more variety to this awesome design.
Hunter S. Thompson
movies
noise
jean bender
PostPosted: Wed Oct 05, 2011 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm still looking at new informations for building even more and different booleanish sequencers... I've seen that Eric Archer build a beautiful and very intersting thing with shift rgisters ( it's BirdBox) but it seems that it's webpage is not up any more.
Could someone here give me links to informations about shift registers ? Datasheet are helpful, but i think i need more information about them !
thanks...
http://h.a.k.free.fr/
www.electroncanon.org
Kabzoer
PostPosted: Wed Oct 05, 2011 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
For some general information about shift registers: http://electro-music.com/forum/topic-46838.html
And I'm totally interested in that BirdBox, as well as all the other desingn in his “Big Box o’ Techno” (http://ericarcher.net/devices/big-box-o-techno/)
He uses a great combination of both analog and CMOS devices...
jean bender
PostPosted: Wed Oct 05, 2011 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
i totally agrre with you !!
Thanks for sharring the link to the other forum, but i would need some schematics, i don't really see how to wire this kind of ic to other lunetta's stuff !
concretedog
PostPosted: Wed Oct 05, 2011 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
So the one on my blog that is linked above has a schematic you connect the output of this to something that takes a gate or trigger input so simple solutions could be to connect it to a 4093 gated oscilator or I quite often patch mine to some simple envelope generators I have.
@Tjookum...I know you should build this as I reckon i sent you some of the chips in the great Tjookum-concretedog trade a while ago!
edit... Forgot to add...the 4031 version of this that Toptop came up with can do 4/4 timesignatures whereas the MC14557 based one on my blog can do lots of different timesgnatures as you can change the lengh of the shift register.
I waffle on about my tap looper in this video http://vimeo.com/21893709
kaputtpanzer
PostPosted: Thu Oct 06, 2011 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Its hard to find the MC14557 here. Is there no schematic with the 4031. Or can I just replace it with the mc14557...
Thankkk youuuu
sneakthief
PostPosted: Thu Oct 06, 2011 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Thankkk youuuu
really?
how about 4,06e for 5:
http://www.ebay.de/itm/5-PCS-4557-CMOS-IC-Bargain-Pack-CD4557-MC14557-HEF4557-/220512808951?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item3357966ff7
Sneak-Thief - raw electrofunk
kaputtpanzer
PostPosted: Thu Oct 06, 2011 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
pssst! I just ordered a bunch of cd4031 an I want to use them...
Kabzoer
PostPosted: Thu Oct 06, 2011 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can just replace it with an 4031, I did that too, for the same reason Very Happy
The only differnce between them is the pinout and the fact that the other one has a variable length.
concretedog
PostPosted: Thu Oct 06, 2011 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
sneakthief wrote:
Thankkk youuuu
really?
Yep...thats who I bought mine off. Wink
kaputtpanzer
PostPosted: Wed Oct 12, 2011 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Soooo this is exactly what I have done:
Why is this not working? Ahh it's driving me insane Twisted Evil
 Filesize:  47.31 KB
 Viewed:  478 Time(s)
PickNick
PostPosted: Wed Oct 19, 2011 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
hi!
if just the pinouts are different than check out this schemo:
L1,L2...are connnected to + and ground via 10k
Allow theex.nl
piedwagtail
PostPosted: Wed Oct 19, 2011 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don Lancaster :
This is a fully static shift register with the ability to recirculate data. It is arranged as 64 serial-in/serial-out stages.
In normal operation, data to be stored is routed to the Data In terminal and the Mode input is grounded. Data enters the register on the ground-to- positive transition (positive edge) of the clock.
In 64 successive clock pulses, entered data will appear as an output on pin 6 and as its complement on pin 7. The normal output (pin 6) may be routed as an input to a following register, cascading stages in multiples of 64. Pin 6 and pin 7 can each drive one TTL load.
If the Mode input is made positive, data at the REC IN terminal gets entered on the next positive clock. For recirculation, the REC IN terminal can be connected to pin 6 of this register or any cascaded register. Alternately, the Mode control can be used to select the data stream on pin 1 (Mode positive) or on pin 15 (Mode grounded).
The clock must be noise free and have only one ground-to-positive
transition per desired clocking. Unlike most CMOS circuits, the clock has a very high capacitance of 60 picofarads that must be driven with a rise time of one microsecond or less. Whatever is driving the clock must have a minimum source and sink current of 1 milliampere to drive this capacitance.
As packages are cascaded with a common clock, the clock capacitance multiplies accordingly and the input drive current needed goes up proportionately.
A slightly delayed replica of the clock appears at pin 9 which can be
used to drive one additional register. "Daisy chain" clocking like this
introduces some recirculation problems—see manufacturer's data sheet for recommendations.
Maximum clock frequency is 4 megahertz at 10 volts and 2 megahertz at 5 volts. Total package current unloaded at a 1-megahertz clock rate is 1.2
milliamperes at 5 volts and 2.4 milliamperes at 10 volts.
Hyper clean hyper rise
SERIES another two of those 40106 inverters after the clock generator to drive the fkr.
kaputtpanzer
PostPosted: Tue Oct 25, 2011 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I will give it a try. Thank you so much
Top Top
PostPosted: Tue Sep 11, 2012 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, realize it is a long time later, but I just found this thread when doing a search for my own schem.
I am the fellow who came up with that design initially.
For anyone who looks up this design, or is otherwise interested, I finally put up a post on my blog about this design:
http://www.tinydazzler.blogspot.com/2012/09/tap-loop-tap-loop-4031-tap-looper.html
Looking at your schem, nothing looks wrong about it to me. Did you ever work it out? What were you gating with it? You know it doesn't produce sound on it's own right? You need to gate/trigger something with it.
Also, .1uF is a pretty small cap for a clock oscillator. Isn't that up in the audio rates?
A. MAGIC PULSEWAVE ELECTRONICS
PickNick
PostPosted: Sat Sep 22, 2012 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
hi!
i built the 4031 tap looper based on Top Top's schemo, but mine play back just once.
i used cd4031BE and the clock source is 40106.
any idea?
hmmm...
i don't know what was the problem but now it's working:)
Allow theex.nl
Top Top
PostPosted: Sat Sep 22, 2012 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
PickNick wrote:
hi!
any idea?
hmmm...
If it is only repeating once, that means the output is not being looped into the input properly.
One thing to make sure is that your "clear" switch is a normally connected type of switch (if it is normally open, it won't allow the output to return back to the input).
PickNick
PostPosted: Fri Sep 28, 2012 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Top Top!
now it's working.
there was some cold solder joint.
Smile
Allow theex.nl
Glitch-Militia
PostPosted: Sat Sep 28, 2013 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Would it be possible to have a LED output on the stages? Also triggering a drummachine instead of gating an oscillator?
Top Top
PostPosted: Mon Oct 14, 2013 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
1) Yes, just connect gate output -> 1K resitor -> LED -> GND.
2) Yes, actually sitting on my bench for like two+ years now is an unfinished gate looper drum machine. The module could trigger anything that takes gate or trigger inputs. Create a drum module that is trigger-able and this gate looper could trigger it.
Glitch-Militia
PostPosted: Tue Oct 15, 2013 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks TOP TOP.
