  EdisonRex Edison's Electronic Review (next show Jan 2)
ChucK <--> Control OSC, TouchOSC, IanniX, ...
heuermh
PostPosted: Mon Oct 10, 2011 1:52 pm    Post subject: ChucK <--> Control OSC, TouchOSC, IanniX, ... Reply with quote  Mark this post and the followings unread
Just wanted to post a note about some convenience classes I've been adding to LiCK, a Library for ChucK
https://github.com/heuermh/lick
for interacting with various tools over OSC (and also in MIDI, for some cases). The classes follow a similar pattern, where you assign procedures (function pointers, basically) to OSC pattern names. For example, to wire up a trigger in IanniX to play a sample
Procedure noop;
IanniXOsc ianniX;
RolandTr808 tr808;
// kickA sample fired for triggerOn OSC message /trigger 1 127
// no-op for triggerOff OSC message /trigger 1 0
ianniX.addTrigger(1, tr808.kickA, noop);
ianniX.connect();
There are classes for
Control OSC
http://charlie-roberts.com/Control
TouchOSC
http://hexler.net/touchosc
IanniX
http://www.iannix.org
Euclidean Pattern Generator
http://www.hisschemoller.com/2011/euclidean-pattern-generator-1-1-osc-support
GrandJu
PostPosted: Wed Oct 12, 2011 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi heuermh,
It's seems to be a lot of intersting things in LiCK! Thanks a lot to share all this code.
I am interesting about scales. In which files can I find it?
Thanks,
Ju
heuermh
PostPosted: Wed Oct 12, 2011 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah right, scales! I haven't written that class yet, my intention would be to implement it similar to Chords.ck, in that each scale references a set of intervals from Intervals.ck.
In the meantime, you may wish to refer to
http://wiki.cs.princeton.edu/forums.html/Scales.ck
or
https://lists.cs.princeton.edu/pipermail/chuck-users/2009-December/005092.html
Although the link in that email seems to no longer be valid.
McKein
PostPosted: Wed Feb 22, 2012 6:36 am    Post subject: Reply with quote  Mark this post and the followings unread
The code happens to work flawlessly. Much appreciate you have brought it into life.
heuermh, is there any success cell phone spyware in making scales implemented similarly to Chords.ck? Hope, you did it
heuermh
PostPosted: Tue Nov 20, 2012 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are now Scale.ck and Scales.ck in LiCK
https://github.com/heuermh/lick/blob/master/Scales.ck
